I want to alert everyone of an issue with the auxiliary 12 volts battery in the new Prius prime 2024
Discussion in 'Gen 5 Prius Technical Discussion' started by Kulti, Apr 29, 2024.
  1. Harry94025
    Harry94025 New Member
    Castro Valley
    2023 Prius Prime
    XSE
    No, they only use the GR8 diagnostic/charger. Researching the GR8, apparently most dealerships use this because it provides a receipt-like “ticket” that allows them to submit a warranty claim.
    According to the owner’s manual, there is a criteria related to the “20 hour rate capacity”; if it is low, “even if the time period where the vehicle is not used is a short time, the 12-volt battery may discharge and the hybrid system may not be able to start.”
    In my case, I drove the car on Sunday afternoon and it failed to start on Wednesday morning.
    Reading about this problem here and elsewhere, why aren’t owners making a big protest back to Toyota? I’m planning to contact Toyota, Consumer’s Report, and Motor Trend. Motor Trend should be made aware of this issue with their 2024 Car of the Year!
  2. Harry94025
    Castro Valley
    2023 Prius Prime
    XSE
    Just found this in the owner’s manual. After I last drove the car, it was put on the charger when we got home and I left it overnight since it wasn’t going to be completely charged until 11:30 PM. Removed the charging system at ~8:30 AM the next morning and didn’t try driving it until two days later.
  3. bisco
    49,490
    if you don't drive too often you might need a maintainer
  4. Harry94025
    Castro Valley
    2023 Prius Prime
    XSE
    The dealer texted me this afternoon that they tried to start the car and it didn’t work, a day after they said everything had checked out ok. Very glad that I didn’t listen to them to pick it up yesterday!
    I asked them to see if a larger capacity battery, such as the Truestart 470CCA mentioned by another poster, could be installed. I also bought the NOCO GB40 battery booster in case this happens again…
    AndersOne and bisco like this.
  5. Cc103acs
    Cc103acs New Member
    27
    Connecticut
    2024 Prius Prime
    XSE
    I believe the 12 volt is an AGM battery.
  6. Mendel Leisk
    38,726
    Somebody's gotta do a phantom load test. It's not hard; might get to the bottom of this. It could be excessive phantom load, or the hybrid battery charging causing excessive draw, or a combo of the two.
  7. Tiberius
    Tiberius Junior Member
    Toronto
    2023 Prius Prime
    XSE Premium
    Ok so the battery issue just reared its ugly head. Have a 2023 for about 1 year, battery dead this week. Toyota roadside boosted it, dead again 3 days later. Replaced battery by Toyota (supposedly bad battery as it failed the tests)
    I’m fairly sure I did everything correctly with the battery as per best practices and it still died.
  8. bisco
    49,490
    does canada have the software tsb? don't count on the dealer to know.
    GcinFl likes this.
  9. HacksawMark
    HacksawMark Active Member
    442
    287
    Oregon
    2023 Prius Prime
    XSE
    Did you check to see if you have a tracker tied into your OBD port under the dash?
    PhoS and Templeton like this.
  10. Approximate Pseudonym
    103
    49
    Colorado
    2024 Prius Prime
    XSE Premium
    Not on the '23-24 Prius models.
    Conventional flooded lead acid 12v battery.
  11. purplePriii
    purplePriii Member
    163
    68
    Did anyone post the TSB number or document for this? I looked but couldn't find it
  12. KMO
    KMO Senior Member
    1,541
    425
    Finland
    2023 Prius Prime
    I believe that's referring to this, issued this month:
    T-SB-0054-24
    12V Auxiliary Battery Charge May Deplete When PHEV Charging Cable has an Extended Connection Without Charging
    From here:
    Parasitic battery drain? | Page 4 | PriusChat
