Is there a thread for Gen 4 Wheels?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by padroo, Dec 12, 2017.
  1. Joe Murillo
    Joe Murillo Junior Member
    Los Angeles
    Do you still have the springs? Its been a while but worth a shot!
    Beezybone likes this.
  2. gattaiolo
    gattaiolo Junior Member
    22
    Belgium
    Hello everyone! I was wondering if 18inch wheels with an offset of 35, a width of 8J and 225/40 tires will rub inside the wheel arches when the car is fully loaded. I plan to keep the original springs. Thanks!
    #22 gattaiolo, Feb 25, 2024
  3. BiomedO1
    3,963
    2,089
    SacTown, Ca
  4. vvillovv
    vvillovv Senior Member
    4,322
    1,511
    NY
  5. Beezybone
    Beezybone Junior Member
    24
    Murrieta
    2020 Prius
    Are the springs still available? I’d like to purchase it. I’m in inland empire
  6. gattaiolo
    22
    Belgium
    That's exactly why I was asking in this specific thread about wheels on Gen4 Prius
  7. vvillovv
    4,322
    1,511
    NY
    "Just sayin" that is a fairly detailed set of conditions and the tolerances are going to be close without extra weight. Is there a standardized weight limit for the Prius? 1000 lbs / 450 kg ? Would the extra weight be passengers, all in the cargo area, or some other configuration or weight distribution?
    I hope you get lucky and someone else has already done what you're asking about and it has worked for their Gen 4.
  8. Beezybone
    24
    Murrieta
    2020 Prius
    No it will not rub. I ran 18x8 +35 with a 225/45 tires and did not rub
    vvillovv likes this.
  9. gattaiolo
    22
    Belgium
    Hi everyone ! I finally found what I was looking for
    A set of 18x8j ET35 wheels (RIAL "Lugano", very similar to Volkswagen "Interlagos" rims). They are second hand but in good condition, and are mounted with 235/40R18 winter tires that will soon be replaced with summer tires with proper dimensions (though I'm happy to announce that 235/40 tires don't rub).
  10. dehning
    dehning Junior Member
    Apache Shores, TX
    2018 Prius
    If OP is still interested, I'm about to replace the stock OEM + Hubcap combination on my recently acquired 2018 Four with 2018 BRZ wheels. They have the same lug spacing and default tire size as the touring package [​IMG] and I'll just use a bore spacer. Pics to follow tomorrow!
  11. dehning
    Apache Shores, TX
    2018 Prius
    Here you go, BRZ/Toyota 86 wheels. I forgot that you have to use an 8mm spacer to get the wheels to clear the callipers. you also need to change lug nuts. prius new wheels.jpg
  12. Mike_Ike530
    Mike_Ike530 New Member
    Washington
    Three Touring
    Question, was 8mm the absolute minimum one could go for with spacers?
    I'm going with some 2013 BRZ/86 wheels (17x7, 5x100, +48).
    I'm hoping to get a 5mm spacer but haven't measured if that'd be enough to clear the calipers.
