I need help figuring out where this seal washer goes.
Discussion in 'Gen 3 Prius Technical Discussion' started by ReshiElderberry82, May 24, 2024.
  1. ReshiElderberry82
    ReshiElderberry82 New Member
    Atlanta
    I decided to replace the head gasket on my 2013 toyota prius cause it was either pay $5000 to get it done or do it my self so i decided to do it my self. Everything was going well till i couldn't figure out where this seal washer goes. it came with the timing gasket set i got at auto zone. does anyone have any idea where it goes?
  2. Tombukt2
    12,698
    2,269
    It's possible that may not go anywhere just keep that in mind It's not unheard of I have the whole timing cover apart laying here on the table than one of the shops I'll looking a little bit and see if I can tell right off but if you can't tell with the stuff you took off your engine and timing cover and then I wouldn't let it bother me too much.
  3. 462disco
    462disco Junior Member
    32
    Socal
    Center of the timing cover, part #7 circled in red.
    ReshiElderberry82 likes this.
  4. rjparker
    9,898
    6,104
    Don’t forget the extra sealant in these six seams
  5. Mendel Leisk
    41,012
    ^ The above illustrates well HOW to apply the sealant. For DIY with the engine in-place, it's practical to apply most on the removed cover, but for those seams, dead-simple to apply on the the engine.
