Engine Rattling/Buzzing/Fluttering
Discussion in 'Gen 3 Prius Main Forum' started by Alexikor, Apr 27, 2024.
  1. Alexikor
    Alexikor Junior Member
    Arizona
    Hi all,
    I have a 2010 Prius with 197,000 miles. In the past year, I've heard the engine make a rattling/buzzing noise under acceleration. Nothing like the chunky EGR rattles, this is more like a dieseling/dried-beans-in-a-can noise. Watch the attached video with headphones. The noise is heard between the 0:09 and 0:13 marks.
    • The noise is easier to hear at speeds less than 25mph, but I've occasionally heard it at speeds above 70mph.
    • The noise is intermittent. Similar conditions of driving and weather do not consistently reproduce the noise.
      • However, the noise happens more often in the Arizona summer than winter.
      • The last couple of "fast" turns from a standstill (eg heavy acceleration while also turning sharply) have produced the noise - oil/fluid starvation?
    • Keeping the oil topped off, something I started about 6 weeks ago, helps reduce how often the noise is heard, but it still comes up.
    • So far, it's only a noise, no vibrations are felt in the cabin or steering wheel
    • My mechanic says that it's okay for a prius of this age to make the noise as "the cylinders shake and tremble as they move up and down inside the block" which doesn't give great comfort to me. He also said the spark plugs look clean. The spark plugs have 60,000 miles on them.
    • I have not checked the EGR circuit
    Any ideas what it could be?
    Follow-up question, anyone have mechanic recommendations in the Phoenix metro area?
  2. bbrages
    bbrages Member
    169
    47
    St. Louis
    I didn't watch the video, but there are a lot of thin sheet metal heat shields on and around the catalytic converter. With age, they rust enough to come partially unattached, making rattles at certain loads and rpms. That would be my first thought for tin-can type rattles.
  3. Alexikor
    Arizona
    bbrages, thank you for the reply. I'll take a look underneath and see if anything is loosey-goosey when I do the oil change and coolant change. Sorry for the late reply, I kinda thought Priuschat would send an email update when someone replied to the thread.
  4. Mendel Leisk
    42,136
    How long have you had it?
    If the EGR's never been cleaned it's more'n likely the head gasket.
  5. Mendel Leisk
    42,136
    It can if you set this in preferences:
  6. Alexikor
    Arizona
    Mendel, I've had the Prius for 14 years. Thank you for showing me the preference page.
    Currently reading the through both the head gasket and EGR cleaning posts on this forum, and it looks a little daunting. What other clues would there be to pinpoint the issue? I will be underneath the Prius in a couple weeks to change the coolant and oil.
    Another stat which may be useful. Driving around Phoenix, AZ in 110°F air with the AC set to 77°F blowing at 3 bars, the Prius shows 40mpg. On the North American East Coast (Georgia) where temps are cooler, driving around town using the same AC settings, the Prius would show 50mpg.
  7. Mendel Leisk
    42,136
    Head gaskets have usually been failing at the adjoining wall between cylinders one and two (as you stand at front of engine bay, cylinder one is at left end), on the exhaust (far) side.
    leak-down tests can been used to test head gasket integrity. Very popular though is to pressurize the cooling system (at the reservoir) and then do a boroscope inspection of the cylinders. This will require removal of the windshield wipers and metal cowl beneath, in order to remove spark plugs.
    you’re looking for:
    1. exceptionally clean piston tops
    2. Tears of coolant forming and running down from the head gasket seam.
    @NutzAboutBolts spark plug replacement video:
  8. Alexikor
    Arizona
    Thank you for the tips and video. Ordered a borescope from McMasterCarr today. Will take a look next weekend. Not easy to work in the Arizona heat in the evening
  9. Alexikor
    Arizona
    Alrighty, here's an update.
    1. I inspected the cylinder heads. Black as soot which is a relief, and the images are attached. Some of the images are super exposed as the borescope wouldn't bend easily and caught some of the metal housing that holds the ignition coils.
    2. I was going through the maintenance history again while i'm digitizing the records, and I found the EGR valve was replaced and reprogrammed in 2019/05 at 148,000 miles. The dealership here in Phoenix also recommend a premium induction service as there is excessive carbon buildup on the throttle plate. My hunch is the intake manifold might need a good cleaning.
    3. I changed the oil and both coolants last weekend. The underbody panel that sits under the oil pan is exceptionally sooty. Before I changed the oil, the dealership says the tech found a timing gasket leak which explains the all the buildup. No idea how long it's been leaking, previous records do not indicate a leak.
    Here's another video of the sound that I captured as i was in the last stages of topping off the new engine coolant. It's the chunky sound that pops and clicks seemingly at its own rhythm:
    I think the the timing gasket leak is a good clue, as the timing chain could be rattling louder due to oil starvation. Pulling the cover off and fixing the gasket looks pretty intense, so I'll start small with cleaning the intake manifold and throttle body, and inspecting the PCV and stainless-steel EGR pipe and see how that works out.
    Side note: i found the spark plugs have 80k miles on them NOT 60k as shown in my original post
      File size:
      68.5 KB
      File size:
      112.3 KB
      File size:
      39.7 KB
      File size:
      94 KB
    #9 Alexikor, Jul 13, 2024
  10. Mendel Leisk
    42,136
    They may have never touched the EGR “cooler”, the component between the valve and exhaust manifold.
    yes, likely.
  11. Alexikor
    Arizona
    So I cleaned the intake manifold and EGR circuit over the US Labor Day weekend. It was grueling and stressful since there was so much buildup and I was kinda freaking out I wouldn't have car by this morning. Some before and and after photos are attached. Didn't get a chance to snap photos of the intake manifold or most of the clean pipes, but i did get the EGR cooler completely clean with a pressure washer.
    Last night I reassembled everything, and the computer is throwing error codes:
    • P0113 (Stored) Intake air temperature circuit high input DTC Severity 2 of 3. Repair immediately if drivability issues are present
    • P0102 (Stored) Mass or volume air flow circuit low input
    • P0108 (Stored) Manifold absolute pressure/barometric pressure circuit high input
    • P3190 (Stored) Poor engine power
    • P0102 (Pending) Mass of volume air flow circuit low input
    • P0108 (Pending) Manifold absolute pressure/barometric pressure circuit high input
    • P0113 (Pending) Intake air temperature circuit high input
    • P106A (Pending) Evaporative emission system pressure sensor - manifold absolute pressure correlation
    • P0102 (Permanent) Mass or volume air flow circuit low input
    • P0108 (Permanent) Manifold absolute pressure/barometric pressure circuit high input
    • P0113 (Permanent) Intake air temperature circuit high input
    • P3190 (Permanent) Poor Engine Power
    Scanner: Innova 3170RS
    The PCV valve hose not connected when I first cranked it, so I connected it which might explain some of the errors.
    Afterwards, I double-checked every connector and hose, and they are all connected firmly in place. I let the Prius idle for about 5 minutes and it sounded normal. I also drove the Prius with the windows down for 1.1 miles at average speed of 25mph and it sounded normal.
    Some other threads talk about a drive cycle that can clean some of these codes. Is that something I should try?
    Also I did not clean the sensor that's at 3 o'clock on the throttle body because, well it's a sensor, and those don't mix with liquids or aerosols. Should I just buy a new one?
  12. Alexikor
    Arizona
    Huh, must have been premature concern, because after my morning and afternoon commutes, the CEL is gone!
    Annoyingly, I still hear the buzzing/rattling, but not as frequently.
  13. Brian1954
    Brian1954 Senior Member
    2,548
    1,008
    South Central PA, USA
    Deleted my post.
  14. Danno5060
    Danno5060 Active Member
    395
    202
    Wyoming
    Check the steering/suspension components. The buzzing/rattling/especially when accelerating while turning could be wheel bearings, CV axles, ball joints, tie rods, struts...
    Jack the front of the car up and put it on jackstands. Wiggle each wheel from side to side and top to bottom, looking for excess play. You shouldn't feel any slop. If you do, look to where the slop is coming from. Side to side could be the tie rods; top to bottom could be the ball joints. Spin the wheels and listen for grinding noises, that sort of thing.
  15. ChapmanF
    18,848
    Haven't watched the videos, but I'd say don't overlook post #2. I've heard exhaust heat shields sound really alarming, like the car was on its last legs.
  16. Alexikor
    Arizona
    The start of the summer brought some high temps here in Phoenix (115° F on the dash), and I caught a better video of the noise (headphones recommended:
    The noise is from around 0:04 - 0:06. The two thumps are the car driving over a metal track that guides a gate, not part of the car. I pressed the accelerator just a little over the halfway mark, where the color changes on the dash indicator, to get the noise to come. After a couple seconds, the noise goes away, and the engine sounds normal.
    I will check the suspension at next oil change/tire rotation in about 2 months time.
  17. bisco
    52,658
    is that the engine starting?
  18. Alexikor
    Arizona
    No, this is pulling away from a stop 0-15mph after the car has been driven about 20 miles in Arizona summer.
    What's weird is that I don't feel any vibrations when it happens, only hear the sound.
