Rattle noise at low rpm
Discussion in 'Prius c Technical Discussion' started by Teccajay, May 22, 2024.
  1. Teccajay
    Teccajay New Member
    New Hampshire
    2014 Prius c
    So I have a 2014 Prius c and it has only 98k on it. I recently started noticing a rattling noise that what sounds like is coming from the engine at low rpm’s . It’s only when I get right from EV into the eco mode when the engine kicks in (I have put a obd2 in to see the rpm’s when it’s happening so I know it’s only at low rpm’s) Once I speed up , it’s gone. I also have slight knocking when I first start the car not sure if that relates to this but it sounds similar . I recently replaced sparks to and it didn’t solve anything
    52,401
    does it have egr?
  3. spy1309
    spy1309 Junior Member
    I think all of them have egr
  4. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Does the engine shakes? take a look if it does, but i think the noise is coming from the catalytic converter shield, mine does the same sound, but the engine does not shakes, and only happens at low RPM.
    vvillovv likes this.
  5. bisco
    52,401
    seems to be a thing, i wonder if there was a bad run
