Featured Next Gen Toyota Harrier (Venza)
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Tideland Prius, Jun 30, 2024.
  1. Tideland Prius
    16,553
    john1701a likes this.
  2. bwilson4web
    16,201
    Are they going to build them in Georgetown KY?
  3. Mendel Leisk
    41,396
    I don’t think they’ll be happy till the headlights are under a centimetre tall. :confused:
    bwilson4web likes this.
  4. Isaac Zachary
    Isaac Zachary Senior Member
    2,541
    1,280
    Then they'll go back to big round ones, then square, then triangle, then some other silly shape.
    Why? Because all cars are becoming the same CUV shape. Look at a car as a silhouette and you won't be able to tell any of them apart. So they have to draw lines on it somewhere to distinguish it from the competition. And using the headlights as accent lines seems to be the popular thing right now.
    This is probably the main reason I actually like the Cybertruck. It's different. So is the Aptera, and I really like the Aptera. But if I'm getting a new SUV of any sort it needs to be a Ford Bronco.
    Trollbait and Mendel Leisk like this.
  5. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Note that Harrier is what Toyota had planned next for PHEV offerings.
  6. bisco
    51,892
    It’s not half bad looking
  7. Trollbait
    12,517
    Tideland Prius likes this.
  8. Tideland Prius
    16,553
    I mean, the Millennials are the head designers now and they grew up with Robocop.
    Isaac Zachary and Mendel Leisk like this.
  9. austingreen
    austingreen Senior Member
    13,671
    4,209
    Austin, TX, USA
    The headlights are so much better now that they are LED vs when those old designs existed for normal incandescent headlights. Halogen was the big step improvement, but LEDs as standard give designers freedom to shape the headlights anyway they want. Not a beautiful design in this model but LEDs give freedom to make beautiful or fugly lighting on cars.
    https://www.roadandtrack.com/car-culture/g6631/ten-cars-with-incredibly-cool-headlights/?slide=15
  10. Mendel Leisk
    41,396
    While replacement headlight prices rise logarithmically. Or is it exponentially? Anyway…
  11. Trollbait
    12,517
    LEDs will only need replacing in the event of a crash or other damage. A hypothetical, standard sized headlight would start at $20, and likely need replacing every year.
  12. Tideland Prius
    16,553
    The problem is that if one bulb goes, the entire headlight unit has to be replaced (whether it's the marker light, or one of the many bulbs in the low beam or the indicators). I like LEDs but they need to find a way to make them user replaceable (at least the smaller ones like indicators and side marker lights. Sell the circuit board with however many lights that make up that light position.)
  13. Trollbait
    12,517
    True, but how often does that happen? Then making components easier to replace can make the unit less reliable over all. Batteries inside the phone allow the whole unit to be less susceptible to damage from water and dust.
  14. Isaac Zachary
    2,541
    1,280
    Well, we would hope so. They might start dying once engineers figure out how to make them as cheaply as possible for them to last "just long enough" which in many cases might not actually be long enough.
    While quit different from things like engines and transmissions, It does seem that things are often designed to last "just long enough" any more. Sometimes manufacturer's cut it too close and the next thing you know you have to replace it much more often than should be necessary. Toyota generally isn't like that, but sometimes I do wonder about where they're headed as far as quality goes.
  15. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
  16. Tideland Prius
    16,553
    True. While I have seen entire units fail, turn yellow or just missing pieces (on the late 2010 cars with several of those large LED bulbs for DRLs like Audi or Nissan). It is very rare.
    Crown Sport. We don't get that model (yet).
  17. austingreen
    13,671
    4,209
    Austin, TX, USA
    Yes, this is a problem with the car designers not the technology. This is evidenced by the fact that aftermarket LEDs can replace older headlight, indicator light, and daytime running light technology.
