Disappearing coolant.
Discussion in 'Prius v Technical Discussion' started by John Traynor, Apr 24, 2024.
  1. John Traynor
    John Traynor Junior Member
    2012 Prius V with 140000 miles.
    I have a slow coolant loss with no visible spotting. Perhaps 8 oz per 100 miles. No apparent loss when garaged.
    I don’t see any signs of water in exhaust or smell any sweet exhaust. When cool, and I open the reservoir it releases pressure.
    I just had the car in the shop and the mechanic said he pressure tested the coolant system and didn’t detect any leak with the exception of a potential slow leak in the reservoir. He replaced the reservoir (for $400
    I just drove 100 miles and noticed another small drop in the coolant level, so I suspect he took the easy answer and cashed me out.
    I have concurrently noticed rough idle which I had thought as related to a bad injector. I am beginning to suspect a failing water pump is leaking coolant into the crank case.
    Next step is to check the oil level and oil consistency to see if oil looks milky or over filled.
    any suggestions?
  2. Danno5060
    Danno5060 Active Member
    382
    199
    Wyoming
    Maybe temporarily take the plastic cover off of the bottom of the car. If the coolant is leaking onto that, it might be harder to spot.
  3. BiomedO1
    3,342
    1,746
    SacTown, Ca
    rough idle could also mean poor mixture (ie. bad injector, plug, ignition coil, poor compression). Pull the spark plugs and look for signs of incomplete combustion or steam cleaning. All 4 should be uniform, the wet or discolored one is the misfiring cylinder. If you can get a bore scope, you can also check for head gasket issues.
  4. bisco
    51,687
    most likely a very small leak in the head gasket, very common. keep the coolant filled and track down the problem before it blows and kills the engine.
  5. rjparker
    9,974
    6,170
    A very rough idle on startup, usually after the engine has cooled off, followed by smooth running and some coolant loss is typically the mid point of a coolant into the cylinder head gasket leak. Because the issue will quickly clear there are often no codes at first. Later misfire codes will randomly occur across various cylinders. A dual view borescope inspection can be further proof.
    If the engine burns oil, which is also common, a hg problem should be solved with a rebuilt engine and updated pistons and rings. Otherwise a head gasket and rebuilt head is recommended if you can find a shop that will do it. Many won’t because of early repeat hg failures costing them money.
    A bad plug, coil or injector will continue and not clear up after a cold start. Codes are common. These won’t cause coolant loss.
    If it was idling rough and not clearing up, again without obvious coolant loss, it could still be very early hg failure or a sticky egr valve allowing exhaust flow into the cylinders at idle. A sticking egr is not as common and would throw a P0401.
    Combustion gas in the coolant tests, water in the oil, compression and leakdown tests usually won’t detect a Prius hg leak until an advanced stage when white coolant smoke comes out the tailpipe. By then the engine is shaking and rattling with every off cycle such as at stoplights.
    #5 rjparker, Apr 25, 2024
