EV-Peak CQ3 Charger - D.Peak Settings
Discussion in 'Gen 2 Prius Main Forum' started by Kiwi7910, Oct 27, 2023.
  1. Kiwi7910
    Kiwi7910 Junior Member
    49
    17
    New Zealand
    I have an EV-Peak CQ3 charger that I am planning to use to recondition my Gen 2 battery.
    The units of the User Setting "NiMH Sensitivity D.Peak" are mV/cell, but I don't see any way to set the number of cells per module when charging NiMH.
    So is this setting really mV/cell or is it the total mV per module (string of cells)?
  2. DanielR
    DanielR Junior Member
    Virginia
    My understanding is that, in this case, it’s mV/module.
    I’ve had the best luck with using 1.2A-1.5A discharge to 5.8V. Keep in mind that there are 6 actual cells inside a module, and going lower than 1V per cell is where negative discharge begins, but many of the modules in my 2010 never reached 5,000mAh discharges, even after 8-10 cycles. I was only able to revive them by going lower than 6.0V on a discharge.
  3. JOHN LOFLIN
    JOHN LOFLIN New Member
    I’m new here, just got one of these chargers. I set it to 3 Call you later
    Cycles, but it stops at one?
    Any suggestions please.
    Jihn
  4. DanielR
    Virginia
    If your cycle reaches a CAPA or charging capacity, it will stop with that cycle. What I do is set the charge capacity to 8,000mAh and just run single cycles when I have this issue.
  5. 9Shenandoah
    9Shenandoah New Member
    22
    Washington State
    2014 Prius c
    Same here.
