  1. Hotdog453
    Hotdog453 New Member
    Ohio
    2024 Prius Prime
    XSE Premium
    Hello,
    For our 2024 Prius Prime, I plan to have two sets of tires: Snow and non snow.
    Does the car natively support multiple sets of TPM, assuming they were 'correctly' assigned to the car? IE, in my Subaru, I currently have a tool to 'flash' the sensors to the car, via the OBD2 port each time I swap tires.
    What are people doing with multiple sets of tires/rims?
    I am 100% down to 'buy something' to do this, but didn't see much information floating around out there.
    Thanks!
  2. Hammersmith
    Hammersmith Senior Member
    1,301
    1,321
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 Prius can handle 2 sets of tires. No scan tools are needed. Everything can be handled through the in-car menu system.
    SM-S901U ?
    Hotdog453 likes this.
  3. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Thanks! I assume the 'dealer', or 'the installer', has to initially synch it up, then it's available in a menu?
  4. Hammersmith
    1,301
    1,321
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Nope. Just have the correct TPMS sensors installed on the wheels, go into the car's menu to tell it to recognize a second set of wheels, then drive around for a bit. No dealer needed.
    SM-S901U ?
  5. Hotdog453
    Ohio
    2024 Prius Prime
    XSE Premium
    Haha! Even better. Thanks.
