Did my most EV range city driving today
Discussion in 'Prime Fuel Economy & EV Range' started by sylvaing, May 24, 2024.
  1. sylvaing
    sylvaing Active Member
    1,027
    424
    Drove 36.7 km, all city driving, maximum speed of 85 km/h and still had 11.4 km left in the battery when I got back home. That would have given me 48.1 km off the battery. Not bad for a 2017 with 147k km :)
    fotomoto and Louis19 like this.
  2. Louis19
    Louis19 Active Member
    374
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yes Indeed , the Prime shines in city driving in EV, for my usage 75% of my driving is done in EV . So after 23K km of usage 17K were done in EV the rest was in HV on highways on long rides
    sylvaing likes this.
  3. sylvaing
    1,027
    424
    I'm at 1.8L/100 km since I got it last year and since the car does 6L/100 km from the engine alone (not accounting for the help of the battery, just fuel usage over distance, as calculated by Hybrid Assistant), I'm at 70% EV myself. Some of that is due to the use of the engine to warm up the cabin during cold winter days, otherwise I would have had an even better consumption.
    Louis19 likes this.
  4. Louis19
    374
    335
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Your 2017 is healty , your numbers are very close to mine , a 2022 model. We live in the same climate so in the long run your numbers are quite the the same as mine , maybe a few tenth of liter lower on my side , the car reports 1.6L/100 Km but again it does not mean a better performance since a lot of variables will change the results ....
  5. The Tramp
    The Tramp Italian Prius Expert
    354
    32
    Turin, Italy
    2020 Prius PHV
    European cities are nowhere near your cities. There is no way I can legally go at 85 in the city. The maximum is 70 but that is on a triple carriageway, and not all of them. Otherwise it's 50 most of the time or even 30.
    Hence my range is around 70 Km on a charge.
