Something missing here...
Discussion in 'Prius v Main Forum' started by GotVolts?, May 25, 2024.
  1. GotVolts?
    GotVolts? Junior Member
    Casselberry, FL
    2014 Prius v wagon
    So when I first got the car, I checked out the cabin air filter and saw signs of an obvious nesting of some small rodent... (small bits of foam and paper on the filter) but don't know think they are still in there. Then the other day I'm yanking the dash apart for some stereo work and I see what is in the picture. Guess I know where the foam is from... What else am I missing and where can I get it to replace it. I'm guessing a mouse since the droppings were pretty small.
    Hopefully no other damage has been done...
  2. Mendel Leisk
    41,906
    To prevent return visits, take off the wipers and cowl, put some 1/4" (opening size) galvanized steel mesh over the cabin air intake. Securing with self-tapping screws works well.
    There's also an outside chance they'll get in via the air exhausts in the back corners, under the hatch floor. That zone's trickier to mesh; I haven't gotten around to it yet.
  3. GotVolts?
    Casselberry, FL
    2014 Prius v wagon
    I did just that after reading about others misfortunes. Here's how it turned out. Also dropped a few dryer sheets in the car and will be putting some humane traps in there tonight.
    bisco and xliderider like this.
