2024 Prius Limited AWD Camber Kit
Discussion in 'Gen 5 Prius Accessories and Modifications' started by Justin Prius AWD, Jun 29, 2024.
  1. Justin Prius AWD
    Justin Prius AWD Junior Member
    37
    2024 Prius
    Limited AWD-e
    I have a 2024 Prius lowered on RS-R springs. Went in yesterday for an alignment and learned that the rear is slightly out of factory tolerance and the front is right on the edge. This is with all possible adjustments. Depending on tire wear in the rear, I might need a camber kit. Any suggestions?
  2. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Did you get a print out? I measured mine after the RSR springs and it was within the range. I wouldn't really worry about a tiny bit of negative camber. It's not going to drastically wear the tire. Otherwise, you would need an adjustable rear upper arm to increase camber on the back of which there are a few already available. The front can use a simple eccentric camber bolt kit. Not sure which size but I'm guessing 10mm or 12mm based on the size of the strut bolts.
  3. zeng
    zeng Junior Member
    45
    Kuala Lumpur
    Front eccentric camber bolt size is 17 mm sir.
  4. PhoS
    PhoS Active Member
    255
    210
    Nowhere
    2023 Prius
    Limited AWD-e
    Ah nice, I'm remembering now how enormous those bolts are compared to some other cars I have worked on recently. Have you installed them yourself? If so, how much camber were you able to gain?
