Gen 5 Prime XSE Premium - Adding a powered subwoofer to the JBL system and need advice
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Rordon Gamsay, Mar 17, 2024.
  1. Rordon Gamsay
    Rordon Gamsay New Member
    Alabama
    2024 Prius Prime
    XSE Premium
    2024 Prius Prime XSE Premium, peeled the driver's seat back and removed a plastic cover to gain access to the JBL amplifier.
    I want to add the JBL Basspro SL2 under my passenger seat
    Guides online say to tap into left and right signal wires for the high level input, but super confused on which wires I should tap into. Does anyone know which wires I should tap? I included pictures of the wire harnesses in the car
    Or is there any way to use the empty harness connector?[​IMG][​IMG][​IMG]
    [​IMG][​IMG]
    otatrant likes this.
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Leftmost connector. Bottom row. Starting from the right.
    Violet - Ignore
    White - Left Rear -
    Black - Left Rear +
    White - Right Rear -
    Black - Right Rear +
    Yellow - Ignore
    That should be what you need.
  3. kellyj
    kellyj Junior Member
    43
    22
    Orlando, fl
    2019 Prius
    Was there room for this and do you have photos? where did you get power for amp, etc?
    broderp likes this.
  4. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    You want to tap the front doors, they're are the only ones that get a full signal. The rear doors do not get much if any bass signal. I used a jumper harness so I didn't have to cut the factory wiring.
    broderp, otatrant and pascalvin like this.
  5. pascalvin
    pascalvin Junior Member
    2024 Prius Prime
    XSE Premium
    Do you by chance have a link for the jumper harness you used? Is the jumper harness long to reach all the way to the back or is the subwoofer's cable long enough to reach the back from the jbl amp jumper harness under drivers seat?
  6. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    pascalvin and otatrant like this.
  7. o_intent
    o_intent Junior Member
    55
    2023 Prius Prime
    XSE Premium
    This notion got me curious. Have you always noticed that your system was front speakers biased?
    I was driving and listening to '23 Prime XSE Premium with the JBL for 4 months, and it was very well balanced, with most of the bass coming from both the Fronts and the Rears. In fact, going to JBL's website would correlate this.
    Now the only speakers that would be present are on the front doors, while the rest seem like they've been turned down to 10%
    Just curious if that's what's causing most to want to add a subwoofer. This system according to the manufacturer was supposed to be 800 WATTS!
  8. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    The front doors are doing most of the work. The rears sound like they have a high pass crossover and a db cut. The system as stock has pretty good mid-range punch but lacks low bass < 100hz. That 800w total peak rating is just fluff, I would guess its really 5-15w RMS per channel tops.
  9. soft_r
    soft_r Active Member
    184
    152
    Beverly Hills
    2024 Prius
    Toyota seems to do the weak rears across a lot of their vehicles, even the 5th Gen Prius.
    Park your car.
    Open your front door and your rear door.
    In your head unit under sound tuning move the dot to the front so that sound is nearly exclusively coming from the front speakers.
    Listen to the front door audio. Feel how the bass kicks. Listen to how loud it is.
    Now back to the head unit and move the dot to the rear.
    Go listen to the rear door speaker. Loudness? Not at all. Bass? None.
    Maybe they changed it on the JBL upgrade but stock, the rear feed is trash. Same speakers as the front, it's the signal that's the issue. You can see it with a multimeter if you removed the panels and tapped the speaker leads.
  10. o_intent
    55
    2023 Prius Prime
    XSE Premium
    I don't know how to convince you, when I can't even convince the guys at the dealership. While there I managed to have 1 guy in management on my side, and we listened to both the base LE/SE system, along with another JBL equipped Prime. The base system is indeed trash, to the point he used the term "embarrassing" that they came like that, while the JBL was marginally better, but still nothing like how I remembered it.
    Would you believe it if I told you that, what you're describing, and your perception of the system now, isn't how it was for me? I drove the car for 4 months, and throughout that time, while the system wasn't the best, it was acceptable. It was fairly tight and loud, until all of a sudden it wasn't, WHILE I was driving.
    A week after posting my issue with my volume dropping, I went over to listen to a RAV4 Prime's system equipped with a nearly identical setup to ours. Sure enough, it was noticeably tight and loud . Now fast forward to April 22, 2024 I went back and the system was completely neutered. My friend was even baffled! Whatever the issue is, it is software, and it has migrated.
    Soft_R, by the same rationale, next time you go back to your car, try this...
    Have all your speakers CENTERED, and while you're listening, move your fader to the FRONT. If you sense absolutely no changes like I have, then clearly the system is faulty, as that's contrary to how a fader function is supposed to operate, then why bother coding it in to the interface at all.
    *just a thought* I've been going under the assumption you're working with the Limited/XSE Premium JBL audio system, otherwise we're talking about two completely different product
  11. soft_r
    184
    152
    Beverly Hills
    2024 Prius
    Not sure if you misunderstood but let me be clear...
    The front output CHANNELS (the signal) from the headunit give a different signal than what goes to the rears. This happens across many Toyota vehicles. Like the Tacoma: Low volume in rear speakers | Tacoma World more here toyota tacoma rear speaker volume site:www.tacomaworld.com - Google Search
    It's nothing new at all. And I really doubt they changed that on the JBL.
    And to be extra clear, it's not the speakers, it's the signal. I bridged my front door and rear doors when I redid my audio upgrade, wiring my the speakers in parallel which reduces the impedance to 2Ohm, and now my rears have much improved sound. Of course I lost front/rear fade doing this but I'd rather have a better listening experience for those in the back seat.
    Oh look, more people talking about Toyota's weak rear signal and this time on the JBL platform: fixing the rear speakers in the JBL system | Toyota GR Corolla Forum - Ownership Discussion
    If you guys just do a little reading first it'd save so much time.
  12. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Sounds like there was an issue with the amplifier in that car. I've have the Jbl and did not observe any change in the output over the last 14mo.
    @soft_r : You are correct the jbl similarly does not give much signal for the rear door. I have also witnessed this in other Toyotas.
    o_intent likes this.
  13. o_intent
    55
    2023 Prius Prime
    XSE Premium
    I appreciate your inputs, sounds like you know your way around car audio. With that said I'm also trying desperately to not make this sound like a pissing match, because we are here to learn from and help each other after all.
    While I'm struggling with an audio problem not relating to this, I could not wrap my head around how you think this problem is NORMAL. I assume you know what a fader function is, and by extension what purpose it serves?
    My '17 Corolla is balanced across all 4 main channels when centered. I know this, because I just changed out a pair myself . And to make this simple, so has every vehicle we own, and every one I have heard. Every basic to advance aftermarket head-unit has had something plastered across like 45W x 4 or something to that affect. Since when has Toyota audio systems start doing this 80% front 20% rear business?
    The vibe I'm getting from Soft_R is that this is normal, it is known, and Toyota owners should just shut up?
  14. pascalvin
    2024 Prius Prime
    XSE Premium
    Not at all, if anything as a consumer we should complain to Toyota to get them to change their tune
    But as far as the actual hardware that came with our gen5s, we're kinda stuck with whatever signal the head unit outputs. It has no bass frequency in the rear speaker signal, and I hate it. It's been like this since day1 for me, as well as during my test drive (sales guy's personal car)
    I added a Beat-Sonic ENA-2T3 on mine to clean the signal and boost the rear a bit since the front drowns it out. Then I'm probably going to follow PhoS and add a jbl basspro nano to round it out. Was really hoping for a full plug/play solution for the sub though
  15. o_intent
    55
    2023 Prius Prime
    XSE Premium
    Rordon Gamsay, it's been well over a month, what's the status chef?
    Looking at the available space I have under the passenger seat, it looks like there's about a 2-inch clearance at it's narrowest point. Did you manage to stick with that plan of installing it there?
    In other news, I spoke with a buddy who installed the JBL Basspro Nano under the seat of his Gen4 Prime (haven't listened to it yet).
    He says even though it fits, and the bass was adequate, the rattling of his seat at most level drives him nuts, and he wishes he hadn't done it. I'll probably be helping him relocate it to the rear at some point then.
  16. o_intent
    55
    2023 Prius Prime
    XSE Premium
    Hammersmith,
    By chance do you know if the two pairs of whites and greys for the FRONT CHANNELS are present in that connector? it is a bit hard to tell.
  17. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    There should be no gray wires in this connector. The other connector has four pairs of Lavender/White Stripe and Solid White, but those are the power feeds to the speakers and not the signal feeds to the amp.
    I don't know if this is going to make a ton of sense, but here are all the channels. I've tried to include all the info you'd need to find any input or output to and from the amp. The only applies to the JBL 8-channel audio system. I only labeled the (+) out of each channel; obviously you also need the (-), but it's a little clearer to read with only one of the two labeled.
    Code:
    From head unit to amp(signal) - not certain what the FB channels are for
    FB1+   Black   10
    FB1-   White    9
    FB2+   Red     22
    FB2-   Green   21
    FR+    Black    5   Front(right)
    FR-    White    4
    FL+    Red      3   Front(left)
    FL-    Green    2
    RR+    Black   17   Rear(right)
    RR-    White   18
    RL+    Black   15   Rear(left)
    RL-    White   14
    24 pin rectangular connector
    1  2  3  4  5  6  7  8  9  10 11 12
    13 14 15 16 17 18 19 20 21 22 23 24
    1  - Blue               12 - Violet
    13 - ???                24 - Light Green
    From Amp to Speakers(power)
    FR+    Lav/Blue    14   A Pillar(right)
    FR-    Lav/White   29
    FL+    Lav/Green   12   A Pillar(left)
    FL-    Lav/White   27
    RR+    Black       15   Rear Door(right)
    RR-    White       30
    RL+    Blue        13   Rear Door(left)
    RL-    White       28
    WFR+   Lav/Black   10   Front Door(right)
    WFR-   Lav/White   25
    WFL+   Lav/Red      8   Front Door(left)
    WFL-   Lav/White   23
    TWR+   Red         11   Dash(right)
    TWR-   White       26
    TWL+   Red          9   Dash(left)
    TWL-   White       24
    30 pin strange shape connector
    1  2  3  4  5  6  7  8  9  10 11 12 13 14 15
    16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
    1  - Red                          15 - Black
    16 - Green                        30 - White
    o_intent, pascalvin and otatrant like this.
  18. o_intent
    55
    2023 Prius Prime
    XSE Premium
    It makes sense to me!
    I'll try to verify if those FRONT line ins are indeed pre-amp and are meant to go to the front (when I get around to doing mine.) Thank you much!
    Shout out to PhoS for the reminder that the fronts might be the only ones getting the full-range signals.
    PhoS likes this.
  19. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I gave him the wires for the rear outputs because that's what the instructions for the subwoofer said to use. But I tested my own sound system today and agree with those that say there's a problem with the JBL settings. If I were asked the same question today, I would recommend using the front outputs instead of the rear.
  20. Rordon Gamsay
    Alabama
    2024 Prius Prime
    XSE Premium
    Hey all, figured I should share what I ended up doing!
    For a while now I've had the Beat-Sonic ENA-2T3 Amp behind my head unit. I ordered the BH10 speaker harness for signal outputs so that I wouldn't have to mess with the factory wiring. For my subwoofer I went with the Kicker 11HS8 Hideaway and installed it behind the passenger seat with Velcro strips. I did end up using the front outputs for the signal. As a classical music listener I'm even more in love with the way my car sounds now.
    To o_intent, I definitely noticed the problem with the rear speakers getting very little signal. With the Beat-Sonic amp I turned the rear gain all the way to max which makes it better, but is still quieter than the fronts.
    [​IMG] [​IMG]
    #20 Rordon Gamsay, Jul 13, 2024
    otatrant, Julio_E and soft_r like this.
