Why am I unable to register the same key via Techstream?
Discussion in 'Gen 3 Prius Technical Discussion' started by Slavatheshrimp, May 25, 2024.
  1. Slavatheshrimp
    116
    73
    Mather
    Both keys are identical. I did notice some numbers on the motherboard itself but not sure if that is the factor. One shows 8/12 one shows 3/12. Other than that, it looks identical.
    When placing the key on the passenger seat post registration, the registration process fails.
    What am I doing wrong?
    Please watch the video below, it's only a minute long.
    Thanks in advance.
  2. Tombukt2
    13,264
    2,395
    This is something you bought online I guess or just an extra remote does it have the gray sticker in it that goes on the side when you slide the cover up?
  3. Tombukt2
    13,264
    2,395
    That might give you some numbers for manual entry . Not sure how TS does it
  4. Slavatheshrimp
    116
    73
    Mather
    My brother in law gave me this key since he sold his prius. Neither of the keys in the video have any gray stickers.
  5. Carall
    Carall Active Member
    316
    104
    Harrisonburg, VA
    A used Gen 3 key must first be unlocked before it can be programmed on another prius.
  6. Slavatheshrimp
    116
    73
    Mather
    Appreciate the response. How does one go about unlocking a used key?
  7. Carall
    316
    104
    Harrisonburg, VA
    I use this tool
    but there is a cheaper option via cell phone
  8. Slavatheshrimp
    116
    73
    Mather
    Looks like the physical hardware is still required?
