Talk about torque.
Discussion in 'Gen 5 Prius Technical Discussion' started by Maturedriver, Apr 18, 2024.
  1. Maturedriver
    Maturedriver Junior Member
    56
    46
    England
    2024 Prius Prime
    I’m confused. Apparently in the 2023/24 Toyota Prius the 2litre internal combustion engine develops 196hp and 139 ft-lbs of torque. Why in the Prime version does it only develop 160hp with the same engine?
    I know it develops a healthy 220hp when combined with the (surprisingly high) 161hp electric motor but does anyone know how much torque the electric motor produces? Additionally how much torque is produced when the engine and motor work together? Strangely Toyota seems to treat this information as a trade secret.
  2. soft_r
    soft_r Active Member
    183
    151
    Beverly Hills
    2024 Prius
    Because it's unimportant info. And if the numbers aren't amazing then there's no benefit to sharing it.
    You get 0-60 in 7s. That information is all that will be relevant to 99.99% of people in their daily driving.
    If you want to know, go get the car dyno'd.
    Danno5060 and AndersOne like this.
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The internal combustion engines in the Prius and Prius Prime output the exact same hp and torque. The difference in total hp is due to the Prime being able to pull more power from the larger battery. Also, the total net power output is not the sum of the different power sources.
    Prius/Prime M20A-FXS
    150hp @6000rpm
    139lb-ft @4400-5200rpm
    Prius HEV Electric Motor
    111hp
    83kW
    Prius HEV AWD Rear Electric Motor
    40hp
    30kW
    Prius Prime Electric Motor
    161hp
    120kW
    Net Power Output
    Prius Prime - 220hp
    Prius HEV AWD - 196hp
    Prius HEV FWD - 194hp
    mva and Trollbait like this.
  4. Maturedriver
    56
    46
    England
    2024 Prius Prime
    Thanks for that but still no mention of electric motor torque and total torque figure.
    #4 Maturedriver, Apr 18, 2024
  5. Maturedriver
    56
    46
    England
    2024 Prius Prime
    Strange and unhelpful response.
  6. ChapmanF
    18,447
    ... which is ('cause somebody's bound to ask) because some of the power from the engine is delivered to the output mechanically, while the rest goes through the electric motor. Therefore, the power rating of the electric motor has to include that portion of engine power; it is not entirely a separate source of output power.
    reallyreal likes this.
  7. Trollbait
    12,652
    From Toyota's site, the engine in both produces 150hp and 139ft-lbs. The system power of the hybrid is 194hp, though I see the Wiki lists a 193-196 range for that.
    The peak motor was once published for hybrids, but an electric motor's peak is at zero rpms. That isn't of much use to drivers. With the differing torque curves, and a portion of engine torque always going, coming up with a nonconfusing figure is probably a nightmare. Toyota explains the system power in a paper.
  8. ChapmanF
    18,447
    I'm pretty sure I remember seeing a torque 'curve' for an MG2 in whatever gen, and it was pretty simple: it was flat horizontal at the spec'd maximum torque from zero RPM right out to where the torque times the RPM equaled the max power. From that point, with increasing RPM, the torque followed the downward curve (max power / RPM), kind of as you'd expect.
  9. Maturedriver
    56
    46
    England
    2024 Prius Prime
    I currently have a 2020 VW Golf Mk8 GTE (PHEV)
    The electric motor develops 114bhp. Torque 243 lbs-ft.
    The engine produces 148bhp. Torque 185 lbs-ft.
    Total of both when working together 247bhp. Torque 295 lbs-ft
    Why can I only find some of Prius Prime’s power and torque figures?
  10. Trollbait
    12,652
    I don't recall Toyota ever posting a net torque for a hybrid. They used to for the motors, but now you have to go elsewhere to find even the power rating of M/G1 or whatever they now call it. Some of it is likely because the buyers Toyota mostly attracts buyers that likely don't care, and the company doesn't want to risk data overload scaring them. The general public is still clueless about hybrids. Some even about cars in general. The fact that our salespeople tend to know little about any of the cars they sell could also play into it.
    As for the Golf, VW is using a very different hybrid system. It is parallel hybrid with a traditional transmission. There is one powerful motor that simply inputs input into the drive train using energy banked in the battery. The same motor charges the battery, either through regen braking or driven by the engine. The math here is simple.
    The Prius and most Toyotas use a power/split system. These work as a parallel and series hybrid at the same time. There are two powerful motors. M/G2 is on the tail end of the drive train, and is the traction motor. M/G1 is buried in the eCVT. The planetary gear stet in the eCVT always diverts @20% of the torque generated by the engine to M/G1. Which then uses the electricity to drive M/G2 or charge the battery.
    So the torque reaching the wheels from the engine is not the full torque the engine produced. The math is starting to complicate. Then M/G1 may not take all the torque it receives from the engine to make electricity. The system can vary its output, thereby simulating the variable gear ratios for the eCVT.
    For both types of hybrid systems, the manufacturers have to also consider the battery. Max motor output only comes from banked energy in the battery, and it won't last long. In the early hybrid days, the gen1 Prius had a turtle warning light to alert the driver that power is limited by a depleted battery.
    Maturedriver likes this.
  11. Maturedriver
    56
    46
    England
    2024 Prius Prime
    Many thanks for the explanation. Wow! I thought the VW system was complicated (because it uses a twin clutch gearbox) but since the Prius Prime has TWO electric motors I think Toyota wins the prize. When my dealer has a demonstrator I will be able to tell how much torque it has. Have to say on my Golf GTE when the traffic lights turn green if I just tickle the accelerator it’s off like a scalded cat! I hope to replicate this with the Prius PHEV.
  12. ChapmanF
    18,447
    Toyota wins both the simplicity and the complication prize.
    Simplicity because the transmission is so utterly minimal and bulletproof. Two motors, a set of gears that are always meshed the same way, nothing that ever clutches or shifts. Simplicity itself.
    Complication because the first time you try to think through what it's doing, there's a bit of mind-bending involved. Once you get through it, that part's simple too.
    PrimeDan likes this.
  13. otatrant
    otatrant Active Member
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    I realize this is an old thread but I came across this spec sheet on the Toyota Europe web page that clearly states the Plug-In Hybrid power and torque numbers. I don't see these torque numbers listed even on the Toyota Prius Prime Wikipedia page.
  14. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I think we've known before what the engine torque is and what the electric motor torque is, but we've never known what the net torque is when both systems are combined. Unfortunately this chart doesn't tell us that either. It gives the net HP but not the net torque.
    otatrant likes this.
  15. otatrant
    348
    211
    San Francisco
    2023 Prius Prime
    XSE Premium
    It looked different because of the different units (190 NM versus 139 lb-ft). In addition I didn't see a torque value on this thread or the US Spec sheet for the Prime electric motor listed which would be 153.4 lb-ft or 208 NM per this European spec sheet. Maybe I am missing it.
  16. Hammersmith
    2,315
    2,359
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I thought someone on one of the early gen5 threads had found it buried in some documentation. Maybe the New Car Features that you can access on TechInfo? Or maybe one of the early reviews back in Dec 2022 or Jan 2023? It's been a long time so I might be misremembering.
  17. BiomedO1
    4,003
    2,104
    SacTown, Ca
    I believe the OP was trying to do a comparison with his 2020 Golf PHEV and couldn't find data to compare them to.
    It's a moot point since someone that's used to driving a performance oriented DSG car is going to be sorely disappointed with the driving dynamics of a gen5 prime. The seat in the pants feel will be way off (even if you place it into sports mode, IMHO); unless they just want to slow-down, take it easy, and enjoy the ride + gas sipping (high tea).o_O:D:LOL::ROFLMAO::whistle:
    Just my two cents.....
    Winston Smith likes this.
  18. VelvetFoot
    VelvetFoot Active Member
    1,124
    437
    New York State
    2026 Prius
    I use the 7 speed DSG on my MINI to upshift to a higher gear, for the mpgs, lol.
  19. BiomedO1
    4,003
    2,104
    SacTown, Ca
    I used to do the same when a manual gearbox could be had in a car. Used to do 50K miles a year as a field technician. Always got better than EPA ratings in a manual - even came close to or beat the early CVTs mpg.
  20. Winston Smith
    Winston Smith Active Member
    387
    260
    OH
    2024 Prius
    LE AWD-e
    Can a car with a CVT have torque measured at the wheels? Can a Dyno constantly adapt for the constant change in gearing?
    While true, VW DSGs have been known to disappoint owners with iffy durability. Maybe being disappointed by VW using customers as beta testers would make a person more tolerant of disappointment with the thrill free manners of a Prius.
