12v Battery Initialization Procedure
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 07 Touring, Jan 9, 2014.
  1. j_whitney
    j_whitney Junior Member
    California, USA
    I will check them tonight, but pretty sure they are tight. I am well aware of the potential problems with loose battery connections.
    Side note - I was cursing all the way realizing all the stuff I had to move to get the battery out, but going back in was maybe 1/4 of the time. In the dark. With a flashlight.
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    It was not meant as a insult.
  3. j_whitney
    California, USA
    Update: I had a few minutes free here at work so I went out and put the MFD in diagnostic mode, display check - battery shows 12.2 (it better, being new). browsed the other menus then put it back in regular mode and started it - the CM is working again! Will keep an eye on it, if it goes out again, I guess I will have to have it replaced.
  4. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    12.2 V is not so great, less than 50% SOC for an AGM battery. 12.8 V is 100%, 11.8 V is 0%.
    Was that with no load (push start button once)? What's the voltage with load (push start button again)? Turn on the blower fan or headlights, see what happens.
  5. j_whitney
    California, USA
    I believe the defroster was activated but no blower, but the radio was off, otherwise the start button w/out the brake pedal. Will have to check with things running.
  6. cyberpriusII
    1,155
    1,768
    Mars Hotel
    Just teasin'
    If I had thin skin, I would have deserted this board back in 2009.....although, except for one brief period, I have to say most people here are quite pleasant. I only have one person on my ignore list....and no, it is not Patrick Wong (Bisco, he's close :p).
    Kris
  7. Mendel Leisk
    41,402
    Try measuring it with a digital multimeter, everything off. The MFD method is fraught with variables, methinks.
  8. j_whitney
    California, USA
    I will, but not until this weekend and then with my trusty analog meter. My digital MM is screwy, I don't trust it a bit. The battery showed 12.4V after the drive home, 14V with the lights etc on. I will continue to check for the next few days.
    But my face is sure red. When I left work, I checked things again, and when I turned the lights on while in diagnostic mode - the CM display blanked out again. Sheepishly, I checked the dash light dimmer and that fixed it :love:
  9. andrewclaus
    993
    326
    Golden, CO
    Those sound like normal readings. When the car is in "ready" mode, the inverter is charging the battery at up to 14 Volts. Your DMM might be okay.
    You might want to check on this forum for one of the many threads on checking the 12V battery.
  10. j_whitney
    California, USA
    Will do, thanks Andrew
  11. Riz Khan
    Riz Khan New Member
    I just bought Toyota prius v 2012 model installed new 12V battery but after that clock , radio stations and Trip A & B and MPG disappeared, I managed to reset time & radio stations but I don't know how to reset milage per gallon and Trip A & B ,
    can anyone help pls . Thanks,
  12. bisco
    51,895
    congrats and welcome!
    i think those are lost forever.
  13. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    @Mendel Leisk , thanks for this post. I will need to replace my 12 volt battery soon and your memory saver Cord might be my answer to not having to worry about anything not working or resetting in the car.
  14. Mendel Leisk
    41,402
    Do you have a jump pack with cig lighter socket? Or maybe a second car (with cig lighter socket), with something like this, to extend reach:
    Even a set of jumper cables could work with a second car, connecting at the jump point and a ground.
    deep breath:
    that said, whenever I’ve done DIY brake work I purposely disconnect the 12 volt. IIRC I’ve not had to do the window auto-up reteach. Trip meters and radio presets do get lost.
  15. Xterra72
    1,432
    1,679
    I have to his one to connect to.
  16. Xterra72
    1,432
    1,679
    Do you power on before or after you plug in the obdII? Or does it matter?
  17. Mendel Leisk
    41,402
    No I don’t, no point. Might even be risky.
  18. Xterra72
    1,432
    1,679
    I meant do you power your jump pack or power source to the obdII before or after you connect it to the obdII port.
  19. Mendel Leisk
    41,402
    My jump pack is constant on, so I would surmise it doesn’t matter. Some of the OBD power cords have indicator lights both end (to confirm each connection). The Clore one only has one indicator light, so I think connect first to the one most iffy, maybe the OBD end?
    Xterra72 likes this.
