Buying a used prime - car longativity/Durability versus 4G prius
Discussion in 'Prime Main Forum (2017-2022)' started by Prican, Apr 19, 2024.
  1. Prican
    Prican Junior Member
    42
    toronto
    2019 Prius Prime
    Technology
    Hello,
    I'm in the market for buying a Prime. Used only around the year 2017-2020. I am the type of person who expects a vehicle to last approximately 15-20 years. I understand the prime is only been around for about 7years, And the plug-in before that.
    The bottom line is if I buy a 6-year-old car, what is the life expectancy of this vehicle versus 4G prius? I am assuming that the the traction batteries have a reserve, I was wondering when people report their SOC when fully charged, do they take the reserve into account? Because if the reserve depletes, then the SOC will drop faster.
    what is the expected lifetime of the battery down to about 50% charge ? Also are there other potential huge repair bills on's certain components? We all know Prius is good on durability over many years, is the prime objectively just as good?
    I would love to hear information on this
    thank you
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    I sold my 2012 Prius PHV to a good friend. It's still running just fine. I sold my 2017 Prius Prime to my niece. It's expected to deliver quite a number of years still. With regard to 15-20 years of use, I don't see the point. Upon reaching year 15 or so, a replacement battery with 2 to 3 times the capacity will be dirt cheap. That purchase would allow you to milk the vehicle for quite a number of more years.
  3. bisco
    52,386
    it's hard to judge longevity because it's so subjective. buying used, it may be difficult to ascertain use and abuse, and proper maintenance.
    overall, i'd say you're good for a total of about 20-25 years before needing a battery.
    Doug McC and Rmay635703 like this.
  4. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    The Prime has different battery chemistry than all the cordless models. That means the end of the battery's life is probably going to have different symptoms and timing.
    I think 15-20 years is a reasonable time horizon. Toyota is pretty good at getting everything to wear out evenly.
    Watch out for mice. Already read of one car totaled because a couple of mice chewed the wiring harness, which is insanely expensive in the Prime.
  5. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    Besides the battery, are there any other high cost ticket items that you guys have found require repairs Like a drive motor or something else?
  6. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    The electric motors and transaxle are pretty much in the "never fails" category. I mean statistically some had to go bad but that's just crazy rare.
    The battery started going bad the minute it was assembled, and you just decide how far you want to let that knife drop before you catch it. Seems like you are already on board with that.
    The HVAC system in the Prime cars is unusual and sophisticated even by Prius standards. They seem to be durable and reliable thus far, but when one does go it won't be cheap.
    The whole economics game with the Prius is down to utilization. If you are driving a lot of miles, the car will save you money. If you aren't driving much, it's the same risk of complexity causing an expensive service visit, but without the odometer bragging points.
    Doug McC, Isaac Zachary and Trollbait like this.
  7. Washingtonian
    Washingtonian Senior Member
    726
    621
    I would expect a 2017 or newer Prime to last a long time. I only have 30K miles on my 2017, but it has had zero problems since new. 90% of my trips are less than 25 miles, so the engine is seldom used. I would guess that the engine has roughly 5K miles on it now. The battery is warranted for 100K miles, so unless I abuse the car, it will last longer than I will. Since you will have the car so long, I would recommend that you buy the top model (advanced for 2017) as some of the safety items are worth having. The rear cross traffic alert has saved my nice person a few times while backing out between two long SUVs.
    Doug McC likes this.
  8. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    This is what I am after. I'm trying to ascertain whether the complexity is manageable, or if many components are $5000 for this $5000 for that and yes they break relatively often. I would love to know Those parts if they do exist or if none at all that's even better.
    The battery is something that is obvious but the other components are not to me and that is what I would like to know, Such is the hVac example
    I guess secondly, is this version of the prime more reliable than the plug-in? I only ask because I'm trying to get a feel for long-term durability. I wonder if this version is a very similar car or if there are a lot of changes
    #8 Prican, Apr 21, 2024
  9. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    I vote 'no' because the original Prius plug-in was based on the 3rd generation car, and that version of the car had a significant problem rate regarding engine cooling, ultimately manifesting as blown head gaskets.
    Toyota appears to have made significant improvements to that gasoline engine going into the 4th generation models, which include the early Prime models.
    Beyond that, the youngest Prius plug-in is what, 2015? That battery knife has fallen further. We still don't know what happens at the bottom, but it's a good bet that there is less time to enjoy the drop.
    If you want to keep a single car over a long span of years, a simple low-tech car is the way to go. Counts double when buying secondhand.
    Just to say it another way: Any Prius is a significant risk of expensive repairs later. Are you driving enough kms that you will save enough fuel to offset those potential costs?
    We're right on the edge with the math for our car. It isn't likely to save us enough to offset the higher future repair costs. But we went for it anyway because we liked it that much.
  10. bisco
    52,386
    2012 plug in is pretty darned reliable 12 years later, outside of some egr clogging/head gaskets, but the ev miles mitigate a little of that
  11. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    over 12 years is your battery degradation miles per charge linear, or exponential?
  12. bisco
    52,386
    idk the difference :p
    i lost about 10% the first year or two, then less than 5% over the following 9 years. it had 87k on it when i traded last summer, 60k was pure ev. but others in the plug in thread with much higher mileages haven't had much degradation either.
    i imagine the prime is even better.
  13. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    It's quite difficult to forecast the lifespan of a new car. It's even more difficult if the car is a new design or is using new materials. The Prime has been using Li-Ion battery packs since 2016. I use the "TOYOTA" cell phone app to get an idea how well the battery is being used. It tells me how much charge is remaining when the charging starts every day. Based on the information in that app, I deduce the following:
    The gen4 Prius Prime has only one high voltage traction battery pack. The car will let you drive under battery power until the state of charge reaches what it calls 30%. Then it uses that 30% to buffer the calls for more power or calls to store regenerated power from braking. When charging at home after a 500 mile drive, it will charge the battery by bringing it up from 30% to 100%.
    The original Prius design used NiMH batteries that they hoped would last at least 7 years. The engineers did a great job of coddling the batteries so that they lasted a LOT longer than expected. I got about 12 years on mine. By the time one of the battery cells needed to be replaced the car was 17 years old and the price of a replacement traction battery was under 1,000 dollars.
    You are not necessarily buying some one else's trouble when you buy used. I say this because I tend to clean up a car before selling it. My 2002 Prius had only 4,000 miles on the new tires. The paint clear coat needed to be cleaned up. The car had about 175,000 on the odo and I was driving it 1000 miles once or twice a month. When I sold my 2017 Prius Prime it had 75,000 miles on it from the same monthly interstate trek. It also had pretty new tires, windshield wipers, 12V battery and such.
    I'm hoping that my new 2024 Prius Prime will last a long time. It's starting to look like we will have real self driving cars by the time I'm ready to replace it. Mercedes already has one that's legal in California to drive without watching for traffic hazards.
  14. Canby
    Canby Junior Member
    Burlington, On
    2018 Prius Prime
    There's possibly a way to find out about the history of something you're buying 2nd hand if the owner has done regular maintenance etc. Ask the owner for a copy of what has been done. Usually if it's done through a dealer then a copy of the record should be available. The owner might also have records.
    AS far as what can go wrong you can look at any recalls by Toyota for the type of vehicle you're looking at and add that to the decision process.
  15. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    yes, I guess were talking about two different needs at the same time that are required. Past history and future expense. I will be buying from a dealership.
    It's hard to predict the future for sure. Typically if there are issues many people seem to share similar experiences, but I'm not really seeing that too much which is a good sign. However sample size is always important.
  16. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    Be aware that most of the last generation primes up for sale are already past the battery warranty as folks who buy them seem to drive immense miles every year.
    These cars also seem to be vastly overpriced selling at 100,000+ miles for virtually the same price as new.
    I was hoping “pandemic pricing “ was over but that’s only true if I want to buy a half price pickup and not a car or hybrid.
    ah well
  17. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    I remember seeing the YouTube a while ago start standard Prius and didn't need the traction batteryTo function near the end of its life. if the traction battery is not functioning, can the gasoline portion still run like a fossil carOr must the battery be replaced?
  18. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Maybe somebody found a way to get one moving around for a youtube stunt, but other than that? No... just, no.
    A Prius cannot start its gas engine without a functioning hybrid battery.
    It also cannot use its gas engine to drive in reverse. That must be done by electric power.
    A Prius is a finely balanced system. When the battery gets weak the gas engine will work a lot harder. When the battery dies completely the rest of the car is out of a job.
  19. dbstoo
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    Just a side note to supplement what Leadfoot said...
    There are circumstances where a Gen1 will travel despite having a battery with a flaw in it. Mine had a battery with one cell that was leaking. As a result there was a voltage leak to the car's frame. Despite lots of errors on the screen it was driveable to the dealer to get the battery or the cell within the battery replaced.
  20. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    Whether I get prime or a standard prius, I wanted to know is there a way to view the condition of the battery? I don't want to take the toyota dealerships word if there are other options.
    would be nice if I could take it to another Toyota dealership but I don't know if they allow that
