Hybrid battery temperature and fan speed (Hybrid Assistant)
Discussion in 'Gen 4 Prius Technical Discussion' started by andywhy, Jun 21, 2024.
  1. andywhy
    andywhy New Member
    UK
    Hi all,
    I have a Lexus UX which is gen4 based and I wondered if anyone had any issues with their hybrid battery overheating on long distance trips and long regens, and the fan not increasing in speed appropriately?
    During a recent long trip there were a lot of long regen periods which meant that the battery was increasing in temperature quicker than normal. It normally sits around 38 degC, but the battery eventually hit 45 degC which caused it to start limiting charge and discharge power. The hybrid battery fan speed did not go any higher than 3 on hybrid assistant, and could not be heard.
    Using Dr Prius I was able to force the hybrid battery fan to go faster (not supported on Hybrid Assistant annoyingly) and this was able to cool the battery quickly, and was very audible. It seems that the car's default fan control does not appear to work properly in the Lexus UX, and I wondered if any prius gen4 owners had this same issue?
    I'm looking to report this to Lexus to get the software updated but I need to know if other people have observed the same thing.
    Thanks
    Edit: Attached the Hybrid Assistant graphs for the hybrid battery charge/discharge and temperature.
    #1 andywhy, Jun 21, 2024
  2. vvillovv
    vvillovv Senior Member
    3,594
    1,264
    NY
    Hey AW a 250h 2024 38 C to 45 C or 100 F to 115 F
    I haven't seen any similar posts here, not that that means there haven't been any, I just haven't seen any.
    For me reading your post, it's good to hear that DrPrius was able to override the UX defaults and cool your pack. Last time I tried using that feature with our 2017 Prime it did not work for me. I will have to try it again using my older phone which I swear the feature worked when I tried it on our Prime. LG V20 to LG V35......
    I hope you can get your issue squared away and functional, those are some fairly hi pack temps for the fans not to be spinning audibly. NiMH or Lithium either way at those temps (I'd think) Toyota /Lexus would want the fans to be audible.
    There have been a few posts regarding how pack cooling fans are programmed to be (( not audible )) under most conditions, so you may want to keep that in mind when asking for the update, if there is one for you car.
  3. andywhy
    andywhy New Member
    UK
    I have searched the forums but I didn't find anything relevant.
    Dr Prius doesn't override it properly, it speeds up and slows down as the car overrides its commands. I have a fast OBD adapter and Dr Prius set to super fast update speed so this might help, but it's not perfect.
    I'm surprised that they didn't prioritise battery health over a little fan noise, as I would prefer this if I'm honest. This is not to say the battery isn't protected, 45 degC is the highest it allows it to go which is plenty safe, but it does restrict performance at that point. I did find this odd behaviour as my CT200h did increase its fan speed when this condition occurs.
    I will probably raise this with Lexus when I go in for a service in a few months. It doesn't affect the car often, just on long trips or where there is a lot of regen braking which heats up the battery.
  4. bisco
    49,348
    i've always wondered why. it might be noise, or it might be to save energy. it certainly isn't to preserve the battery, they are happy that most exceed warranty i guess. there are better ways to cool the battery with internal ducting for the middle modules, but toyota isn't interested and modifying is complicated.
    some have gone so far as to run a duct from the a/c vent to the intake grille.
    i have read that scan gauge allows control of fan speed, there must be others.
  5. andywhy
    andywhy New Member
    UK
    It won't be to save energy. The fan uses very little power. I suspect it's mainly noise given that in 99% of driving situations the battery isn't going to get up to that kind of temperature. I've only encountered it a handful of times and it's always been from long journeys with lots of hills. A higher fan speed would allow for more heat to be moved away to stop this from happening at the expense of more noise.
    45 degC isn't going to harm the battery and that's its max limit as it becomes very inefficient above this temperature anyway (look at Ni-MH temperature specs). However, it ceases being a proper hybrid when this happens as it's not capable of supplying enough power other than stop-start of the engine. It won't provide nearly enough traction power to move the car.
    I'd argue that the design of the battery is fine, but the software control for temperature isn't set up properly. It would only need to run at full fan speed if it reached 45 degC and below that it can ramp down quite significantly. Not a lot of headroom is needed, just a couple of degrees. 38-40 degC is currently where it normally sits as you can see on my graph in the first post, but it doesn't have to be this warm. 25 degC allows max charge/discharge, and so anywhere between 25-35 degC would be a good place to let it sit.
    I wish we had a more direct route to technicians who could get this kind of update out there, or allowed us to update our own profiles.
  6. vvillovv
    3,594
    1,264
    NY
    Dr Prius was originally built for Gen 2 Prius using Gen 2 pids. The further a supported model is from a Gen 2 Prius the less likely it is to function as expected when using in a different model..
    Dr Prius still provides many valuable data points for many more Toyota/Lexus models than a Gen 2 Prius. But in many cases there are always going to be features that don't work as expected in those other models.
    There are usually driving hacks and workarounds when a DrPrius feather doesn't behave as expected. As long as the driver understands not all Toyota Pids and Programming follow the same directions and paths.
  7. Mendel Leisk
    38,628
    Just maybe it's speed is appropriate, the engineers considered all the variables, designed the fan and it's programming to suit? I know it's always tempting to improve on things, but maybe it's fine?
  8. bisco
    49,348
    fine for what though? to get the batteries through warranty, or get the longest life possible?
  9. andywhy
    andywhy New Member
    UK
    It's not fine when the battery overheats when doing its job. When you regen you put a lot of energy into the battery and when doing it repeatedly this generates a lot of heat in the battery which doesn't dissipate very quickly unless the fan is running strongly. I found that after 3 or 4 long regens in a short time (5-10 mins?) from a high ish speed (60mph) the battery was in a state of being too hot. That 6 degC gap between the 'normal' operating temperature and overheating isn't a lot. It would then take up to 20-30 mins for the temperature to fall back to 38 degC when cruising and the hybrid battery isn't used much.
    There is no need for the battery to be held at 38 degC when it can be fully functional at a lower temperature which is achieveable with an increase in fan speed. I get the need to go for silence but I would prefer that the battery be able to perform its job and put up with a little fan noise in return. Better still, they could route an a/c duct into the battery fan duct so that it receives better cooling.
    In any case, I don't think it's operating correctly. Whilst I can override it with Dr Prius (somewhat badly) I shouldn't need to. I got better performance after doing this which was helpful when I was doing a lot of fast to slow to fast speed transitions on my route.
  10. Mendel Leisk
    38,628
    Battery warms up with use. Toyota’s engineers design a fan and ductwork to cool it. You’re concerned their design is inadequate.
    I’m somewhat more confident the design is adequate, based on our car’s consistent performance over the years. Not 100%, but enough to leave it be.
  11. andywhy
    andywhy New Member
    UK
    Their hardware design is adequate, their software is not. I'm not confident in their programming of the fan when the battery is allowed to overheat and the fan is not even close to its maximum speed. When I can forcibly set it to a higher speed with a 3rd party app to provide more cooling and then it performs better, their software is clearly wrong.
  12. Abarnabe
    Abarnabe Member
    92
    59
    Netherlands
    Some time ago I took apart the battery fan and I found out it has no ball bearings, instead it has bushings.
    Bushings are noise free, and they are good for low speeds and low load, but less good for high speeds and high load.
    I believe the software runs the fan at low speeds to prolong it's life.
    I also think the engineers tried to find a balance between noise, battery temperature and fan life.
    I have replaced the bushings with ball bearings, just for test, but the noise was really loud.
    I attached a foto of the small ball bearings I have used.
  13. ChapmanF
    15,400
    I wouldn't think a fan subject to awfully high side loads, and a sleeve bearing can be very very good as long as it hasn't dried out and the oil film is there preventing any metal-to-metal contact.
