How do I change inverter coolant fluid 'without bleeding' the system?
Discussion in 'Gen 2 Prius Main Forum' started by ski.dive, Apr 30, 2024.
  1. ski.dive
    ski.dive Active Member
    963
    242
    Hutchinson Island,FL. Mt. Snow,VT
    Is there an easy way to bleed the system?
    #1 ski.dive, Apr 30, 2024
  2. Tombukt2
    12,808
    2,303
    No bleeding just drain n fill let run till pump stops sounding like air . Then level the jug n go.
  3. Mendel Leisk
    41,125
    From the Repair Manual, engine and inverter coolant change instructions attached.
    Also, per your other thread, transaxle fluid "inspection" attached. No mention of changing the fluid, but has some helpful pics and bolt torque spec, at least for the fill bolt. FWIW, the drain bolt on 3rd gen is 29 ft/lb. For some general tips, see also the transaxle fluid change link in my signature (on a phone turn it landscape to see signatures).
    #3 Mendel Leisk, Apr 30, 2024
  4. Danno5060
    Danno5060 Active Member
    382
    199
    Wyoming
    I did this
  5. pasadena_commut
    pasadena_commut Senior Member
    2,529
    754
    Southern California
    Preceding post is for burping the engine coolant, not the inverter coolant.
    For the inverter:
    Fill reservoir to mark.
    Attach a clear plastic tube to the bleed valve for that loop and place the other end in the open reservoir.
    Open the valve.
    Turn on the car.
    Fluid with bubbles will move through the tube.
    When there are no more bubbles close the valve.
    Turn off the car.
    Remove the tube and close the reservoir.
    Note, clean up any drips around the bleed valve thoroughly. Otherwise it might look like it was leaking there after the coolant dries up and crystals form.
  6. Danno5060
    382
    199
    Wyoming
