Post Aftermarket Stereo Fiasco
Discussion in 'Gen 2 Prius Technical Discussion' started by Duncwarw, Jun 26, 2024.
  1. Duncwarw
    Duncwarw Junior Member
    46
    Capital Region, NY
    I feel that this issue should be separated from my other thread about my new stereo and bypassing the JVC thing.
    Once I finally got the new thing working, I still have the multiple warning lights on the dash but that's nothing new.
    My (yet another) issue is with the MFD,
    Symptoms:
    Climate; "Check the connection to the air conditioner"
    Audio: "Audio Off" (non-issue)
    Trip Info: No battery levels, no arrows
    Menu: "The external system is not connected"
    Dest: Same as "Menu"
    Map: Same as "Menu"
    I recently bought a virtually identical Prius to drive but I really need the '08 to work/pass inspection as it is my work vehicle.
    I don't think it's a bad MFD and I hope somebody can point me in a the right direction.
    Thanks!
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    What ever you did, the car is no longer communicating with the MFD.
    At a minimum, verify all your connections at the rear of the MFD have been plugged back in.
    Meg&Bear likes this.
  3. Duncwarw
    46
    Capital Region, NY
    Thanks for the response. I'll look again.
    I don't think I unplugged anything from the MFD and I left the thing plugged in and just put the MFD aside
    while I worked on the stereo. I hope I missed another connector (or two) !
  4. Tombukt2
    12,637
    2,251
    And have you cut into things or just tapped? Taking apart and soldered? But yeah you've definitely got to communication problem The plugs click in pretty smartly. And they can fail you for your MFD not working for inspection because I wouldn't think the check engine light would be lit for this reason.
  5. dolj
    dolj Senior Member
    8,307
    4,245
    Wellington, New Zealand
    Did the harness you used have an integrated 68Ω resistor within? If not search for 68 ohm resistor in the Audio and Accessories forum for threads that detail how to do that. The resistor is required to correctly terminate the comms bus.
  6. Duncwarw
    46
    Capital Region, NY
    Soldered and heat shrink(ed).
    Thanks for the hints, I've been really busy lately but I need to find time to get back to work on that Prius...
  7. Duncwarw
    46
    Capital Region, NY
    It came with the resistor. I'll solder it in.
    Thanks!
  8. tkc100
    tkc100 Member
    89
    25
    Arizona
    I have considered replacing my head unit and I know that it has been done successfully but.....
    While work on another problem I got an education on the CAN bus. There numerous control units and items that communicate over the bus. Any disruptions to the communications can have unexpected and seemly unrelated consequences.
