identify part
Discussion in 'Gen 2 Prius Main Forum' started by bugmenot, Dec 29, 2006.
  1. TheForce
    3,461
    537
    Wheelersburg, Ohio
    Does it have a part number stamped on it?
  2. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    <div class='quotetop'>QUOTE(bugmenot @ Dec 31 2006, 04:31 PM) [snapback]369041[/snapback]</div>
    So no-one admits to putting it there? This is like playing Clue!
    I say Professor Plum did it in the garage with the plastic bracket ...
  3. bugmenot
    bugmenot New Member
    93
    I don't have the part on me, but there's no part number that I can remember seeing.
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I know! It's that dohickey that plugs into the watchamacallit. :)
  5. netgooroo
    netgooroo New Member
    if no one has told you yet, it's the seat belt dealy that goes into eather the seat or up by the door.. help keep the seatbelt on track.. ;)
  6. bugmenot
    bugmenot New Member
    93
    There's no part on the seat belt assembly that looks like that.
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    I'm with the idea that it's part of a kid's car seat...could the car have been taken for a test drive or did you get it fresh off the truck? Could someone have been checking for fit of a car seat? That's exactly what it looks like.
  8. bugmenot
    bugmenot New Member
    93
    The car was still in plastic when I received it. Is there a similar picture for comparison?
  9. PA
    PA Member
    427
    27
    Raleigh, NC
    2019 Prius
    Oh, so it was found in a brand new car? Now I see why you're so concerned.
    God I love a good mystery .... :)
  10. bugmenot
    bugmenot New Member
    93
    Brand new. Because the part looks a little dinged, I thought an employee removed it and forgot to put it back.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Maybe it is not a Prius part at all? Some one dropped in the car at some point. I went over the seat belt and it does not look like it fits there at least not on my car. The sales person that attached my plates for me grabbed Ford attachment bolts and then made them work ( a Ford Toyota dealership) ! The service department replaced the front licenses plate holder. Luckily the rear bolts were in place. There was some muttering under the breath by the service people about sales people being allowed to touch a tool at any time! :lol: PC will figure this out I am sure! What fun for New Years. Almost as good as red beans and rice! B)
  12. hill
    8,897
    <div class='quotetop'>QUOTE(cbs4 @ Dec 30 2006, 01:03 AM) [snapback]368505[/snapback]</div>
    Perhaps, as a dude, I shouldn't know this. 1,200 count thread, according to my wife though, is mearly 600 count with 600 'doubled over' threads twisted together. So 600 threads per inch is realisticly, the max. That being said, yes, you did give a nice illustration. But as to what the gromet goes to? Unknown.
    Pragmaicly, gromets prevent the inside thingie from rubbing on a surface rougher than the rubber itself. So check around for wire clusters, etc.
  13. bugmenot
    bugmenot New Member
    93
    As long as my car doesn't fall apart with this piece, I won't worry too much.
  14. sl7vk
    sl7vk Member
    518
    Salt Lake City
    <div class='quotetop'>QUOTE(bugmenot @ Jan 2 2007, 05:35 PM) [snapback]369712[/snapback]</div>
    I think that part holds the entire rear axel together..... :eek:
  15. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(sl7vk @ Jan 2 2007, 07:24 PM) [snapback]369787[/snapback]</div>
    Priceless. The next time you are at the dealer have some fun and ask around. If Parts and Service don't know ask the Ford guy.
  16. nicoss
    nicoss New Member
    304
    Maybe it is for the recessed handle inside the hatch.
    Open the hatch and look up and to your right.
  17. bugmenot
    bugmenot New Member
    93
    I use that handle everyday, and it's definitely too small to be it.
  18. Ghostrider
    Ghostrider New Member
    121
    I am not sure at all but go look at your door where the wiring harneses pass thru and see if that is it. it could not fall out with the wire going though it but might have been dropped inside the car during assembly
  19. member
    member New Member
    197
    I'll take a picture of our child seat grommets this weekend and post them, or die trying.
  20. bugmenot
    bugmenot New Member
    93
    It's not part of the wiring harness on the door. Those are also circular.
