Charger Recommendation
Discussion in 'Prime Plug-in Charging' started by Clar007, May 13, 2022.
  1. Clar007
    Clar007 New Member
    Toronto
    2022 Prius Prime
    Upgrade
    I ordered a 2022 Prius Prime Upgrade which will arrive in Oct. Can anyone recommend a level 2 charger? Apparently my electrician said I need one with no greater than 8 kw/h for my building. Thanks!
  2. Tideland Prius
    16,108
    Welcome to PriusChat!
    That's not a problem as the Prius Prime takes 3.3kW maximum. The type of L2 EVSE depends on what you have planned for the future. If you're going to stick around in your building, and keep the Prime, then you can save money and get a 16A L2 EVSE (so 3.3kW). If you plan to upgrade to an EV in the future, then you can future proof your purchase now and buy a more powerful EVSE but then you'll be lugging around a unit that's slightly heavier (due to thicker cables).
    Currently, I'm using a ClipperCreek LCS20 as I wasn't sure what my plan was so I bought the lowest powered EVSE. It's still useful for my new EV that replaced my Prime but of course it'll take longer as an EV has a much larger battery than the Prime.
    Other brands to consider include Grizzl-E Mini (I'm waiting for this one to be launched as it's a portable version of their Grizzl-E home EVSE). EVDuty has one but their design seem to be the type where you permanently install it (as if you have your own garage or maybe a townhouse that'll let you permanently install one). These two are Canadian companies.
    Otherwise a Tesla mobile charger (get the adapters for J1772 which is what all cars except Tesla uses) or even a ClipperCreek. I like CC because the unit itself acts as a cable holder so I can wrap the cable around and store it in the car or in the house.
    No more than 8kW means you're looking at a 32A EVSE unit (7.7kW at 240V) for any of those brands above. Don't worry about the higher power as the car will dictate the maximum input rate. (This is why I've been using the term EVSE or Electric Vehicle Supply Equipment and not the word "charger" because the charger is onboard the car and is the one that controls the power. The units we're buying simply supply electricity from the outlet to the car).
    jzchen and jerrymildred like this.
  3. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    The Prius Prime can take the following:
    Car option setting of 8amps max at 120/240 volts.
    Car option setting of 12amps max at 120/240 volts.
    If you have a 1,000 amp 240volt charger :), the fastest/most any Gen4 Prime will charge at is 240volts at 12amps.
    The same is true if you use any public charger.
    I sometimes use a Chargepoint charger at work.
    Some chargers will also let the user set a max amp charge.
    The lesser amperage setting between the charger and the vehicle, is the charge-rate at which the vehicle charges at.
    For example, I have a 120/240 volt charger that I can set to 6amps max charge.
    Since I always charge overnight, I set the charger-defined max charge-rate of 6amps.
    And then, my Prime charges at 6amps (as dictated by the charger), and not the 8amps or 12amps setting that is defined by the car-defined max charge-rate settings.
    Without getting into any "p*********ing contests", you will never see any paper in a major publication that says that charging at a lower rate is bad or detrimental.
    I'm not driving some 500+mile range electric vehicle.
    Charging at 6amps 120volts is more than fast enough for me.
    I don't "ricer dyno race" my Mustang.
    And, I don't have any desire to ricer "dyno race", that I can charge my Prime faster than "you" can! :cool:
    My
    Prime sits at least 8 hours between uses.
    BFD if someone custom hacked a charging setup to DC charge in 0.00001 seconds. :)
    Good Luck!
    #3 prius16, May 14, 2022
    Danno5060 likes this.
  4. prius16
    462
    243
    New England
    2022 Prius Prime
    For chargers, I have a few:
    I recommend: (get from the Canada Amazon web site:) )
    Code:
    https://www.amazon.com/gp/product/B09HG8TV8K/
    Anbull Level 2 EV Charger (240 Volt, 25ft Cable, 16 A) Portable Electric Vehicle Charger Plug-in EV Charging Station with NEMA 6-20P
    Price: $149.99
    (Note, with an esve 120/240 volts adapter cable, this charger will work fine at 120volts.)
    This is the charger that I typically use, at 120v, and I have set at a charger-defined max 6amp charger rate.
    I do have 30amp L14-30R 240volts outlets outside, and in my garage.
    That way, if I wanted to, I could use a charger at 12amps and 240volts, for a quicker charge.
    But, mostly, I use the 240V outlets for my MIG welder, and other stuff. :)
    Also:
    Code:
    https://www.primecom.tech/
    Great options for their 16amp charger (many plug options, and 30ft, 35ft, 40ft, and 50ft cable length options)!
    Sorry, they don't offer any cables in metric. ;-)
    Code:
    https://www.primecom.tech/products/new-16-amp-level-2-portable-ev-charger
    (Note, no charger-defined charge rate options for this model)
    Good Luck!
    #4 prius16, May 14, 2022
  5. john1701a
    john1701a Prius Guru
    12,749
    5,244
    57
    That is a 32-amp EVSE. (240v * 32a = 7.7kW)
    Note that supporting any sustained draw requires 80% of the lines capacity. So to get 32 amps, you need a 40-amp line (8-gauge wire).
    #5 john1701a, May 14, 2022
  6. prius16
    462
    243
    New England
    2022 Prius Prime
    Yes, imho, the electrician is doing the correct thing, by adding an outlet that could support a 240v 30amp charger, in the future.
    Who knows, they may decide they want a full-EV in the future, or next week. :)
    If the electrician presently just added a "good enough for now" 240v 15-amp socket/circuit, it'd be double the cost to upgrade the circuit at a later time (two trips, when only one trip was needed),
    That's the same reason I have Two 240V 30amp circuits for my outside and garage. :)
    Yet, I still mainly use my charger at 120v and 6amps.
    Wire it once. :)
    Btw, to run my evse charger at 120V, I just use socket-adapters on those circuits.
    I like to run my evse charger on a separate circuit. The circuits have all new 10GA wiring, and direct point-to-point runs between the electrical panel and the outlets (no junction boxes, detours, etc).
  7. john1701a
    12,749
    5,244
    57
    5 years later for us, that's the case. I had 40-amp lines installed, figuring 7.7 kW would end up becoming the norm. When you do the math, 8 hours of charging will deliver roughly 200 miles of range. Sure enough, the upgrade from Prius Prime to bZ4X will match that anticipated future usage.
    Ideally, you would have the NEMA 14-50 outlet connected with 6-guage wire to a 50-amp breaker. That's the max supported for a 240-volt outlet. There's no point though if the vehicle cannot utilize greater load. And if you want to favor lowest cost electricity, you'll be recharging overnight anyway. So, no benefit from faster. If you truly need it, just use DC instead.
    It is interesting now looking back, 5 years later.
    prius16 likes this.
  8. CharlesH
    2,785
    1,152
    Roseville, CA
    I was fortunate that the builder of our house had put a blank outlet on the inside garage wall just opposite the breaker panel on the outside wall, so when I got a L2 EVSE, the electrician put in a 4 foot run to the outlet with a NEMA 6-50 receptacle for the Chargepoint Home charger. A rebate from my electric utility paid pretty much paid for the EVSE, and it was a couple of hundred dollars for the electrician to put in the receptacle and install the EVSE.
    jerrymildred and Tideland Prius like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,508
    14,108
    Tampa, FL
    Welcome and congrats! As several mentioned, if you'll be there long term, and you have any inkling that you might get an EV later, then the highest amperage outlet permitted would be the way to go. But the cheapest would be a 20A circuit and get a 240V, 16A, level 2 EVSE. They can be had for under $200.
    I'm guessing that's a typo since the Prime will max out at 16A with a 16A EVSE cable.
    I have several days a week where I make multiple trips, so I need to charge as quickly as possible. Also, charging at L2, 16A pulls less electricity from the wall since the fans and computers run for less than half the time of L1 charging.
    Tideland Prius and prius16 like this.
  10. prius16
    462
    243
    New England
    2022 Prius Prime
    Good catch Jerry!
    (y)
    The max charging rates are 240V@16A, or 120V@12A.
    I agree that having the 240V 16A charging ability is good for people that may take multiple trips a day.
    Below is from the 2022 Prius Prime User's manual:
    jerrymildred likes this.
  11. fuzzy1
    10,129
    It has been two years since this thread was last updated. Does anyone have any new recommendations?
    I'm looking for portable J1772 L1/L2 EVSEs, something higher capacity than the 12 amps of the Toyota L1 unit included with the car, which has already been successfully used in 'off-label' L2 mode on a NEMA 10-50 welding outlet at the family farm. The 2023-24 RAV4 can take up to 6.6 kW / ~28 amps, much more than the factory 1.4 kW unit.
    I want to travel with just one EVSE, and standard 120V outlets have been by far the most common wall outlets found so far at lodgings where J1772s were not nearby, so the L1 mode must be included. I'm not yet sure what variety of other outlets will be found in our future travels, but do remember TT-30 (120V) and NEMA 14-50 (240v) at camp sites where we needed other electrical support for cycling events.
    The Grizzl-E Mini mentioned above reached the market and appears to have good ratings, though is not inexpensive and seems to require wi-fi to change settings. The ClipperCreek unit (now Enphase?) also mentioned above is capped at 16 amps, not enough faster than I have now. And none of the multi-adapter units I've checked, including the portable Tesla charger mentioned in another thread, include an adapter for the NEMA 10-50 outlet used back at the farm. Though generic outlet adapters are available.
    What other or new units might people be recommending?
  12. priusman15
    priusman15 New Member
    Frankfurt
    2023 Prius
    For a 2022 Prius Prime with its 8.8 kWh battery, an 8 kW Level 2 charger would be ideal. I'd recommend looking into the ChargePoint Home Flex or the JuiceBox Pro 40 chargers. Both are well-reviewed, UL-certified models that can charge at up to 9.6 kW while offering flexibility to adjust to lower amperage requirements like 8 kW for your building. Don't forget to factor in potential installation costs from an electrician as well when budgeting for the Level 2 setup.
  13. fuzzy1
    10,129
    I have the ChargePoint Home Flex. Depending on whether it is hardwired or plugged-in to an outlet (choose before purchasing, it has three versions, different pigtail included in box), it can be set in multiple steps from 3.8 to 12 kW (16, 24, 32, 40, 48, or 50 amps), depending on the circuit it is attached to.
    Mine is the NEMA 14-50 outlet version, on a circuit with 40 amp breaker (32 amps / 7.62 kW max). There is a conflict between the installation instructions, recommending against a GFCI breaker for plug-in versions, and my local electrical inspector, who did require a GFCI breaker for the wall outlet. ChargePoint recommends a hardwired installation for this case, which is a separate option choice that must be selected before purchase. But so far, my main panel GFCI and ChargePoint's internal GFCI together have not caused any nuisance trips.
    So far -- less than three months -- I am very happy with it. Driving a RAV4 Prime, which can charge at 6.6 kW.
    #13 fuzzy1, May 3, 2024
  14. Plugin_RK
    Plugin_RK Member
    94
    28
    Pacific Coastal city
    2018 Prius PHV
    I would also investigate a 7kW or 8kW charger, if installing a new one, just in case I bought a different EV/PHV with greater AC charging capacity. Of course the Prius PHVs/Primes are all limited to 3.3kW or 3.5kW, which is the case for the OP's 2022 Prime, so they can't utilize the full 7kW or 8kW.
    We're still using a portable granny charger from a 10Amp socket. The charger is permanently mounted in the garage and seldom used as a portable charger. It charges at only 1.7kW every night and takes a few hours until full - but this is still well before I wake so no problem at all. Somewhere I read that the majority of drivers charge like this i.e. without a hardwired Level 2 charger. Apparently this is thought to be less safe and less flexible with regard to matching charging times and cheap power rates.
    But does this bother owners of PHVs/Primes with small batteries? Due to the small battery in all Prius PHVs/Primes I can't see the need for more timing "smarts" than the Prius's inbuilt timer to program when charging starts. (If necessary it can be different each day of the week.) But perhaps I'm wrong and there are locations where more timing "smarts" might help?
    #14 Plugin_RK, May 3, 2024
  15. fuzzy1
    10,129
    Bump.
    Note that I'm looking for a portable unit, not a wall unit. Must be both L1 and L2, preferably with user selectable current limits to or near my RAV4 Prime's max (~ 28 amps).
    Separately, is there much experience here charging J1772 vehicles from Tesla / NACS destination stations (not supercharger CCS or CHAdeMO)? E.g. what portion of outlets (if any) will serve Toyotas or other non-Teslas without being locked out by registration or accounting blockages? And any preferred J1772-NACS adapters of correct flavor and sufficient quality, not going to overheat or burn up?
    I recently supported a cycling event where, of several mid-day recharging opportunities, the sole J1772 station was fully occupied by a Rivian attending aother event, and a couple other stops were near only Tesla plugs. Evening charging was available (juggling timeslots between BEVs), but I was skunked on daytime refills.
  16. Mr.Vanvandenburg
    1,018
    345
    2020 Prius Prime
    I got a Ford level 1, 2 evse on ebay new in the unopened box for a low price. I think these come with some Mustang ev’s. Future project to install a 50 amp outlet, but it also has a standard 120 volt plug, interchangeable.
