No Ready Mode
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by thetruth127, Jun 1, 2024.
  1. thetruth127
    thetruth127 Junior Member
    36
    Would appreciate your troubleshooting procedures:
  2. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    First step: check 12v battery.
    Air_Boss likes this.
  3. thetruth127
    36
    Optima yellow top reading around 12> / Noco charger and booster
  4. Brian1954
    Brian1954 Senior Member
    2,550
    1,010
    South Central PA, USA
    I am assuming that you have not gotten the car to start after you created this thread back in April: https://priuschat.com/index.php?posts/3445569
    Why did you create a new thread rather than continuing in the earlier thread?
    You have a big mess on your hands. If the car is worth saving, a very experienced Prius mechanic would need to look at the car. It could get very expensive.
    Danno5060, Air_Boss and bisco like this.
  5. thetruth127
    36
    Your troubleshooting procedure is appreciated
  6. Air_Boss
    Air_Boss Senior Member
    4,235
    1,190
    New Yawk
    With respect, how much $$$$ have you shotgunned at these problems, so far? Further independent troubleshooting may not be your most cost-effective route to success.
    #6 Air_Boss, Jun 1, 2024
  7. bisco
    52,662
    12> may not be enough. get a load test done
  8. thetruth127
    36
    List of Replaced Parts:
    1. Prius 2010-2015 Hybrid Battery Wire Wiring Harness
      Cell Strip HV Cable Relay Bus Bar./Ebay
    2. Hybrid battery Bus Bars made of C11000 Copper Alloy, plated with 6μm thick Nickel./Amazon
    3. 2012-2017 Toyota Prius Hybrid Battery Voltage Sensor (Part No. 89892-47080) by DENSO./Ebay
    4. 2010-2015 Toyota Prius/V 12V Battery
      Positive Terminal Fuse (140A)./Ebay
    5. 2012-2015 TOYOTA PRIUS V START/STOP Parking Button Switch Dash Bezel/Immobilizer (Part No. 55446-47070)./Ebay
    6. 2010-2011 Toyota Prius Hybrid Inverter Converter./Ebay
    7. 125 Fusible link 90982-08297/ Toyota
    8. Waterpump/Toyota
  9. bisco
    52,662
    sounds like a hole new car
  10. Mendel Leisk
    42,151
    I always struggle with "<" and ">"; it's over 12 volts? How much?
    thetruth127 likes this.
  11. thetruth127
    36
    I have drawn it down to 10ish but since I got my solar setup backup its around 12.50 up to 13> , I have it on the Noco while performing test with the Techstream or the
    KZYEE KM10 Power Circuit Probe
  12. Mendel Leisk
    42,151
    If you measure voltage fresh off a charger it'll be reading highish. Ours LIVES on a charger, and my drill for checking voltage is to check in the morning, the day after it's been taken off the charger, taken for a good drive, and sat overnight.
    More telling is to test with one of the electronic load testers, Solar BA9 for example.
    bisco and thetruth127 like this.
  13. thetruth127
    36
    I load tested the modules with a
    H11 . But the 12v I haven’t other than measure it through out the day and also from under the hood . The only time I really put it on the charger or use the booster is when I’m running test with it in accessory mode.But what are you thinking ? I do have some codes a U0293 keeps popping up and other results what would you be looking for in Techstream or ?
  14. rjparker
    10,845
    6,811
    Hv battery voltage and state of charge?
  15. thetruth127
    36
    I that would be found I assume with techstream datalist which last I checked was giving this , but all the other data list produced results.What do you think it could be ?
  16. bisco
    52,662
    i'm not sure having it on a charger will cause a bad battery to perform properly
    Air_Boss and thetruth127 like this.
  17. thetruth127
    36
    It seems to hold a charge , say if I put it in accessory mode for 15 min to 30 mins it draws down to 11ish and I charge it backup to high 12’s what would be a reasonable voltage in the morning or should I test it another way ?
  18. bisco
    52,662
    the only other way i know is with a load tester. some auto parts stores do them for free
  19. thetruth127
    36
    Yea I was thinking about the auto store , but even if the 12v was bad and I charged it and used the booster. It should at least go into ready mode even if it does or doesn’t crank ?
  20. Leadfoot J. McCoalroller
    8,225
    7,731
    Pennsylvania
    2018 Prius c
    At this point the 12v source is not your problem. There may still be a problem distributing it evenly through the car (fuses) but between charging and the booster you've got enough volts there. Something else is wrong.
    thetruth127 and Brian1954 like this.
