Android Auto nav display question
Discussion in 'Gen 5 Prius Audio, Electronics and Infotainment' started by Don G., Jun 20, 2024.
  1. Don G.
    Don G. New Member
    NC
    2024 Prius Prime
    Discovered that if an Android phone doesn't auto-connect (via bluetooth) and navigation is used in our 2024 Prius, turns are displayed on the information panel directly in front of the driver. Once a phone was connected (via USB) that display stops and the driver is alerted to turn via audio, but if they want to see the map they have to shift their eyes to the multimedia display. Is there a setting that can change how turn by turn directions are displayed so that when using Android Auto they continue to show up on the driver's display?
  2. radsaq
    radsaq Junior Member
    28
    Virginia, USA
    2024 Prius
    It's available on the second row of options alongside the compass and larger DRCC display. But it does disappear every time navigation stops so you'll end up back on the compass and need to hit left/right to see it again.
