Need Advice! [Red Triangle of Death]
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Hybrid Hobo, Apr 15, 2024.
  1. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    Sorry, long day, and I've been through hell dealing with this today. Not sure what 3 digit code you're referring to. I can try and figure it out tomorrow.
    Does anyone know, if indeed it's the inverter that's the issue, ballpark what this heavenly surprise will end up costing?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    A quick check would be to make sure the reservoir next to the inverter has fluid in it. No fluid could mean you have a leak in the system. If it's at the proper level, then check to see if there is flow in the system.
    For DIY, if you purchase the pump online from a dealership, it can generally be found for about $130ish, or you can get a chinese version for about $40ish.
    Take it to a dealership for diagnostics and replacement and you're looking at $650ish for the job.
    If you have a good mechanic that you trust, expect to pay at least $150 for the pump and some coolant and add 2 hours labor, even though the pump can be replaced in an hour or less by anyone who has done it previously.
    Sometimes, if it is the pump that is failing, it's due to electrical failure and you may get a slight acrid odor due to some potting material burning. The pump may blow the AM2 fuse and completely kill the car. The pump can be isolated by disconnecting it using the single wire connector located just above and to the left of the under hood fuse box. Plenty of pictures in the forum. Also plenty of descriptions on how to look at the reservoir to determine if the pump is actually moving fluid in the system or not.
    #22 TMR-JWAP, Apr 15, 2024
    Hybrid Hobo and Brian1954 like this.
  3. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    Update: I got in touch with my mechanic earlier, and I'm having the Prius towed to him on Friday, as he's 50 miles away and I don't want to chance driving the car that distance. He's a whiz, and will hopefully sort out whatever the issue is with the inverter pump.
    He said that - worst case - if the pump actually needs replacing, it'll cost $548 including tax. A bit pricey, but going on some of the prices I've read online, I think it's a win. TBH, I'm actually thrilled that it's NOT the hybrid battery or some other major problem I'm dealing with.
    In my stress and haste yesterday, I forgot to ask...Is it normal that the check engine light came on (and has mostly stayed on) in addition to the triangle of death? Is this normal, even though no other codes were thrown aside from the P0A93?
    Thanks to everybody that chimed in with help. I appreciate it more than I can express (y)
  4. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I would make sure you are getting an OEM Pump. Then you should be good for many more years or another 100K. I had this happen to my wife's car. I replaced the pump and disconnected the 12v battery located on the rear right trunk area. That cleared the codes and the RTOD. I would start saving for a new hybrid battery for when that day comes. $2,000 or so.
    Hybrid Hobo likes this.
  5. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    I am glad everyone chimed in ... spot on advise you get from PC.
    Agree with spend money on the toyota inverter(pump) , I literally pay less than 100 to have guy put it in, and it take him less than 40 minutes, including pour in pink fluid directly from the bottle without spill :) ...
    Good luck and stay safe .
  6. Tombukt2
    13,045
    2,336
    The pump is about 130 bucks If it cost another $400 in labor to take out three 10 mm bolts and disconnect two hoses well then your market dictates that are generally this is a 30 minute job that your kid can do but I'll take all the $548 that people want to pay.
  7. Brian1954
    Brian1954 Senior Member
    2,232
    880
    South Central PA, USA
    Yes, it is normal for both of those warning lights to come on for the P0A93 trouble code.
  8. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    that still would be cheap, sometime !!!!
    During the time I have the issue: away from home, driving between LA-OK, I stop by 2 dealers, one quote me for 540 parts and 4-5 hrs of labor, take 2 days for part to arrival and 3 days for schedule so 5 days to get it fix.
    Then another dealer in Dallas hook my prius up and say I need the ABS brake replace ... that is 1 week order from toyota ... I will not disclose dealer name nor price :) .
    I stop by their part-shop, pick up the inverter pump, drive to the closest shop I found, show him the part and explain what need to be done: he fix it - while I stand and watch ... less than 40 minutes.
    I give him 20 bucks tip for his efforts ... money well spend .
    Hybrid Hobo and Tombukt2 like this.
  9. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Yes...
    Ignore this can lead to engine run without coolant ... You have two coolant source, both important .
    If they use belt like it used to, then we would be good, but no, they have to use electric pump :)
  10. Tombukt2
    13,045
    2,336
    I charged a guy $540 to swap out the new break actuator that he bought online through the Toyota Network for around $1,300 and some change versus retail walk-in which is it like 1486. It takes me about 2.2 hours to do the job correctly maybe a tad longer.
  11. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    Due to a vigorous stroke in 2020, I don't have the same strength or mobility that I used to. So yesterday a buddy helped me open the hood of the Prius so we could poke around a bit.
    The reservoir tank for the inverter (which holds the pink coolant) was low. It had coolant in it, and still appeared very full, but its level was at just about where "LOW" was marked. Additionally...
    After I watched a few YouTube videos, I learned that the coolant (while the car is on), should almost appear to be simmering (lightly boiling) within the tank. However, it appeared totally still/stagnant.
    Might be a dumb question, but could either of these things be the issue? Further...
    How would I even know? If I went to buy coolant and topped it off, would the triangle of death go off and/or would the P0A93 code go away if I ran another diagnostic with the Autel?
  12. Tombukt2
    13,045
    2,336
    Not necessarily the being near low is not going to do the trick That's not going to take you out of fluid enough for the pump to suck air then it would make a racket you'd hear it for sure so then you and your buddy didn't hear the pump running while the hood was up and the car was on or the door open or any of that other stuff going on You should have heard that pump running You can barely see the fluid shimmering in the reservoir that you especially won't if you don't hear the little pump fluttering along is equal to the pump like in a fish tank if you remember those from back in the day It's almost like nothing's running You just hear it because it's vibrating so if you didn't hear that noise and you didn't see that movement I don't care what you do with the scanner It's not going to make any difference You probably need the pump replaced If you and your buddy would have had the pump in a 10 mm long socket and a pair of long angled needle nose pliers from Walmart you would have changed the pump in 11 minutes and 35 seconds or something It's that simple it is stupid easy stroke or not this has nothing to do with that I promise you don't need to worry you could be sitting in the bar chair if you wanted to do this job practically It will take no excessive stooping bending or any special mobility requirements that younger people might have at this point I am near your age have not had any strokes but have a bad hip.
  13. ChapmanF
    18,249
    This thread is in the forum for gen 2 Prius, where the engine water pump does use a belt.
    Also, the trouble code being discussed is P0A93, which has nothing to do with the engine cooling system or the engine water pump. P0A93 is about the cooling system for the inverter and transaxle, which is completely separate from the system for the engine.
    Hybrid Hobo and ccna101 like this.
  14. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    *Opinions, please*
    The car will be towed by roadside assistance on Friday 60 miles to my mechanic in NJ. But I am currently spitting distance across the border in PA.
    The roadside assistance company said it will be MUCH easier to get a tow truck if it's an interstate job versus out of state...even though I'm only about 1.5 miles away from the NJ border.
    Should I chance driving over the border to the nearest rest stop in NJ, which is about 4 or 5 miles away?
    If the car stalls or dies out in a bad spot or on the highway that obviously won't be good, as roadside assistance companies don't cover highway tows.
    FWIW, I've driven the car a few blocks here & there for gas, etc. the past 2 days with no issues. In addition, I've been running the climate control and all that. So, no problem with either of the batteries or anything. At this point, it appears to just be an inverter pump problem.
    Worth taking the risk?
  15. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    I think if you drive a short distance you should be good. The invertor pump cools the invertor so a 4mile trip ought to be OK to do. If you get the warning lights again. You can pull over and let it cool. But it will take a bit to generate heat
  16. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    Thanks. I got the main gist of your point (y)But to be clear, the warning lights (red ️ of death & check engine) are already on. They've been on since this debacle began 2 days ago, and I never turned them off via the OBD reader since.
  17. ColoradoCrow
    1,108
    464
    Leawood, KS
    I
    If you unplug the 12 volt battery and wait 3 mins you might be able to clear the codes.
  18. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    Went into the store earlier. Only a couple of blocks from where I'm staying, so no big risk. When I came out a few minutes later and restarted the Prius, oddly, the triangle of death, check engine, and other lights all went out.
    Instrument cluster now appears normal, like it usually does.
    I'm guessing it isn't my lucky day, and that the problem hasn't magically fixed itself, or disappeared :LOL: If that's the case...
    Is this common? They've been on for days and they suddenly all go off?
    Anywho, I'm driving a few miles across the border to NJ tomorrow morning for a tow. I'll check back in after getting the car back from my mechanic on Friday or Monday.
  19. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    You can drive it that short distance (straight to your mechanic in NJ) and it is not really a risk. You should avoid the highway if you can and drive no faster than 45 MPH. Do without A/C if you can.
    If the car is driving okay then codes should not be cleared. It doesn't fix anything and only makes it harder for the mechanic to diagnose or confirm.
  20. Hybrid Hobo
    Hybrid Hobo Member
    201
    New Jersey
    I was going to chance driving it to the mechanic, but I've been paying for roadside assistance for 2 years and never used it, so why not recoup my investment lol.
    If I didn't have bad luck, I'd have no luck at all! Waiting for the tow truck now, and the triangle of death and all other lights are still off. Murphy's Law. As you said, now it's going to be more difficult for the mechanic to diagnose. Ugghhh!!! :mad:
