combination meter repair - DIY
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ultanium, Jan 20, 2016.
  1. ChapmanF
    15,562
    There isn't the same kind of PriusChat record of gen 3 having a notorious meter capacitor issue, the way there is for gen 2. I suppose that doesn't mean one can't occasionally flake out.
  2. 2cents
    2cents New Member
    Uk
    Thank you for your response. I'm unlucky in that sense then. Started playing up when it got really cold in the winter recently.
    I'm from the UK. Helps to know it could be more than one particular issue though. Thank you.
  3. Fi0na
    Fi0na New Member
    Denver
    I followed a youtube vid to get it out
    Another one for the repair
    (I only changed the 10u)
    And my vents crumbled so found replacements on Amazon that fit like and look OEM for $99
    Edit: Seems like the site keeps trying to change my link to media for amazon. But search
    4Pcs A/C Dash Air Vent Trim Plate Panel, Air Vent Outlet Frame Cover, Compatible with 2004-2009 Toyota Prius 1.5L, Replaces# 55670-47060, 55680-47020, 55475-47020, 55474-47020
    Hope that helps!
    #363 Fi0na, Apr 5, 2024
  4. gfjg59
    gfjg59 Junior Member
    47
    new jersey
    so where is the repair thread? interested in knowing my options
  5. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    You're replying to as good a thread as any. Read the first two pages then jump to about page 15 and read pp 15, 16, and 17. After that, you can read as much of the rest as you like.
  6. PriPinball
    PriPinball New Member
    New York
    SE
    Thanks for all of the info! I joined the forum today. Just inherited a 2007 Prius from my mom when she upgraded.
    Just finished reading through 19 pages of this before starting to tackle this combo meter repair job.
    I just put together a Digikey order for Combo meter parts today. I bought all of the surface mount and thru hole caps and the 5V regulator IC.
    (I hope I got them right!, they're all low impedance/low ESR)
    the whole order was $6.83 + $4.99 shipping - about $13 with tax.
    I was going to post all of the links, but I'm not able to share links before I have 4 posts on the forum. If anyone feels like current links to digikey parts / part numbers / descriptions would be helpful, let me know and I saved it to post later on. Or I guess PM if you need it ASAP.
  7. Trafficat
    Trafficat New Member
    24
    New Reno, Nukevada, Merica
    On my Gen 2 Prius I had the combo meter go out and I soldered in a new capacitor a few times. I didn't take the old one out, just put the new one in parallel. The first few times it worked for a few months until my solder broke, but the most recent solder job has lasted about a year. I also once damaged a ribbon cable with a screwdriver and had to order one from a local Toyota dealership. The worst part about the whole job here is taking the dash apart and putting it together. I've broken lots of brittle pieces of the air vent assemblies. I've also lost a few bolts into the void, and my car rattles when driving due to random bolts somewhere in the dash.
    VFerdman likes this.
  8. pasadena_commut
    pasadena_commut Senior Member
    1,479
    445
    Southern California
    Don't leave the old capacitor in. It could potentially short out in the future which would negate any replacement capacitor in parallel with it.
    For broken vents a source of (some) replacements is mentioned in this thread:
    Dash vents I came across today while browsing.... | PriusChat
    and aftermarket ones can be found on Amazon. For instance, on that site search for B0C7L4VWV7 and it will turn up a full set of 4 for $93.
    VFerdman and Trafficat like this.
  9. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    Adding advice to NOT leave the old cap in. They do short out or just present a resistance that should not be there. Just pop it out. Not difficult to do. I used through-hole replacement cap on mine and it worked just fine. Several years and going. Car now has over 302K miles.
    Trafficat likes this.
  10. Trafficat
    24
    I was under the impression the old capacitor just slowly had less capacitance over time. Good thought about the shorting that would be really bad.
    Putting two resistors in parallel reduces the overall resistance, so it shouldn't add any resistance to put them in parallel.
    #370 Trafficat, Jul 5, 2024
  11. pasadena_commut
    1,479
    445
    Southern California
    I don't understand your point. What matters is that any resistance in parallel with your new capacitor will cause it to discharge faster, essentially making it a lower value capacitor. Not what you want since you changed the capacitor because the old one had too low a capacitance.
  12. Trafficat
    24
    When you put two capacitors in parallel, the capacitance adds together. If the bad capacitor was measuring zero capacitance, maybe it could be an issue, but I think the combo meter fails because the capacitance gets only slightly too low. There wasn't enough factor of safety designed into it.
    I know that real capacitors aren't ideal capacitors, but the hope is that our capacitors mainly just add to the reactive part of the impedance and the real part is negligible.
    Perhaps as the capacitors wear out this is a bigger problem, but I think the capacitors still measurably have most of their capacitance when the combo meter fails. I am under the impression the main design flaw here on the combo meter was that the capacitor they used was too small to begin with and just barely works.
    #372 Trafficat, Jul 5, 2024
  13. pasadena_commut
    1,479
    445
    Southern California
    That is all correct.
    When repairing electronic equipment a defective component is typically removed from the circuit board and the replacement installed in its position. The circuit can be made to work by piggy backing components and other similar hacks, and that's OK for testing purposes, but if a change is supposed to hold up long term that sort of work is not so good.
  14. Trafficat
    24
    Great thought. I definitely wouldn't want to do something hacky like this professionally. If it fails again I'll take the old capacitor off.
  15. eblade
    eblade Junior Member
    70
    Plymouth, Michigan
    Might be a silly question, but anyone able to point me in the direction of someone near-ish Detroit that is capable of pulling off this repair start to finish? I'm reaaaallly out of practice on board level repair skills, and most definitely do not have the time to deal with a dash pull
