Teyes CC3 2k Head unit (rear camera not working)
Discussion in 'Gen 4 Prius Audio and Electronics' started by gtavowww, Oct 2, 2023.
  1. gtavowww
    gtavowww New Member
    Valencia
    2018 Prius
    I haven't tried yet..., thank you very much!!
  2. gtavowww
    gtavowww New Member
    Valencia
    2018 Prius
  3. Tony1988
    Tony1988 New Member
    Sweden
    2017 Prius PHV
    im thinking of buying and installing in my 2020 prius plug in. are they plug and play or do they now have to cut cables? are you happy with yours?
  4. gtavowww
    gtavowww New Member
    Valencia
    2018 Prius
    Plug and play, you need to be sure about the compatibility, but if it's compatible, just plug and play.
    I'm happy with it, better than the stock, but with some drawbacks, the 4G modem is awful, don't even try to use a SIM to have internet connection (at least in Spain), the phone calls via Bluetooth doesn't work well, the sound and the mic are too low, I'm still trying to work out a solution, everything else is fine, like having an android tablet.
  5. thomassster
    thomassster Member
    239
    81
    Colorado, US
    2019 Prius
    XLE AWD-e
    I'm considering getting this and upgrading from my double din Pioneer, which has quite a small screen. I've seen different sources mention that the OEM backup camera uses 6V. Does the harness that comes with the unit accommodate this?
  6. gtavowww
    gtavowww New Member
    Valencia
    2018 Prius
    Don't know, I didn't need any adaptation, just plug and play... (Toyota Prius 2018)
