Has anyone found a rear deck protector?
Discussion in 'Gen 5 Prius Main Forum' started by mark fassett, May 7, 2024.
  1. mark fassett
    mark fassett New Member
    2024 Prius
    My LE has had some damage from removing heavy things from the rear cargo area. Has anyone found a plastic protector for this?
  2. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Coming from a farm, we usually use plywood. Easy to cut and fit, and fairly inexpensive. If you don't like the color, I guess it could be painted.
    You can also buy mats made of recycled rubber tires, which are fairly inexpensive as well.
  3. daisy555
    daisy555 Senior Member
    1,715
    708
    CT
    I saw an antique dealer using multiple thick moving blankets. He said they’ve saved his car multiple times. Obviously depends how heavy your cargo is.
  4. PriusCamper
    PriusCamper Senior Member
    12,736
    5,152
    Pacific Northwest, USA
    What do you mean by "rear deck" ?
    Are you referring to the bumper cover on the outside, or the plastic on the inside?
    If its the Bumper cover on the outside... Just mask it off and spray black plastic-dip spray paint. You can spray it on real thick in multiple coats and peels off fairly easy when its time for a refresh.
    If you're talking about the inside of the car, follow advice from people above.
  5. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    Weathertech makes a liner for the cargo floor.
  6. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Laser measured no less.
  7. o_intent
    o_intent Junior Member
    55
    2023 Prius Prime
    XSE Premium
    Are you referring to something to protect the upper part of the rear bumper from getting scratched?
    like this rear bumper applique. Part #: PT929-47230
    Currently the only thing available, hardly worth the price for what little protection it gives. I've got 3M PPF tape I was going to cut and install myself, just haven't gotten around to it. What I think we're all waiting for is an actual bumper cover/protector.
    daisy555 likes this.
  8. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    $166 it better be perfect.
  9. BiomedO1
    3,573
    1,853
    SacTown, Ca
    Mine included the carpeted trunk mat but I prefer something I can wipe/hose off, if I get a minor spill or throw muddy stuff in the back.
    Cargo Trunk Floor Mat Liner Fits Toyota Models All Weather Semi Custom Fit Black | eBay
    Got one of these and let it bake in the sun for a few days. It had a weird chemical / plastic smell when it arrived, so I let it bake-off. Didn't want the smell getting into my upholstery. It was big enough for me to create one inch walls on 3-sides. Could've did the trunk lid side also but didn't want to chance the latch hanging-up or jamming.
  10. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    I'm forgetting the cars that come with the all weather mats include one for the cargo as area well. PN: 9084723520
  11. radsaq
    radsaq Junior Member
    28
    Virginia, USA
    2024 Prius
    The all weather mat set also include two covers for the back of the rear seats; is there a separate part or parts for those?
  12. PhoS
    PhoS Active Member
    253
    206
    Nowhere
    2023 Prius
    Limited AWD-e
    Mine have both of these PNs on them.
    PT908-47235
    PT908-47236
  13. Mendel Leisk
    41,406
    Gen 3 style:
  14. mark fassett
    2024 Prius
    I was thinking of something more like the gen3 style example directly above... that black plastic which would completely save the bumper cover from being chipped etc from cargo. It doesn't seem like anyone makes such a beast?
