Change transmission oil on my '02?
Discussion in 'Generation 1 Prius Discussion' started by Trombone, Mar 24, 2024.
  1. Tideland Prius
    16,566
    For your information, your replies and coming in as Russian rather than English. If you are using an app like Tapatalk, it’s not transcribing into English for the rest of us.
  2. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    Interesting.
    I'm not sure putting engine oil in the transaxle is a good idea. What is the rational?
  3. nolik
    nolik New Member
    29
    Dobczyce
    2001 Prius
    I
    if nothing happens in the box and the oil just splashes, then what is the problem, what prevents you from doing this?
  4. dolj
    dolj Senior Member
    8,458
    4,294
    For me personally, nothing prevents me from doing this, it is just Toyota specified a very specific transmission fluid and as that is readily available I just use that. It never crossed my mind to use engine oil.
    I'm more interested in why you're taking the approach you're taking.
  5. ChapmanF
    18,317
    For one thing, it splashes on the insulated electrical windings of high-voltage electric motors, and one goal of the prescribed oil is that it should not chemically degrade the insulation.
    Even more generally, oils have always been chosen for very specific conditions of viscosity, lubricity, and so on, and I can't recall any instance where the oil for a car gearbox was specified to be the same oil used in the engine; I would be unlikely to assume either one would be suitable for the other use.
  6. Trombone
    Trombone Active Member
    327
    111
    Allentown, Pennsylvania
    2002 Prius
    Don't feed the trolls. Russian clearly isn't talking about our cars anyway. Ignorance in action.
  7. nolik
    nolik New Member
    29
    Dobczyce
    2001 Prius
    I
    you're funny, I laughed. How is my Prius different from yours?
  8. mroberds
    mroberds Member
    143
    58
    2001 Prius
    This is correct. You can't see the magnet unless you take the whole pan off of the transmission. At least for me, the magnet normally has a little bit of "fuzz" on it, as stated.
    For OP, or anyone else contemplating a transmission fluid change, you can get 6-packs of Toyota T-IV ATF on Amazon for roughly $50, delivered, in the US. At least for me, this is a lot better than I can do at the local dealer.
    I also recently discovered that the Dorman 095-149 aluminum crush washer is pretty much an exact replacement for the Toyota 90430-A0003 washer, used on the transmission drain and fill plugs. A bit over $2 and on the shelf at an O'Reilly near you.
    I very vaguely recall that some 70s Japanese cars (Datsun?) took engine oil - like, 10W40 - in their manual gearbox, but I don't know if 1) that's true or 2) it was a factory spec, or some kind of hot-rodder/enthusiast/lore thing. In that era I would have expected something more like 80 or 90 weight gear oil.
  9. Mendel Leisk
    41,645
    From 1990 Honda Accord Shop Manual:
    engine oil: 10W30 or 5W30
    manual transmission: 10W30 or 10W40
    80~90 weight gear oil was specd for something on our daughters previous 4WD Honda Pilot. Not the rear differential (which took a proprietary Honda fluid); it was another 4WD related component in the engine bay, transfer case or similar?
    #29 Mendel Leisk, Apr 13, 2024
    mroberds likes this.
  10. Trombone
    327
    111
    2002 Prius
    Mission accomplished! Transmission oil drained, pan removed and cleaned, reinstalled with new gasket, refilled with Toyota T-IV. The pan was surprisingly clean, just the expected sludge around the magnet, but no big pieces, filings, shavings, etc. I didn't really expect any. The old gasket looked like it could be reused, but I provided a new one and they used it. Car has 162,626 miles on it. There had been a previous fluid change at around 90,000, but the pan was not dropped at that time, so today was the first time that pan has seen daylight since it left Japan. Currently getting 47.8 mpg. Going out for a ride now to enjoy the refreshed vehicle.
    BTW, I had this serviced at the dealer. The charge was $272 and change; most of that was labor. They didn't gouge me on the T-IV, $43 for the 4.5 quarts. I'm not complaining. At an earlier time I might have tackled this job myself, but I'm past wanting (or being able!) to get under the car and make a mess; I can do engine oil changes, but that's about it. The car should be good for another 100K miles.
  11. K Franke
    K Franke Junior Member
    missouri
    2001 Prius
    My manual states to have transmission fluid changed at 75K. The dealership stated that was not accurate and so at 55k i paid for the transmission fluid change. I still think I should have waited until 75K, but whats done is done. My 2001 prius now has 91K and I am thinking now to have it redone at this point, even if dealership insists I do.
    #31 K Franke, Jun 10, 2024
  12. Trombone
    327
    111
    2002 Prius
    Interesting that your 2001 manual differs from my 2002 in re: transmission fluid change. I would have thought the two model years would be exactly the same. In any case, 55k was too early, and 91k is too soon after the 51k service, IMO. Of course, it won't hurt anything (except maybe your wallet!) to change the oil now, but I'd wait a few more 10k miles if it were my car. FYI, my change intervals were 90K for the first change, and 162k for the second, IOW, 72k between changes. YMMV!
    K Franke likes this.
  13. K Franke
    missouri
    2001 Prius
    yes that is interesting. Hmmm. Maybe in that year they either improved the system or realized it was not necessary to change at 75K. I think I will wait 10-15 K or more before I have it serviced again. No sense wasting money. Thank you for responding.
