Traction battery stays at 2 bars
Discussion in 'Prime Main Forum (2017-2022)' started by Scott Dean, May 10, 2024.
  1. Scott Dean
    Scott Dean Junior Member
    Iowa
    So, I just purchased a 18 Prime Advanced. On the drive home from the car sales place it never went above 2 bars. It was almost 3 hours of driving! It has a brand new 12V battery as they had to jump start it so they replaced it.
    I tried searching on here but couldn’t find anything right away. I’m really concerned the traction battery is bad and I wanted to gain some insight before calling them.
    Thanks!!
  2. Tideland Prius
    16,588
    Did you try charging the car with a charger?
    It won't charge up in hybrid (HV) mode. You have to either go into CHG mode (press and hold HV/EV button) or physically plug the charger into the charge port at home or at a public charging station.
    FuelMiser, Louis19 and sylvaing like this.
  3. schja01
    schja01 Senior Member
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not sure I've ever noticed my traction battery charge level displayed as bars but it sounds like both your 12v and traction battery were discharged. A discharged traction battery is common as dealers typically don't charge up Primes sitting on the lot or after test drives.
    Assuming my assumptions are correct, what you are seeing are normal.
    The traction battery will only recharge through regeneration or overtly putting the car in charge mode as Tideland Prius has said.
    Hopefully the car comes with the home charging cable which you can use to get the traction battery fully charged and going forward use the EV mode of driving.
    As for a discharged 12v battery I consider this rather normal if the car sits undriven for more than a few weeks or even less.
    Enjoy your Prime.
    J
    #3 schja01, May 11, 2024
  4. Scott Dean
    Iowa
    Unfortunately the car didn’t have a charge cable with it. I ordered one, but it won’t be here until Wed. I will try the CHG mode and see if that works.
  5. BiomedO1
    3,941
    2,071
    SacTown, Ca
    Yep, plug it in.... 4 - 5 hours on 110VAC or 2.5 hrs on a 220VAC level-2 charger.
    If that doesn't work, hopefully you can take it back. There's a 8 year, 100K mile warranty on 2018 traction packs, I believe.
    Tideland Prius likes this.
  6. Scott Dean
    Iowa
    I was able to charge it in the charge mode. I’m so relieved! Thanks for helping me!
    schja01 and bisco like this.
  7. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Who would sell a plug-in car without a charge cable?!
    It would be like selling any car without a key/fob!
    The last two used cars we bought from a dealer only had one fob, but I made sure to get in writing the dealer would provide a second fob with the deal. With the most recent purchase, it took literally months to have them follow through after the salesman dropped the ball and subsequently left the dealership! I had to go back to the used car manager in person only to find he left also, so written documentation is a must.
    This same dealer charged me $400 for a LoJack that was never installed, so more trips to the sales manager to get them to refund the $400. I guess they figure most buyers would never question or follow through with complaints. Fortunately, I'm retired and have nothing but time for these shenanigans.
    #7 FuelMiser, May 12, 2024
    BiomedO1 likes this.
  8. schja01
    1,841
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    On a used car sale? More often than you'd imagine.
    Check the forums. Maybe not without any key fob but certainly with only one.
    Fortunately, 3rd party level 1 charging cables are not overly costly.
    Scott Dean likes this.
  9. BiomedO1
    3,941
    2,071
    SacTown, Ca
    LoL, a salesman's' worst nightmare. A customer that gets promises in writing and has all the time in the world to make the dealership follow through with their contractual agreements!!!!
    Unfortunately most people who buy used cars don't carefully vet them; even new cars. I wouldn't take delivery of a car once I found the spare tire jack was missing. The sales guy literally pulled one out of another new car to close the sale. Caveat Emptor. People take things out of cars they trade-in and sell it on Facebook market place or eBay so it's not surprising the charging cable is missing. You can only get that stuff, if you notice it's missing and make it part of the sales contract.
