Prius V 2013 - Swaybar bushing and links - torque specs
Discussion in 'Prius v Technical Discussion' started by JoqJoSain, May 1, 2024.
  1. JoqJoSain
    JoqJoSain Junior Member
    Finland
    Hello, i was searching but couldn't find any info for the Prius V 2013 - sway bar bushings and links torque specs.
    Anyone know the torque specs for such operation?
    I'm changing the bushings and the swaybar links.
    Thank you, any help much appreciated.
  2. Air_Boss
    Air_Boss Senior Member
    4,197
    1,183
    New Yawk
    55 ft-lbs for front end links. Bushing covers are in the 15 ft-lb range.
