12v battery question
Discussion in 'Gen 2 Prius Main Forum' started by alanf52, May 2, 2024.
  1. alanf52
    alanf52 New Member
    St. Louis
    Hey everyone!
    I need to replace my 12v battery. I saw there was a lot of back and forth about Everstarts. Is the Everstart Platinum the same thing as the Maxx?
    Will this fit in a 2nd gen Prius (2008)? I'm asking bc it says it's a 46 and will fit. Doesn't the prius take a size 51.
    Basically will this battery fit and do people recommend it?
  2. alanf52
    alanf52 New Member
    St. Louis
    Is this the same quality as an OEM?
  3. Tombukt2
    13,056
    2,340
    I think that's the right factory number or the battery number. I've seen a few of these in cars I don't know that they're any better than anything else there's no goal standard of 12 volts like there used to be in the old days they're all pretty crappy now I don't know why a lot of things are pretty crappy right now Not sure why because manufacturers are allowing it whatever I don't know I tend to buy the Sears It's a blue and white silver looking label AGM I think it's their gold battery I don't know some people are using universal batteries and fire escape flood light batteries all kinds of nonsense so it's not really mission critical the cheaper the better as long as you can get a couple years out of it You're pretty much golden The days of not doing anything for 7 years or probably a little behind us seems like batteries regularly failed these days.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    The battery in your post is the correct battery for your car. It has the Japanese "JIS" size terminals and is an AGM style battery with a vent hose connection.
    A group 51 battery has standard size terminals and will NOT fit your cables, it is also a wet cell battery and has no vent tube connection.
  5. alanf52
    alanf52 New Member
    St. Louis
    Thank you so much!!
  6. alanf52
    alanf52 New Member
    St. Louis
    Thank you so much!
    I went to AutoZone and they said the battery I had just needed to be recharged. I'm doing that for now and hopefully it holds up for a while. (At worst, they charged it for free and I wasted a couple of hours today.)
  7. Tombukt2
    13,056
    2,340
    Yes generally this is what most folks would find themselves doing first and then worry about model battery numbers and terminal tops fitting and all that perfect.
  8. ski.dive
    ski.dive Active Member
    964
    244
    Hutchinson Island,FL. Mt. Snow,VT
    Where can I buy this EVERSTART BATTERY?
  9. Brian1954
    Brian1954 Senior Member
    2,250
    889
    South Central PA, USA
    #9 Brian1954, May 3, 2024
  10. alanf52
    alanf52 New Member
    St. Louis
    Thank you! I also bought a battery tender (maintaner) and will keep checking on it and charging it periodically.
    (I'm new at this and learning as I go.)
    Thank you for all your help!
    Tombukt2 likes this.
