Diagnostic/Load test results
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by thetruth127, Apr 22, 2024.
Thread Status:
Not open for further replies.
  1. thetruth127
    thetruth127 Junior Member
    36
    Relying on the help of A.I.’s it’s humbling to realize that human direct interaction is the most advanced technology, Help~
    1.Want go into Ready Mode
    U0129
    U0293
    U0104
    U1002
    U1100
    U110B
    U0142
    U0155
    U0101
    U0164
    U0293
    U0100
    U0129
    U0131
    U0293
    B27A6
    B1273
    B2324
    SYLVANIA - H11 XtraVision - High Performance Halogen Headlight Bulb Voltage 12V, Wattage 55, Load time 4 minutes
    Hybrid Battery:
    Load
    Before/After
    1/7.97 /6.95
    2/8.24/7.44
    3/7.80/6.99
    4/7.80/ 6.90
    5/7.77/6.94
    6/7.90/7.01
    7/7.83/7.00
    8/7.89/7.00
    9/7.93/7.12
    10/7.93/6.99
    11/7.93/7.04
    12/7.80/6.90
    13/7.96/7.14
    14/7.8/7.03
    15/7.74/6.01
    16/7.86/6.12
    17/7.90/6.96
    18/7.91/7.08
    19/7.85/6.95
    20/7.95/7.14
    21/7.93/6.99
    22/7.86/5.54
    23/8.03/7.14
    24/7.98/7.03
    25/7.96/7.02
    26/7.95/7.10
    27/7.99/7.06
    28/7.97/7.19
    4/17/24
    Recheck
    1/7.57
    2/7.84
    3/7.56
    4/7.55
    5/7.55
    6/7.58
    7/7.56
    8/7.55
    9/7.58
    10/7.59
    11/7.58
    12/7.55
    13/7.63
    14/7.56
    15/7.06
    16/7.13
    17/7.54
    18/7.58
    19/7.56
    20/7.58
    21/7.58
    22/7.24
    23/7.64
    24/7.56
    25/7.59
    26/7.58
    27/7.62
    28/7.61
  2. thetruth127
    36
    Diagnostic
    • 3.pdf
      File size:
      291.7 KB
    • 1.pdf
      File size:
      303.4 KB
    • 4.pdf
      File size:
      274.4 KB
    • 2.pdf
      File size:
      299.8 KB
  3. rjparker
    10,074
    6,240
    I vote for the KISS troubleshooting method.
    A. What is the 12v reading (1) at the jump point in the fuse box?
    B. What is the 12v reading (3) downstream of the 125a fusible link (2)?
    How about a human initiated description of what lead up to the problem in complete sentences followed by what you have tried so far.
    Jump start?
    #3 rjparker, Apr 23, 2024
    Brian1954 likes this.
  4. bisco
    51,839
    get a free load test at auto zone?
  5. Mendel Leisk
    41,302
    Is there a question you need answered? Can you explain in layman's terms what you're concerned with, doing?
  6. rjparker
    10,074
    6,240
    He can’t get the car into Ready
  7. bisco
    51,839
    we're going to see a lot of young people die as a result of AI
  8. thetruth127
    36
    Complete sentence? Where I come from the school to prison pipeline is big business/
    # Copilot : Certainly! Here’s a professional rewrite of the issues and actions taken, formatted with bullet points:
    Initial Issue and Diagnostic Actions:
    • Encountered a problem with the skid indicator, which activated the Internal Combustion Engine (ICE) drove for months taking off the battery cable to reset
    • Toyota performed a J0V update; the system functioned correctly for approximately one week.
    • Attempted to have Toyota honor a recall for an inverter converter replacement without success.
    Subsequent Issues and Troubleshooting Steps:
    • The vehicle failed to start; replaced the inverter converter with a pre-owned unit, which temporarily resolved the issue.
    • Experienced repeated power cut-offs; depleted and replaced the 12V battery multiple times.
    • Purchased a Noco charger and booster due to persistent battery drain.*
    • Noted adverse effects of humidity on the system; inspected the hybrid battery and found corroded connections.
    • Replaced the wiring harness due to poor connections
    Further Diagnostic and Repair Attempts:
    • Transitioned from cranking without starting to a lack of ‘ready’ mode indicator light./ not driven or started for 6 months
    • Performed ECU resets using paper clips on Pins 4 and 13, as well as jumper cable resets.
    • Accidentally crossed wires, resulting in blown fuses, which were subsequently replaced.
    • Utilized an Etekcity Measure Up multimeter to test fuses, relays, and power supply to the ECU.
    • Inspected wire harnesses and device connections with the vehicle powered off; discovered possible issues at the Power Control Module (PCM) with two of the four connectors showing no response.
    • Observed that the brake lights were not functioning.
    Component Replacement and Observations:
    • Attempted replacement of the PCM and Smart Key box, which did not yield positive results; reverted to the original components.
    • Noticed the orange accessory light blinking before shutdown.
    • After reconnecting the Tire Pressure Monitoring System (TPMS), the parking light remained continuously illuminated.
    Blown Fuses Identified:
    • (4/23/24 30 amp fuse under the hood.
    • Audio System (Navigation Receiver Type)
    • Navigation System (Navigation Receiver Type)
    • Parking Assist (Rear View Monitor) (Navigation Receiver Type)
    • 4/23/24 4/24/24 410 amp ECU-IG No.2 fuse.
    • Audio System (Radio & Display Receiver Type) Automatic Glare-Resistant EC Mirror
    • Cruise Control
    • Dynamic Radar Cruise Control
    • Engine Control
    • EPS
    • Garage Door Opener
    • Headlight Cleaner
    • Hill-Start Assist Control
    • Hybrid System
    • Navigation System (Radio & Display Receiver Type)
    • Parking Assist (Rear View Monitor) (Navigation Receiver Type) Parking Assist (Rear View Monitor) (Radio & Display Receiver Type) Pre-Collision System
    • Roof Sunshade System
    • Shift Control System
    • Tire Pressure Warning System
    • TRAC
    • Vehicle Proximity Notification System VSC
    List of Replaced Parts:
    1. Prius 2010-2015 Hybrid Battery Wire Wiring Harness Cell Strip HV Cable Relay Bus Bar./Ebay
    2. Bus Bars made of C11000 Copper Alloy, plated with 6μm thick Nickel./Amazon
    3. 2012-2017 Toyota Prius Hybrid Battery Voltage Sensor (Part No. 89892-47080) by DENSO./Ebay
    4. 2010-2015 Toyota Prius/V 12V Battery Positive Terminal Fuse (140A)./Ebay
    5. 2012-2015 TOYOTA PRIUS V START/STOP Parking Button Switch Dash Bezel/Immobilizer (Part No. 55446-47070)./Ebay
    6. 2010-2011 Toyota Prius Hybrid Inverter Converter./Ebay
    7. 125 Fusible link 90982-08297/ Toyota
    8. Waterpump/Toyota
  9. thetruth127
    36
    I’m thinking maybe the brake booster is bad , would it prevent it from going into Ready mode ?
    BRAKE BOOSTER WITH MASTER CYLINDER ASSEMBLY (SKID CONTROL ECU)
    Troubleshooting:
    (Blows fuse 10 amp ECU -IG no.2 systems
    Cruise Control
    Engine Control
    EPS
    Garage Door Opener
    Headlight Cleaner
    Hybrid System
    TRAC
    Vehicle Proximity Notification System VSC)
    U0129
    Lost Communication With Brake System Control Module Current and History indication /
    Brake booster with master cylinder (skid control ECU)/ ECM/ ( all set *2)
    *2: DTC U0123, U0124, U0126 and U0293 are not stored when DTC U0073 has already been stored.
    (Set *1) Power management control ECU (set *1: DTC is not output during communication error, but will be output as a history DTC (past DTC) when communication returns to normal.)
    Power source control live:
    Power management control ecu (power source central)
    U0129 Skid control ECU Communication stop mode (set)
    U0293 Lost communication with HV ECU
    Condition: The power management control ECU does not receive vehicle speed data from the brake booster with master cylinder assembly (skid control ECU) for 3 seconds or more.
    No brake lights
      File size:
      57.9 KB
    • 1.pdf
      File size:
      303.4 KB
    • Health Check.pdf
      File size:
      317.2 KB
    • 25.pdf
      File size:
      293.8 KB
    • 24.pdf
      File size:
      299 KB
    • 22.pdf
      File size:
      353.9 KB
    • 21.pdf
      File size:
      304.6 KB
    • 2.pdf
      File size:
      299.8 KB
    • 4.pdf
      File size:
      274.4 KB
    • 23.pdf
      File size:
      297.4 KB
    • 3.pdf
      File size:
      291.7 KB
    #9 thetruth127, Apr 24, 2024
  10. rjparker
    10,074
    6,240
    Hopefully you are out of shotgun shells.
    I would measure the voltages I suggested in post 3. Most likely you did not replace the 125amp fuse which is buried in the engine fuse box.
    thetruth127 likes this.
  11. thetruth127
    36
    8. Waterpump/Toyota
  12. bisco
    51,839
    my head is spinning
    Air_Boss likes this.
  13. thetruth127
    36
    Question, do these cables coming from hybrid battery going to the engine have a voltage? The modules are reading around 7.50 with the two in the middle 7.22 . But when I check with the multimeter the orange cables I get nothing and I tried checking the modules and the cables with a
    KZYEE KM10 Power Circuit Probe I get nothing ?
  14. thetruth127
    36
    By the way the accessory mode was not engaged
  15. thetruth127
    36
    I mean the do the cables bolted down have a voltage?
  16. rjparker
    10,074
    6,240
    They have a voltage around 201vdc when in Ready. However there is a contactor/power relay that opens contacts disabling them when the car is not in Ready. The orange disconnect plug also disconnects in a different way plus has a fuse.
    Air_Boss, thetruth127 and Brian1954 like this.
  17. thetruth127
    36
    Ok what is one of my confusions is Techstream was
    4/23/24 P308A
    Circuit Low
    Hybrid Battery Voltage Sensor All
    Circuits Low
    4/23/24 P0B65
    Hybrid Battery Voltage Sensor "I"
    P308A
    Circuit Low
    4/23/24 P0B4C
    "D" Circuit Low
    4/23/24 P0A80
    Replace Hybrid Battery Pack
    4/23/24 P0B65
    Circuit Low
    4/23/24 P0B4C
    "D" Circuit Low
    But they went away I guess after changing out the harness,sensor and bus bars .
    So now its giving
    Techstream
    No Communication with HV
    Engine and ect / U0293
    Lost Communication with Hybrid
    Vehicle Control System/Power source control ?
  18. thetruth127
    36
    So the bolts will only have a voltage or provide any reading when the car is fully started ?
  19. rjparker
    10,074
    6,240
    Brian1954 and thetruth127 like this.
  20. rjparker
    10,074
    6,240
    Let’s see - car was getting a Ready but at some point quit trying. PCM, inverter, wiring harness, battery voltage sense and bus bars changed among other things. Not sure what a scanner shows for hv battery voltage if any after six months sitting.
    Even though changing hv battery parts adds complexity, common issues after a reversed polarity jump:
    1. Many fuses blow including the 125a
    2. Some are in the interior fuse box
    3. Occasionally blown fuses are missed but the assumption is they are all good
    4. Some have mixed up fuse positions missing a needed slot or a smaller fuse was inserted in a higher load slot blowing it
    HV battery
    5. Often the orange hv battery disconnect is not properly engaged because the last step is missed
    6. The voltage sense connector on the battery ecu has corrosion
    EBay Parts and Wiring Harness Swap
    7. The part is bad or the wrong firmware
    8. Connectors are not properly connected
    No start with Ready and engine spins
    9. Sensor connectors or hose connections bad
    No Spin
    10. HV Battery discharged
Thread Status:
