Anyone know if the fog light connectors are on the SE?
Discussion in 'Gen 5 Prius Main Forum' started by purplePriii, Dec 12, 2023.
  1. purplePriii
    purplePriii Active Member
    275
    122
    I am not sure if anyone with an SE or an LE has checked yet but I'm looking to see if the connectors for the fog lights from the higher trims are present and if anyone took a couple pictures to see the wire gauge and what kind of connector it is.
    Anyone checked so far? I have no floor jack for the time being so cannot check
  2. PriusCamper
    PriusCamper Senior Member
    13,080
    5,306
    Pacific Northwest, USA
    I just bought these fog lights for someone: Fit for 2004-2009 Toyota Prius Bumper Fog Lights Lamps with Bulbs Switch+Harness | eBay and they appear to be much higher quality than OEM and comes with a full wiring harness and dashboard switch. Also, I've never seen obvious wiring on Gen2 lower trim models that don't have lights. So these 2 facts leads me to believe that the lights and their wiring in higher trim packages go together and you'll need more than just the lights if you want to upgrade.
  3. rjparker
    10,546
    6,621
    Toyota usually does not have spare connectors for something that does not come on a given trim.
  4. purplePriii
    275
    122
    Do those fit on the Gen 5?
    On the Gen 5 so far they had the spare connectors for the ambient lights and footwell lights which do not come on the lower trim but does on the higher trim. It was a breeze adding it back. Hence I'm wondering if it extends to the fog lights.
  5. PriusCamper
    13,080
    5,306
    Ooops... Apologies! I did't realize I was in the Gen5 forum. Disregard everything I said!
  6. FreeJack
    FreeJack Junior Member
    2024 Prius Prime
    SE
    sorry for reviving an old thread. Did you manage to get an answer? I got a 2024 SE recently and am trying to find out.
    Cheers
  7. purplePriii
    275
    122
    I never managed to get an answer nor get a jack so I have no answer. If you happen to go looking, please post your results here!
