At what miles did your head gasket fail and at what miles did you clean your EGR?
Discussion in 'Gen 3 Prius Main Forum' started by douglasjre, May 19, 2024.
  1. douglasjre
    douglasjre Senior Member
    1,851
    646
    Orlando, FL
    Please post brief answers like this is a poll
  2. PTS
    PTS Member
    62
    25
    Austin, Texas
    2013 Prius v wagon
    It was down to 38 mpg and the gasket blew. I had cleaned the egr cooler to Mendel’s specifications even though the Car Care Nut said it was a waste of time. The guy with the most views was right.
    N.J.PRIUS and PriusGuy32 like this.
  3. Mendel Leisk
    38,620
    Maybe the mods could add this question to the initial post:
    At what miles did you clean the EGR?
    And maybe fix the thread title, “mpg” should be “miles” I think.
    douglasjre and bisco like this.
  4. ASRDogman
    ASRDogman Senior Member
    6,026
    3,236
    You waited too long to clean the cooler. The damage was already done.
  5. douglasjre
    1,851
    646
    Orlando, FL
    At what mileage did you clean your EGR, and at what mileage did your hg blow.....(I just reported this to mod hoping for edit)
  6. PriusGuy32
    1,417
    510
    Harrison Township, Michigan
    115,000 Never cleaned EGR and not planning to - will replace the water pump when I replace the spark plugs at 120k miles, going to chance it!
    2015.
    MikeDee and bettergolf like this.
  7. bisco
    49,343
    good luck! at least it's a 2015
  8. M1sac
    M1sac New Member
    England
    Do all toyota hybrids that share this engine suffer HG problems. Such as the Auris
  9. Danno5060
    Danno5060 Member
    192
    78
    Wyoming
    Cleaned the EGR at 110K miles. Still going and I'm not driving it all that much these days. It'll probably be quite a while before I need to do anything else with it.
    N.J.PRIUS likes this.
  10. PA Prius
    PA Prius Active Member
    754
    241
    SE Pennsylvania
    Neither.
  11. douglasjre
    1,851
    646
    Orlando, FL
    Please list your current odometer reading
  12. Danno5060
    Danno5060 Member
    192
    78
    Wyoming
    114K miles.
    douglasjre likes this.
  13. Mendel Leisk
    38,620
    EGR cleanings:
    September of 2017, at 71K kms (~44K miles)
    November of 2022, at 96K kms (~60K miles)
    Current odometer reading: 101K kms (~63K miles)
    douglasjre and N.J.PRIUS like this.
  14. priusbydefault
    priusbydefault New Member
    26
    El Monte, CA
    2012 Prius 3, currently 166k mi. Bought used with 140k mi. Wasnt aware of Prius historic issues until I started having them and did my research. Didnt realize engine was consuming oil until low oil warning light went off on a sharp turn. Started topping off about a quart every 1k mi. Had accumulator/ABS module fail. Replaced it myself. As soon as it was back on the road, blown head gasket symptoms popped up. I am currently in the process of changing out the head gasket. Lapped the valves. While I have it apart, I am doing a piston soak and installing an oil catch can. Full egr system, throttle body and intake manifold cleaning. New spark plus and coil packs.I should be done with it by the end of this week. I will post my results.
    #14 priusbydefault, Jun 3, 2024
  15. priusbydefault
    26
    El Monte, CA
  16. bisco
    49,343
    head gasket 87,000, never cleaned the egr
  17. tomlichu
    tomlichu Junior Member
    Seattle
    2014 Prius Plug-in
    2014 plug-in Prius
    Head gasket is fine. First cleaning of EGR cooler and intake manifold a few days ago at 133k miles. Not very clogged.
    PriusGuy32 likes this.
  18. Mendel Leisk
    38,620
    How much EV mode, roughly?
  19. tomlichu
    Seattle
    2014 Prius Plug-in
    I don't have a good estimate, I would around 50k miles EV. This was my father's car prior, and he put 85k miles on it, with over half of it in EV since he was able to charge it at work. Ever since he gave this car to me, I put on 53k miles, and I do not use the plug-in.
    I was surprised at how little carbon build-up there was, I didn't take pictures of the cooler or valve though. I only have one of the pipe. The carbon wasn't baked on too badly, roughly ~30 minute soak in oven cleaner got most of the carbon out and EGR cooler pretty clean. It was coated in a layer that was not too thick. It was the same with the intake manifold. To me, it all seemed like it didn't need an immediate cleaning.
    The PCV seemed good, I was shaking it and can hear a pretty springy click. I still replaced it. There was oil in the bottom of the intake manifold, I would say around 15 mL.
    edit: grammar
    Mendel Leisk and ASRDogman like this.
  20. Mendel Leisk
    38,620
    Good time to clean: 133-50=83 (thousand miles). Keep in mind, the radiator fins in the cooler are there for a purpose, and any significant coating is not just reducing flow; it’s reducing cooling ability as well.
    An oil catch can will help with the intake manifold sludge. That’s the stuff that didn’t just breeze right through.
    tomlichu likes this.
