Toyota Prius 2023 LE FWD DRLs and auto lights
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Adam Adamovich, Jun 25, 2024.
  1. Adam Adamovich
    Adam Adamovich New Member
    United States
    2023 Prius
    Hello, I was wondering if there is a way to turn off DRLs and replace them with parking lights(led strip) instead as it is on higher models?! Also, is there a way to retrofit auto headlights on LE models?
  2. Agent337
    Agent337 Member
    27
    Orange County, California
    2023 Prius Prime
    SE
    Following this thread as I'd hope to find a solution for this as well, I have a 2023 Prius Prime SE. One "workaround" that I've found is to disable the DRL in the vehicle settings in the multimedia display screen, then turn the headlight stalk to turn on the parking lights. This turns on the front top LED lights without having the actual headlights turn on. This also turns on the front and rear side markers so you'll be driving around with your parking lights on.
  3. Adam Adamovich
    United States
    2023 Prius
    Yeah, but it'll dim your inside displays, and orange deflectors would be turned on also, so wouldn't work for me. I saw on Canadian SE Prime models they come standard with auto lights with the same headlights as we get in US for LE or SE. But the same headlight only used that led strip during daytime.
