2022 adaptive cruise control not reliable?
Discussion in 'Gen 4 Prius Main Forum' started by SteveK2024, May 7, 2024.
  1. SteveK2024
    SteveK2024 New Member
    2022 Prius
    I noticed that adaptive cruise control does not slow down sometimes when the car in front slows down.
    Is this a known problem with cruise control or is it defective in my car? It works fine most of the time. I see this problem only sometimes. Could the sensor in front Toyota logo be bad?
  2. sylvaing
    sylvaing Senior Member
    1,210
    514
    How's the weather like when it doesn't slow down?
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Have never seen this in our 2016. Dynamic CC has always worked safely.
  4. sclevine
    sclevine Active Member
    167
    160
    Northeast Florida
    2024 Prius
    Have not seen this either in my 2017 or my 2024. If anything, it errs on the side of slowing down when it doesn't need to.
    Diablo6vct likes this.
  5. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    Are you sure it is in adaptive mode, and not simple cruise mode where it would normally not react to a slowing leader?
  6. Doug McC
    Doug McC Senior Member
    1,080
    420
    Midwest
    2022 Prius
    Haven’t had any issues with our 2022 Nightshade Edition XLE. What are the ambient light conditions when it happens or possibly the shape of the vehicle in front of you?
    EDIT: pages 335 and 336 in your Owners Manual list quite a few conditions that will cause the system to not respond “correctly”. Several of them could easily be a fairly common occurrence IMHO.
    ■ When the sensor may not be correctly detecting the vehicle ahead
    In the case of the following and depending on the conditions, operate the brake pedal when deceleration of the system is insufficient or operate the accelerator pedal when acceleration is required.
    As the sensor may not be able to correctly detect these types of vehicles, the approach warning (P. 331) may not be activated.
    ●Vehicles that cut in suddenly
    ●Vehicles traveling at low speeds
    ●Vehicles that are not moving in the same lane
    ●Vehicles with small rear ends (trailers with no load on board, etc.)
    ●Motorcycles traveling in the same lane
    ●When water or snow thrown up by the surrounding vehicles hinders the
    detecting of the sensor
    ●When your vehicle is pointing upwards (caused by a heavy load in the luggage compartment, etc.)
    ●Preceding vehicle has an extremely high ground clearance
    ■Conditions under which the vehicle-to-vehicle distance control mode may not function correctly
    In the case of the following conditions, operate the brake pedal (or accelera- tor pedal, depending on the situation) as necessary.
    As the sensor may not be able to correctly detect vehicles ahead, the system may not operate properly.
    ●When the road curves or when the lanes are narrow
    ●When steering wheel operation or your position in the lane is unstable
    ●When the vehicle ahead of you decelerates suddenly
    ●When driving on a road surrounded by a structure, such as in a tunnel or on
    a bridge
    ●While the vehicle speed is decreasing to the set speed after the vehicle accelerates by depressing the accelerator pedal
    #6 Doug McC, May 8, 2024
  7. SteveK2024
    2022 Prius
    Yes, because it works most of the time and accelerates/decelerates correctly.
  8. SteveK2024
    2022 Prius
    Thanks for sharing this list. I'll check next time if any of these situations cause it to not work.
    Doug McC likes this.
  9. BiomedO1
    4,086
    2,139
    SacTown, Ca
    Never had an issue with mine; but don't try using it while raining. I believe that's in the manual. It seems to do fine in foggy conditions - but I'm too much of a control freak to enable it for any length of time.
    sylvaing likes this.
  10. sylvaing
    1,210
    514
    That's why I asked what was the weather like. Never got an answer.
