2015 Prius c oem fog lights
Discussion in 'Prius c Accessories and Modifications' started by Christophers, Mar 10, 2016.
  1. DasMc
    DasMc New Member
    PNW
    Hello, could you clarify what "stock" is needed? Is there a part number for this "stock?"
    I also found the h11 factory plugs electrical taped up against the blinker wires underneath my bumper.
    I pulled the panel where the OEM fog light switch would go and there is no wire pig tail to plug a OEM switch into. I am assuming that there is a OEM wire harness that needs to be purchased to complete the circuit? Where would such a harness plug in at? Perhaps it is folded and taped up under the dash already and I'm not seeing it?
    Anyone complete an install using the factory wiring? I understand I will need the bezels, fog light lenses, light bulbs, OEM switch for the dash, possible relay and add a fuse in the fuse block for the fog lights... what else?
    Thanks for your help!
  2. RamiKanaras
    RamiKanaras New Member
    2015 Prius c
    I am looking for the same thing as the above ^.
  3. Mtn-Goat
    Mtn-Goat New Member
    Here
    2015 Prius c
    Left steering column stalk will be needed, pre-wired fogs will allow you to skip wiring.
    Suggest plugging your VIN confirm fit. You can try to retrofit as used parts are much cheaper now.
    PARTS
    81481-52620 Lamp Cover RH
    81482-52530 Lamp Cover LH
    90167-50063 Screw, Pan Tapping (8)
    84140-47161 Steering Column Assembly
    LED
    81220-48050 Lamp Assy, Fog, LH
    81210-48050 Lamp Assy, Fog, RH
    90080-87010 Relay
    RH0506R000FC02 50w 6ohm Resistor (2)
    HALOGEN
    90981-13090 Bulb 12V 19W (2)
    81211-47010 Lamp Assembly, Fog, LH
    81211-47010 Lamp Assembly, Fog, RH
    90080-87026 Relay
  4. Mtn-Goat
    Mtn-Goat New Member
    Here
    2015 Prius c
    Correction to the LED Fogs Resistor (optional)
    RH01018R00FC02 - 12.5watt 18ohm (2)
    More PN for the steering column if you are shopping.
    629-51406L
    47151-17F968
    173832 stamped on the inner assembly
