Audio Not Working after 11.6" Display Switch
Discussion in 'Prime Audio, Electronics, and Infotainment' started by soontobeangel, Jun 17, 2024.
Tags:
  1. soontobeangel
    soontobeangel New Member
    California, USA
    2020 Prius Prime
    Hey all - need some help! I have a 2020 Prime XLE, and cracked the Infotainment Screen (E7057). It was still working - side buttons still controlled volume and temp, and the map updated - but the touch controls were dead.
    I bought a replacement unit (E7052 with JBL) and the install went great! I swapped the Micro SD card from the old unit into the new unit, patched all the cables on the back properly, and did the long software update. However, while everything works with the new unit (Nav, Bluetooth connection, touch controls), there is no audio coming out of the speakers. It perpetually says "Audio Off" and when I try to select a source, it will flash and stay on the selection screen. Sometimes I can hear a brief (1/2 second) static through the speakers when i try to select FM / AM, but that's it. The Bluetooth shows a connection and I did a test call with my wife where she could hear me (so the mic works) but I couldn't hear her.
    Any thoughts or tips? I don't think the part is defective but working with the vendor to confirm that. Thanks!
  2. Igor331
    Igor331 Junior Member
    Kazakhstan
    2018 Prius Prime
    Original HU have amplyfier onboard, JBL not have.
    You need to replace one PCB with amplyfier from old HU to new HU, and it will works.
    #2 Igor331, Jun 26, 2024
  3. Pdog808
    Pdog808 Active Member
    427
    285
    Los Angeles
    2018 Prius Prime
    When I replaced my display screen, we had to make sure the serial number of the replacement display exactly matched the one that it was replacing. Because your serial numbers appear to be different, your issue most likely stems from that.
