Do we have to buy the bearing and hub seperatly?
Discussion in 'Prius c Main Forum' started by Syed Ashar Ali, Apr 25, 2024.
  1. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    83
    Houston, TX
    2014 Prius c
    I saw for the rear it comes as an assembly.but for the front I can't find the complete wheel bearing kit.
    I have the Dorman front wheel hub.
    930-413
    And I have the Drivestar front bearing
    510094x2
    I have both front for the left and right side. Will ask my mechanic to replace it. But my question is will these work? Or am I missing any other parts that I need to order?
  2. ChapmanF
    17,748
    Edit: caution: I don't have a Prius c, and what I'm saying here is about gen 1 through the gen 3 liftback.
    Toyota uses a one-piece hub/bearing unit in those cars. It is not sold as separate pieces, and isn't even intended to come apart into separate pieces.
    I suppose if you are buying aftermarket, the story could be different. From the photos of the parts you have ordered, it does look as if the Dorman part is only the inner hub, the Drivestar part is only a bearing, and you will have to hope that disassembling the original equipment hub/bearing unit will leave you with something this aftermarket bearing and hub will fit in.
    But once again, I don't have a c. It's quite possible the c is actually designed to use a separate bearing unit and hub like that.
  3. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Yes because one time I got a rear assembly wheel bearing for the rear side of the prius c. And it was easy to install for the mechanic. Next day I wanted to do the front. I bought only the bearing and when he took off everything from the front he said "you need the complete assembly it won't go in like that with just the bearing." so that's why I was curious if this is all I need for the front
  4. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    I've only done a rear bearing on our car, wish I could help.
  5. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Does the prius c bearing ever go bad? Front?
  6. BiomedO1
    3,145
    1,667
    SacTown, Ca
    In my experience, only if the car's been in a collision or you've got very very high mileage. I've had really good luck with original OEM Toyota bearings. Then again, I'm a if it ain't broke or humming - why fix it, type of person.
  7. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Type in 204605577600 for the item number. It's a scion car wheel bearing. On ebay it is saying it will fit the front left side. Can someone please tell me if this part will fit before I buy it?
  8. Syed Ashar Ali
    83
    Houston, TX
    2014 Prius c
    Type it in Google preferably
  9. BiomedO1
    3,145
    1,667
    SacTown, Ca
    IMHO; I'd go with a new OEM assembly to avoid future issues. There's many Prius on the road with over 200K miles on the clock and the original OEM bearings still in them.
  10. Leadfoot J. McCoalroller
    8,009
    7,484
    Pennsylvania
    2018 Prius c
    ^ I strongly support that. I just replaced a rear bearing in our car, about 5500 miles after I paid somebody else to replace it. He did not use a Toyota part, and it went bad fast.
    I used a Toyota part.
    BiomedO1 likes this.
  11. elsabeth
    elsabeth New Member
    singapore
    Ensure that the Dorman hub and Drivestar bearings are compatible with your specific vehicle make and model. From the part numbers, they generally fit a range of vehicles, but confirming they match your car's specifications is crucial. You may need the Wheel bearing seals, Axle nut and Retaining clips or snap rings.
