Featured Lexus RZ is selling $13,000 below MSRP in Southern California due to inventory surplus
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Gokhan, May 22, 2024.
  1. Trollbait
    11,462
    There are no eddy current loses in a Toyota permanent magnet motor?
  2. hill
    8,138
    iirc - tesla ditched induction motors some 3 or so years ago for permanent magnet, as they're less lossy.
    Gokhan likes this.
  3. austingreen
    austingreen Senior Member
    13,555
    4,085
    Austin, TX, USA
    You are looking at the 5 year old models when tesla first put the second motor in front, and it actually was the same motor as in the performance model although software limited it's power. That changed at the end of 2019.
    Compare Side-by-Side
    The awd model now takes a hit of 2% in the city and 1% on the highway.
    The new rwd isn't up on model Y yet on fueleconomy.gov but it is on tesla. On the Y the rwd model is about 3% more efficient, versus 11% on the 5 year old model 3. On the 2024 model Y the rwd and awd use the same battery.
    On the lexus RX the rwd is 20% more efficient than the awd. Still Toyota can look at what tesla did and make some big improvements in dual motor efficiency.
    The 2022 prime is slightly more efficient than the tesla 3, but it likely comes down to tires for city and efficiency of drivetrain for highway. The model 3 has much higher rolling resistance in its tires. Both have about the same aerodynamics but the tesla motors are likely more efficient at highway speeds which lets face it you can't do for too long in the previous generation prime so not a dig.
    On the new prius prime the model 3 is more efficient. The se prime with 17" wheels and tires, more efficient than the higher trim prius primes with 19" wheels and tires.
    YMMV depending on how you drive.
    The model 3/Y AWD use a rear pm motor, and a front induction motor. The model S/X used to use 2 induction motors but now use pm motors on front and rear with the plaid getting 3 motors - one for the front axle and one for each rear wheel.
    #23 austingreen, May 24, 2024
    hill likes this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    1,816
    863
    From what I've read, both the rear motor in a Tesla and the motors in Toyota's vehicles are a permanent magnent reluctance motor hybrid. This is how they get great efficienices and torques at low RPMs and high RPMs, so over the whole range, as the rotor's angle compared to the rotating field changes from low RPM to high RPM, making it effectively a PM motor only at low RPM and a reluctance motor at high RPM. This disign is actually something I both love and hate, because it is an ingenius design but also is the final nail in the coffin for a real two or three speed manual transmission in an EV.
    austingreen likes this.
  5. Trollbait
    11,462
    The concern over rare earth mineral supply and cost also lessened.
    Isaac Zachary likes this.
  6. Gokhan
    Gokhan Senior Member
    4,598
    1,842
    Paramount CA
    Eddy currents are a small effect, especially at zero field-coil current. The resistive losses on rotor coils would be a lot higher if a permanent magnet were not used. Permanent-magnet motors are more efficient—that's why Toyota has been using them and Tesla has now ditched induction motors and switched to permanent-magnet motors in their newer cars as well.
  7. Isaac Zachary
    1,816
    863
    I have a solution!
    Ditch pemanent magenets. They require rare earth metals so aren't good.
    Just use synchronous reluctance motors. These have a narrow torque and efficiency band, but also don't have the eddy current, inefficiency problem induction motors have because they are synchronous, the rotor spins the same speed as the rotating field, and the rotor is cheap iron, nothing more.
    As a plus, they need transmissions. That way I can get my 5 speed EV stick shift commuter car.
    Thank you for your attention to my armchair engineering.
  8. bisco
    49,287
    are you trying to kill the electric car? :p
  9. Isaac Zachary
    1,816
    863
    I'm hoping for an electric car that I meets all my preferrences, I guess because what I like and want nobody else does.
    • FWD EV sedan.
    • With stick shift.
    • Doesn't need more than say 50hp or even 30hp.
    • Has a tow rating.
    • Has a spare tire.
    • Has a metal roof and flatish metal trunk lid (for ham radio antennas).
    • Ownership costs comparible to the dying econocar (back in the day, the air-cooled VW Beetle, the Geo Metro, and more recently the Honda Fit, Toyota Yaris, Mitsubishi Mirage, Nissan Versa, Chevy Spark, etc.)
    • Personally I don't care if it has ultra fast charging. But enough battery capacity to be sure I can make it to the next charging station even in winter would be great.
    Glass roofed/sun roofed, RWD/AWD crossovers with single speed gears and ludicruos acceleration and such are nice, but just not at all what I'm interested in.
  10. bisco
    49,287
    yeah, there isn't a car or politician in the universe that meets all my preferences. i even had to compromise on mrs b :p
    hill, Trollbait and Isaac Zachary like this.
  11. Trollbait
    11,462
    Tesla's reason for using induction motors was from the valid concern over rare earth element supplies and prices. Those became less volatile in time, so they switched to a permanent magnet motor. An induction motor doesn't have a magnetic field when de-energized, thus no braking effect at that time. Eddy current brake - Wikipedia Which is why Tesla continued to use an induction motor for the secondary one in AWD drive trains.
    Rare earth mineral cost and supply are still a concern. It's why the gen2 Volt had an iron magnet in one of its motors, and why Honda and others are developing motors to reduce the amount of the minerals, or eliminate them.
  12. Isaac Zachary
    1,816
    863
    The problem with EV's is, in a way, you kind of need best performance and efficiency. A few percent of efficiency gains or losses in an EV make a pretty big deal to the consumer. Most consumers want EV's that have a 500+ mile range, so squeezing out every last mile possible is pretty important for EV manufacturers.
    In an ICE you might get a bit more power or efficiency if you use a copper berilium mix for valve seats, or magnesium alloy blocks with yittrium and other such minerals to slightly outperform alluminum. But in the end, getting 50mpg compared to 40mpg or even 30mpg in an ICE isn't that big of a deal to your average consumer. So the question becomes, what's the point? I guess ICE's have expensive minerals in the catalytic converters, so that could be comparible. But in an ICE you have to have those catalytic converter minerals anyway, whereas in an EV those rare, expensive, and controversial minerals are optional.
  13. Isaac Zachary
    1,816
    863
    Electric motors have stators made of many plates. The thinner the plate, the harder it is to induce eddy currents. However, with permanent magnetic motors there will always be some eddy current drag. It may be very small, but it will still be there.
    On the other hand there are bigger fish to fry, and permanent magnet motors offer better efficiencies over all.
    I'm afraid that Aptera is on the brink of beating Toyota in the efficiency race. Aptera may end up like the Geo Metro, something that's very efficient but nobody wants. The 1994 Geo Metro xfi got 43 mpg/city and 52 mpg/highway (new adjusted ratings) long before the Prius even came out and better than the Gen 1 Prius too both city and highway. Mind you that the 1994 Metro xfi would cost just over some $15,000 in today's dollars, so apples to oranges. EV's are expensive, so are hybrids. Now I want to find and fix up a 1994 Geo Metro xfi.
    Gokhan likes this.
  14. Gokhan
    4,598
    1,842
    Paramount CA
    Ha ha, my roommate in the first year of graduate school had a black Geo Metro. He was a big and tall blond guy, and I don't know how he managed to get in it. Those were tense times in 1992 a few months after the LA riots. We went to an open mini mall in LA, and a group of Mexican guys standing there were staring at him and giving him really bad looks when he got out of his tiny Geo Metro. I got out of the passenger side next, and when they saw my black hair, they suddenly got relieved and looked away. LOL
  15. Gokhan
    4,598
    1,842
    Paramount CA
    Model S and X use permanent-magnet motors both front and rear.
    Yes, the Eddy currents are there, but I don't know how big the effect is. Perhaps 1 mpg?
    Here is an apples vs. apples comparison (not apples vs. oranges using different battery types). Tesla's AWD mpge hit is higher than Toyota's, even with an induction motor in the secondary drive axle (front for Tesla):
    Compare side by side: 2022 Model Y RWD, 2022 Model Y AWD, 1994 Geo Metro XFI manual, 1994 Geo Metro manual
  16. Gokhan
    4,598
    1,842
    Paramount CA
    Go figure this. Longo Toyota has almost no Toyota bZ4X in stock, and they are not giving any factory rebates or dealer discounts on them:
    New Toyota cars for sale in El Monte, CA: Toyota bZ4X | Longo Toyota
    One would have to be a fool not to walk in immediately next door to Longo Lexus and get a Lexus RZ instead.
    I think these inventory surpluses and factory rebates/dealer discounts are very temporary, similar to when I got my current Prius Prime in late 2020. Therefore, if you need a BEV, grab the opportunity while you can. The window won't be too long.
  17. Isaac Zachary
    1,816
    863
    AWD will always be less efficient (by how much is the question) and also costs more (more parts). It does make me sad, since the EV craze is threatening the affordable FWD. I guess we're supposed to choose now between RWD (not the greatest for snow and ice because you can't point your powered wheels) and AWD (more expensive, and cars are already too expensive) kind of like back when I was young.
    Interesting comparison. The cheapest used Tesla on the Cars.com is a 2015 Model S for $10k. Sadly the cheapest full coverage insurance on a Model S would not work for me as it would be some $400 per month.
    The cheapest non-S or X Tesla that I found is a 2022 Model 3 for $15k. The last time I had an insurance quote for a similar vehicle it was around $190 per month.
    In comparison, I just got a quote from Progressive and the insurance an a 1994 Geo Metro would around $30 per month. Of course that's just liability, but you don't need full coverage on a car that's not worth more than the deductible.
    But even at 40+ mpg, the Tesla is enticing to me in comparison. I'm just a bit afraid of longevity at 150k miles and have a few qualms for now, but if my Toyota Avalon were stolen tomorrow, I'd consider the Tesla.
    The cheapest BZ4X I could find is a tiny bit less than $25k. I have no idea what the insurance would be for me on it.
    I highly doubt I could afford a Lexus RZ, even with the price cuts.
  18. Mendel Leisk
    38,561
    Our nearby dealership has 42 BZ4X, plus 6 trucks and a Venza. That’s it.
  19. mikefocke
    3,681
    1,641
    Sanford, NC
    Canada has an allocation problem, just not getting enough from the factory located therein.
    I was into my local small town dealer this week and surprised at the number of cars on the lot. Didn't stay long enough to do the count but there were lots of Rav4s. No idea of the hybrid or plug in counts.
  20. Trollbait
    11,462
    What Toyota are you comparing the Y too?
    The Model Y AWD suffers a 4.65% reduction in efficiency compared to the RWD.
    The bZ4X is a 12.6% loss compared-.
    The RZ is a 7.2%.
    Part of the problem for RWD in poor conditions in the past was that more of the car's weight is in the front. Generally not a problem with a BEV. Then vehicle stability control and other advances helped a lot in countering the downsides in driving in those conditions. The manufacturers stuck with FWD in ICE cars for the first place, meeting fuel efficiency targets.
