Anyone having trouble unlocking the driver's door?
Discussion in 'Gen 5 Prius Technical Discussion' started by Paul Gregory, May 13, 2024.
  1. Paul Gregory
    Paul Gregory Senior Member
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    Mine locks me out occasionally, and I have to go around to the passenger side and use the door unlock switch in the armrest. I reported the issue to the dealer, but they said if they can't duplicate it, they can't fix it. So, I've been living with the problem until I can replicate the problem at will.
  2. dbstoo
    dbstoo Senior Member
    1,397
    752
    Near Silicon Valley
    2024 Prius Prime
    XSE Premium
    I ran into a similar problem when using my cell phone as a "digital key". Occasionally the car does not recognize the phone as a key UNTIL I turn off the phone's wifi. Then the blue-tooth signal works and the car unlocks.
    I've pretty much gotten it down to :
    a) the wifi is at the edge of my wifi signal when I'm in the driveway. I frequently have no signal there.
    This assumes that the cell phone is sending a signal over the internet to the car's cellular receiver.
    b) My phone has two blue-tooth chips. I can listen to music via headphones while using Android Auto. I can't tell which one is trying to communicate with the car.
    c) We bought a couple of faraday pouches to isolate the main key fob when it's not in use. My wife uses the pouch when she is in the car on the passenger side with her purse. That helps ensure that the smart seats adjust to my settings and not hers.
  3. Peter3232
    Peter3232 Member
    107
    48
    NY
    2024 Prius Prime
    SE
    That sounds like a pain. Fortunately, nothing like this has ever happened to me and my 2024 Prius Prime SE.
    When this happens, was the driver’s side door previously locked or unlocked?
    And when the driver’s side door locks you out in this scenario, is the sensor on the door handle responsive at all (i.e., does it make a sound when you press it)?
  4. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    It happens when I lock it and come back to the car later, and it also auto-locks when the car is running, such as when I'm getting my mail. I could leave the driver's door open, but sometimes it's cold or windy, the door gets closed. I guess I'd estimate it happens about 1 in 4 times.
    I can probably disable auto-lock, but I don't want to do that, considering safety.
  5. bisco
    51,897
    if the car is locked, how do you get into the passenger arm rest?
  6. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    It unlocks every time.
  7. bisco
    51,897
    Do the rear doors unlock?
  8. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    All the doors unlock when I use the unlock button in the passenger door. I have also unlocked the driver door by reaching in through an open window and pressing the unlock button on the driver door. When it locks me out, neither the fob nor the button on the remote will unlock the driver door.
    Post edit: I've made a service appointment at another dealer. They assured me they can troubleshoot it without duplicating the fault.
    #8 Paul Gregory, May 14, 2024
  9. Paul Gregory
    2,152
    563
    Alberta
    2024 Prius Prime
    XSE
    I mean, the passenger door always unlocks. It's just the driver's door that fails to unlock sometimes.
  10. Hammersmith
    Hammersmith Senior Member
    2,315
    2,341
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Oh, if it's only the driver door, then I'm betting it's just a squirrelly door lock actuator. Those(Toyota in general) were always flakey even before the pandemic's effect on the supply chain. It's not a stretch to imagine a bad one getting through quality control these days.
    OTOH, it could be a wiring/ECU issue. But I'm still betting it's going to be the actuator.
  11. DOHCtor
    DOHCtor Member
    162
    93
    Levis (Quebec city's south shore)
    2024 Prius Prime
    SE
    Or you could just deactivate the fob by holding the Lock button and pressing twice on Unlock. The light will flash, indicating the Fob is deactivated. It works. To reactivate it, just press a button on the fob, like, you know, unlock! ;)
  12. Beach Dweller
    Beach Dweller Junior Member
    46
    28
    The Beach
    2024 Prius Prime
    XSE Premium
    Nope.
