WTH: black box ???
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ccna101, Apr 27, 2024.
  1. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    During the time that I am fishing around for a good fuse to tap into, I found this box just under the driver side ...
    Can anyone know what they are ? and before you ask, no, I do not own it and previous owner is passed away so no...
    The location is tie to a self driving or whatever they called it back in the day .
    TIA,
  2. dolj
    dolj Senior Member
    8,502
    4,314
    Wellington, New Zealand
    I have no clue but I can tell you it is not OEM. Maybe google the manufacturer and model that you can see on the label.
    The box it is tied to is the Navigation DVD reader. Not sure whether all of the GPS function is driven from here also, but probably.
  3. bisco
    52,263
    looks like big brother is spying on you :p
    ccna101 likes this.
  4. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    Ya, it is barebone 2007 Prius Base with nothing (no DVD, no nav, ... ) ... I havee to remove it and I really don't want to mess with it unless I know for sure ...
    darn - black box for sure, send all of my whereabouts back to Mars ?!!!
  5. bisco
    52,263
    could it be a lojack type of thingy?
    ccna101 likes this.
  6. ChapmanF
    18,435
    Slide the zip ties a little bit so they're not covering up the company address, product name, and model, and you're probably one short google away from what it is.
    ccna101 likes this.
  7. Brian1954
    Brian1954 Senior Member
    2,362
    949
    South Central PA, USA
    I did a search and found ejward.com .
    Is the device connected to the OBD2 port?
    It is some type of device that can capture data like odometer, acceleration, braking, idle time. VIN, GPS, MPG, etc. It looks like the data can be transmitted wirelessly. The device is usually installed in a company car to track its usage.
    #7 Brian1954, Apr 27, 2024
    ccna101 likes this.
  8. rjparker
    10,400
    6,515
    ccna101 likes this.
  9. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    darn, I think this is ... I will try to jiggle and uncover the sign ..
    It will be a while ... I am back home and the car is 600+ miles away ... I will update.
    Thanks ya all !!!!
  10. bisco
    52,263
    sending your driving habits to your insurance company...
  11. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    yes, seriously : It one of those thing on my list to remove ASAP.
  12. ccna101
    ccna101 Member
    122
    29
    SFO/IAD/DCA
    2020 Prius Prime
    From the remove/disconnect standpoint, I am looking at something similar to this :
    1. One end of RS232 daisy to my OBD2 which I can unplug.
    2. The other end: perhaps another RJ9 with some crimping connections for power, and ... ? I really want to remove any external GPS if there is, but tracing non OEM wires can not be fun :( ....
    I am not looking forward to this, but perhaps spring clean up time .:unsure:
  13. ColoradoCrow
    ColoradoCrow Senior Member
    1,108
    464
    Leawood, KS
    I
    I also had one of those in my Prius. I removed it as well. It was ina security vehicle that the officers had to swipe there rfid on the dash to activate the car to start and end their shift.
