Safety Recall Rear Doors
Discussion in 'Gen 5 Prius Main Forum' started by exbauer, Apr 17, 2024.
  1. Trollbait
    12,501
    I was able to manually unlock my driver's door of the Outback on the highway. Didn't think to check if it would lock again after slowing below 5mph and speeding back up.
    The conditions for when or if the doors auto lock and unlock were all adjustable in the settings menu of the last three cars I had(GM, Toyota, and Subaru).
  2. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    The service manager at my local dealership told me they haven’t received an update regarding the timing of fixing the vehicles that were mid production or on the way to dealerships. He said US car manufactures typically let the cars arrive and fix them afterwards and Toyota typically takes care of production before the recall unless it’s super serious like brakes etc. He also checked on tire inventory due to my curiosity and said he can get replacement 19” tires within a week but it’s a special procedure due to shortage. Hmmm…
  3. bisco
    51,836
    they'll say anything to make a sale. then when you actually need a tyre...
  4. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    That was the default on our '23. Shift into reverse or drive and the doors lock. I think it is changeable in one of the settings areas, but I have no desire to reset it.. As I read it, that is a good work around. Just don't change the default settings on door locks (or put them back if you did).
  5. UmpireRips
    UmpireRips Junior Member
    Colorado
    2024 Prius Prime
    Would be possible for you provide the source of the data on the significant number of deaths in Teslas due to doors not opening? I would like to see it. Thanks
  6. AndersOne
    AndersOne Active Member
    334
    194
    Europe
    2023 Prius Prime
    Im not sure about English sources, but here is a translated article thats speaks of 4 (confirmed?) cases so far since 2018
    Handelsblatt
  7. flim
    flim Active Member
    251
    173
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    I just received my Safety Recall Notice (Interim Notice) by snail mail from Toyota.
  8. aforkosh
    aforkosh Active Member
    413
    272
    Oakland, CA
    2023 Prius
    So did I.
  9. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    Car was in for its first regular service today - was expecting them to ask about or insist on pulling the fuses as per the interim recall for Europe (we don't have auto-locking), but they said the fuse removal notice was cancelled today, and the real fix is now available. Booked a time for it next month.
  10. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    Thanks for the information. Maybe in the US soon?
  11. Hammersmith
    Hammersmith Senior Member
    2,296
    2,306
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Man, I hope so.
  12. Zeromus
    Zeromus Active Member
    552
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    I was in last week for an early oil change and 6 month service. I was told there was no news here in Canada.
    (and before anyone asks why have them do the early oil change - I have a 3 y/o and an 8m/o, a lot of laundry and whole host of other chores to do. For $40 more, I was able to have them do it for me while I was able to keep working from my laptop)
  13. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
    Great info!
    Do you know if you have a TSB/number/'code' or anything? I know you're in Europe, but was just wanting to provide something to my dealer.
  14. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    Perhaps if you all don't have auto locks on the back doors those have been fast tracked for repair???
  15. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    I'm just hoping they don't tear up the rear interior doing the fix. I will be taking before pictures just so they can't say there was pre-existing damage.
    daisy555 and bisco like this.
  16. CD-Ever
    CD-Ever New Member
    British Columbia
    2024 Prius Prime
    XSE
    Last week I found this vlog showing the fix applied for Priuses in Japan.
    (check out 3:52 - 4:46)
    It would be indeed required to tear up the rear interior. The service takes around 60 - 90 mins. There are also pictures comparing the new and old rear door handle component.
    villageidiot2, soft_r and Yvrdriver like this.
  17. Yvrdriver
    Yvrdriver Member
    47
    42
    Vancouver
    interestingly, this youtube channel posted another video about the 12v battery issue...i'll post the link in the 12v battery thread
  18. Sharol
    Sharol Member
    161
    76
    Kansas, USA
    2023 Prius
    I don't think I want my car to be the first that the dealership repairs with this. Maybe let them practice on someone else's baby first.
    daisy555, bisco and Gwyd like this.
  19. Gwyd
    Gwyd Member
    113
    78
    NE Florida
    2023 Prius
    Agreed!
    I'm going to put it off as long as possible since the car locks automatically when in Drive. I don't feel there's any real danger as long as the door is locked and I don't have kids that would try to unlock it.
  20. KMO
    KMO Senior Member
    1,947
    676
    Finland
    2023 Prius Prime
    I see two bulletin IDs listed in the Toyota-Tech system:
    * 024SD-052 R/SSC - for Rear Door Outside Handle on certain Prius
    * 024SD-046 PDC & RSSC - for Rear Door Outside Handle on certain Prius
    024SD-052 is the fuse removal bulletin from April. I can't find the text for 024SD-046, but presumably that must be the real fix.
    Hotdog453 likes this.
