OBD2 scanner won't stay connected
Discussion in 'Prius OBDII Third-Party Apps' started by Moronical, Sep 13, 2020.
  1. Moronical
    Moronical New Member
    DFW
    Good morning, I'm trying to run DrPrius tests on a new to me '15 Prius. My problem is neither the panlong nor my old OBDLink LX will stay connected to my pixel 3a xl. They both pair perfectly, but 2 seconds after pairing they drop down to the previously connected devices list. Trying the connect button does nothing. I can forget and re-pair, but the same thing happens. My phone connects to the car and my earbuds perfectly. I've restarted my phone and tried updating relevant apps. I could update to Android 11, but I doubt that's the problem.
    Has anyone else run into something like this, or have suggestions? $5 says it's operator error.
    Thanks!
  2. Moronical
    DFW
    All I needed to do was tap the obd2 scanner in the Dr Prius app and it connected just fine.
    No errors and 70% life left - yay!
    Looks like I won another bet
  3. smaturin
    smaturin Junior Member
    New Orleans, Louisiana US
    I am having exactly the same problem. I am using a pixel 4a (5g)
  4. smaturin
    I feel compelled to correct / add to my post (though I don't think this will likely be read / come up in someone else's search)
    as Moronical sorted out on his own, though his description of figuring it out didn't extricate me, I also sorted it out.
    what I thought was a problem, wasn't really a problem: when I connected to the PanLong OBD2 (one of the adapters recommended at Dr Prius site), it didn't show up in my phone's (android) settings as a connected device. I stubbornly attempted multiple things to make show up in that connected device list - even though the message told me it connected, every other device I ever connected to the phone showed up in that list.
    all I had to do was ignore the fact that it wasn't in the list and start using the app.
    I have been happily using the app for several weeks now.
    now I am on the fence about paying for the 'added features' of the Dr Prius app to find out the % capacity of the battery compared to what it was when it was new. I have been spending way too much time reading this website, and this thread here Is Project Lithium / Nexcell a scam battery? | PriusChat further clouded my thoughts on this
    do I pay the money and help out a small business man trying to do some good things in this space?
    I do like FOSS which is perhaps why I am leaning away from spending the money on dr prius -- I am looking into the Autel adapter and am probably going to order that, whilst trying to get a used laptop up and running, to try and get tech stream installed. at some point I expect I will be opening a thread my self once I have more info (if the battery gods give me the time to get more info) -- I did have one instance of of a PA006 error.
    [the other very early question I have had is whether I ought to be looking at the lithium ion replacement for my NiMH that I suspect is not going to last long - especially without some conditioning - that may take me a while to implement --- that thread is making me lean toward replacing the NiMH like for like (new)
    (think I need to post a time or two more so I can add attachments when I do start a thread) .
    p.s. proved myself wrong-- I can already post an attachment. this was coming down off the mississippi river bridge - one of the only places that I go down a hill-- this is something else I've only seen once (so far).
