New Wheels/Tires- Bye bye OEM
Discussion in 'Gen 5 Prius Main Forum' started by Blackat, Jul 2, 2024.
  1. Blackat
    Blackat Active Member
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    Finally had it with the 19's and POS Toyo's. Lack of handling while flogging up Berthoud Pass and road noise, lack of choices or long wait time if one blows....
    Especially after swapping back from my winter set up. Just too much...Lol
    Very happy with these 17's from Enkei(Japan) with Conti DWS06- 225/55/17
    Tires fit perfectly in wheel well.
    Rides better, a lot less noise.
    Danno5060, GeoJ, xliderider and 8 others like this.
  2. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    Also, the new wheel and tire is almost 5lbs lighter than the OEM
  3. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Very good point , Prius should come standard with decent 17 inch wheels on each version . 19 inch should be an option for those that want them
  4. Will B
    Will B Active Member
    442
    408
    Denver
    2023 Prius Prime
    XSE Premium
    Thanks for this. Contemplating something like this a bit later on. Figger I will live with the 19s until I get a bit more use out of them first.
    Do let us know if mileage measurably improves.
    Will
    #4 Will B, Jul 2, 2024
    GeoJ and _flop like this.
  5. GcinFl
    GcinFl Junior Member
    42
    2024 Prius
    Very nice. Color me envious!
    Blackat likes this.
  6. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I was going to drive the tires down first but just couldn't take it anymore
  7. Winston Smith
    Winston Smith Active Member
    359
    241
    OH
    2024 Prius
    LE AWD-e
    And looks much better than the Everydaydriver experiment.
    Avoiding the 19" wheels altogether is my primary reason for having my sights on an LE.
  8. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I was really only interested in AWD but my one choice was the LTD. That said, I'm glad I have it
    samsprius1 likes this.
  9. Hotdog453
    Hotdog453 Junior Member
    Ohio
    2024 Prius Prime
    XSE Premium
    Nice! Any impact on MPG yet, that you've noticed, good or bad?
  10. samsprius1
    samsprius1 Active Member
    720
    182
    2023 Prius
    Limited AWD-e
    I agree they could’ve put better tires on a 40+ K car! Michelin at the very least! I just can’t part with my 19 inch wheels, what were you running for air pressure? I find mine handles pretty well in extended curvy sections of road, better than any others I I’ve owned Gen2-Gen3 ! I am very satisfied with the all-wheel-drive and the limited trim,
    Will B likes this.
  11. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I'm pretty sure I'll take a small hit on MPG but who knows. 2 words for me- worth it.
    Already rides better. The Toyos were garbage tires
  12. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    I drive in the CO mtns taking Berthoud Pass frequently. Handling was sub-par but I'm coming from a GTI.
    I ran the suggested air pressure. If you look at the Toyo tread pattern, it's not designed for ultimate handling, IMO.
  13. CeruleanBlue
    CeruleanBlue Member
    66
    25
    NC Triangle
    2023 Prius
    Does the odometer-speedsometer need to be recalibrated with such a change?
  14. Zeromus
    Zeromus Active Member
    553
    307
    Ottawa Canada
    2024 Prius Prime
    SE
    In Canada they come with bridgestone ecopias on the SE prime, which is 17 inch from the factory. Sure they have some road noise, being Low rolling resistance tires, but from all I've gathered, they are better than Toyo tires.
    I have the michelin winter tires, and they weren't much noisier or quieter, really. Hopefully by the time the tread is worn there will be Michelin all seasons available, since they tend to be a bit quieter than bridgestone in general from my experience on my other car. I mean if the winter michelins are similar in noise to bridgestone all seasons, I'm sure the michelin all seasons would also be quieter.
    Yvrdriver and reservoirblue like this.
  15. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    nope
  16. bisco
    51,998
    those look great. well done!
    Blackat likes this.
  17. Blackat
    459
    320
    Colorado
    2023 Prius
    Limited AWD-e
    A better shot
    xliderider likes this.
  18. Humble Bear
    Humble Bear Member
    130
    49
    Arcadia, CA
    2024 Prius
    Please show the whole car, not chopped off nose or rear.
  19. Mendel Leisk
    41,522
    OD is theoretically identical to the stock 19" size (195/50R19). (y)
  20. Gokhan
    Gokhan Senior Member
    6,250
    2,481
    Paramount CA
    I like the Gen 5 OEM aero wheel covers better than aftermarket wheels. Could they go on aftermarket wheels?
    These particular aftermarket wheels resemble the Gen 4 OEM wheels with the wheel covers removed.
    #20 Gokhan, Sep 10, 2024
