2013 Persona Project..
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Xterra72, Oct 29, 2014.
  1. PTS
    PTS Member
    62
    25
    Austin, Texas
    2013 Prius v wagon
    Cool
  2. Xterra72
    Xterra72 Senior Member
    1,387
    1,652
    At HybridPit. Engine Transplant. More to come.
    Mendel Leisk and Burna J like this.
  3. Xterra72
    1,387
    1,652
    Long story, short…
    Dropped off Wednesday morning.
    Car prepped Wednesday afternoon.
    Thursday, and it was full speed ahead!
    Old engine out!
    New engine in!
    Done!
    Friday Testing!
    Everything checks out!
    Drove back to Northern Cali!
    330 mile drive & my car lives another day!
    Thank you Hybrid Pit! My car is back on track!
    Before:
    After!
    #263 Xterra72, Jun 23, 2024
    amarino, Burna J and ASRDogman like this.
  4. AzusaPrius
    AzusaPrius Senior Member
    1,822
    809
    So you got a Gen 4 engine installed thats cool.
    Xterra72 likes this.
  5. Xterra72
    1,387
    1,652
    Because I wasn’t driving my car when I had the head gasket problem (before the engine transplant), I drained the car’s 12 Volt Battery just before my trip to Hybrid Pit.
    I was able to jump the car with a battery jump pack. Also before the trip, I connected it to a battery charger , settings at 12 volt, AGM, and at 2 amps. The battery charger fully charged the car’s 12 volt battery before my trip to Hybrid Pit.
    This is my second 12 volt battery, installed on July 2020. This is almost 4 years old. The original 12 volt battery (lasted 7 years), never drained itself. This was the first time it’s ever happened. Granted this was the longest time it sat and not being driven.
    I ended up purchasing a battery charger to see how much longer I could keep it.
    It charged it to a full charge twice but on the 3rd and 4th try, I never got the green fully charged light , so I thought the battery was compromised.
    to verify this, I purchased a battery tester from Clore Automotive and these were the following test results.
    After these results, I’m charging the battery again. Let’s see if I can get it back to a full charge.
    #265 Xterra72, Jun 27, 2024 at 9:24 PM
  6. Xterra72
    1,387
    1,652
    After 6-1/2 hours, finally got the complete full charge with the green light.
    Kept it plugged it and see what happens.
    12 volt battery states to get it fully charged within 10 hours. I will unplug after 3-1/2 hours.
    I’m testing it out because I did this battery charge overnight (twice), while I was asleep and when I woke up after the battery was charging just under 10 hours, the battery charger was still on charging mode, amber light.
    #266 Xterra72, Jun 27, 2024 at 10:46 PM
  7. Xterra72
    1,387
    1,652
    The manual did show this
    I’m currently in n Phase 5.
    Based on the chart, when I had it charging overnight, the charger was in Phase 7. All I saw was an amber light with no green light.
  8. ASRDogman
    ASRDogman Senior Member
    6,048
    3,247
    Doesn't sound like a healthy 12 volt battery. You've charged it several times,
    and it still won't fully charge? Since it's not that old, you should still have a warranty
    on it. Take it back and get a new battery, charges it until it's fully charged,
    they don't worry about it for several years.
  9. Mendel Leisk
    38,641
    What’s the specd CCA, 325? Then 311 seems lowish, indicative of a battery on the way out.
    I’ve always found good-condition batteries read well above specd CCA, say at least 25~50 higher.
  10. Xterra72
    1,387
    1,652
    The battery is almost 4 years old. I would think the warranty has already ended.
  11. Xterra72
    1,387
    1,652
    Yes , the CCA test result came in lower than what is shown on the battery at CCA 325.
    the SOC is at 72% and the SOH is at 95%, so hoping the battery still has some decent usable life.
    But maybe it is time for a new battery.
  12. ASRDogman
    6,048
    3,247
    Depends on what battery you purchased. It's an 8 year warranty from Toyota.
  13. Brian1954
    Brian1954 Active Member
    789
    299
    South Central PA, USA
    Toyota warranty is 84 months (7 years).
  14. ASRDogman
    6,048
    3,247
    whatever..... more than 4 years...
  15. Xterra72
    1,387
    1,652
    Just went to the dealer. Yes it’s 84 months.
    This same dealer installed the battery for me.
    They said in order to honor the 84 months warranty, the battery has to fail through their own battery tester.
    Secondly, they said if it does fail, they will pro rate it for however many months it failed before the 84 months.
    Thirdly , in order for this to happen, the dealer has to install it and the customer has to pay the dealership the $245 labor for install.
    It’s crazy how this works. Nuts!
    To be fair, if the battery failed within 2 years of purchase, then they replace the battery for free and no labor cost.
  16. ASRDogman
    6,048
    3,247
    WHAT??? I think you need a new dealer.
    The "parts" department told me they would have to lead test it and if it failed they
    would replace it. No charge. And pro rated if over 2 years old.
  17. ChapmanF
    15,430
    Last time I dealt with a pooped-out Prius battery, I swapped it for an older (but not pooped-out) one to get the car going, and then drove it to the Toyota dealer where the pooped-out one had been bought, and plopped the battery on the parts counter. They took it in back, put in on their tester, confirmed it was pooped out, and I walked out the door carrying a new one with the pro rata cost of the pooped-out one deducted.
    Seems like some dealers are more reasonable than others.
    Brian1954 and Xterra72 like this.
  18. Xterra72
    1,387
    1,652
    I called another dealership. I spoke to a parts department specialist and they said the same thing. If the battery was purchased from a dealership and their testing holds true that the battery has failed, the battery will be replace or pro rated regardless of who installed it.
    They considered my situation and this dealership is willing to have me take the battery to them, even though the battery was not purchased from them.
    if their tests proves that the battery is defective, they will not pro rate it , but even better, the parts specialist said that they will replace it with a new battery at no charge. I give them the bad battery and they will give me a new one.
    I couldn’t believe that they would go out of their way to accommodate my situation.
    This will all happen next week. Let’s see the outcome.
    I will probably be taking my car here for future parts, maintenance and services.
    ASRDogman likes this.
  19. ASRDogman
    6,048
    3,247
    There ya go!
  20. Xterra72
    1,387
    1,652
    I went to the other dealership this morning.
    The 12 volt battery was tested & it’s passed all their tests. It is still good at its current state.
    When it comes time to replace this one, I might spend a bit more and get this,
    https://a.co/d/09DXD3sj
    #280 Xterra72, Jul 1, 2024 at 10:30 PM
