is there any Phone holder that works with Prius Gen 5
Discussion in 'Gen 5 Prius Main Forum' started by deev, Apr 11, 2024.
  1. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    as question - is there any Phone holder that works well with Prius Gen 5? thanks.
  2. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I've been very happy with this one:
    The adhesive pad it came with let go after a few weeks, but I reattached it with a better adhesive pad.
    #2 Paul Gregory, Apr 11, 2024
  3. Cc103acs
    Cc103acs New Member
    28
    Connecticut
    2024 Prius Prime
    XSE
    I spoke to the dealer about mine not working. And he indicated it works without my case. So I tried it and found that it is hit and miss but occasionally goes into the charge mode. I pointed out that I have a MagSafe case that is recharged via magnet at home and having to t take a case off a phone to charge it is ridiculous. They didn’t care… it works.
  4. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
  5. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I don't like to use the wireless charging slot because the reception can't be as good as when the phone is in a higher position.
  6. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
  7. Mendel Leisk
    41,406
    It'd be nice if there was convenient "clip point" on the dash, purpose-built for cell phone holders.
  8. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Mine mounts very nicely on the flat surface to the left of the steering wheel.
  9. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Can you imagine the heat they'd get for doing that? Have you noticed that every other car manufacturer puts their wireless charging pad below the level of the dash?
  10. Mendel Leisk
    41,406
    From whom?
  11. otatrant
    otatrant Active Member
    331
    204
    San Francisco
    2023 Prius Prime
    XSE Premium
    That is where I have mine too. I have a old version of the iOttie phone holder on amazon. Once I update my iPhone am planning on getting a magnetic holder/charger.
    Anyone have a magnetic cell phone holder/charger they like for iPhone?
  12. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Mine is not magnetic, but it clamps the phone when you place it in the cradle, and it unclamps with a button-press, even when the power is off.
    otatrant likes this.
  13. deev
    deev Junior Member
    47
    usa
    2024 Prius Prime
    XSE Premium
    Would you consider sharing the product link?
    Thanks.
  14. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I shared the link, but I don't know how to make it visible. If you hover over it, a line appears. Click on that for the link.
  15. Mendel Leisk
    41,406
    If it's an Amazon link, they work properly if you type and select representative text, then click this icon:
    And paste the Amazon link into the field presented.
  16. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    That's the one I used. It decided not to display it, apparently.
  17. Beach Dweller
    Beach Dweller Junior Member
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    This holds it well and you can charge via the cable.
    https://a.co/d/6vJtftc
  18. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I believe I did that, but the result is what you see. You can still access the link.
  19. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I am quite happy with wireless Android Auto. My other car requires a cable, and I find it inconvenient.
  20. wstt
    wstt Member
    147
    24
    CN you post a pic of your setup?
