OBD2 scanner apps for smartphones
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by C Clay, Jun 30, 2024 at 11:22 AM.
  1. C Clay
    C Clay Member
    285
    52
    Lexington, KY
    Do any of you use this app? I found an old thread on it and it seems the developer went offline for some time. I have Dr Prius and have never really used it for much except to turn off the reverse siren. This app has some cool features like coolant temperature and tachometer.
    I just wonder if it is accurate with its data. So odd to be that it is free, or has most features for free: ‎Car Scanner ELM OBD2 on the App Store
    iPhone ?
  2. Tombukt2
    8,880
    1,549
    I don't know much about that I've heard of the ELM business talked about before not in any kind of a bad light I guess there's some kind of problem possibly with the software because it's maybe Russian. But seemingly the best bang for the buck is the AP200 thingy. If you wanted to pay a monthly subscription the carista seems like it's the way to go with most modern cars it can bring up TPMS sensor identification numbers for each wheel generally able to program said to the car all of that sort of thing I don't know what the monthly subscription is but the carista if you really need to play with the TPMS and some other things might be a good thing to have and just turn on your subscription on an as needed basis if you don't do much scanning and then having the AP200 outright and it can bleed your brakes and read all of your codes and do most things except the TPMS business which apparently the carista can do very well and it has interfaces that look just like the TIS or Toyota software business so that's a plus The AP200 is 56 bucks and I imagine the carista hardware piece is probably $40 or something like that and I don't even care what the monthly subscription is because I wouldn't use it but every few years probably maybe a little more often working on other cars but we'll see In those two devices you don't have anywhere near an MK 808 or any of that kind of business and shouldn't need it.
  3. ChapmanF
    15,405
    I haven't used Car Scanner myself but it seems pretty decent from what others report.
    We have this thread that compares a bunch of different offerings, testing them on Prius gen 2. So the thread's not absolutely specific for gen 3, but it should give some useful comparative info.
    Gen2 OBD2 app review | PriusChat
    Brian1954 likes this.
  4. burebista
    burebista Active Member
    166
    114
    Romania
    I have on my phone:
    Car Scanner
    Hybrid Assistant
    Torque
    Dr. Prius
    Scan Master
    And OBDLink from my OBDLink MX.
    All are fine. :)
