Prime charging cable warranty?
Discussion in 'Prime Technical Discussion' started by Scarface2005, Jun 30, 2024.
  1. Scarface2005
    Scarface2005 Member
    93
    47
    San Bernardino Mountains
    2017 prime and 2020 prime both charging cables not working. With a non contact voltage tester, one of them chirps like it’s got power, but no power indicator light, and it doesn’t charge the car. The other has a flashing power indicator light and will sometimes still charge some, but very slowly.
    I’m pretty handy, and if someone has links to previous threads or any personal insight, I’d like to try and repair each one back to working order, or at least use parts from each to get one functioning safely.
    ideally they’re both under warranty? Are the charging cables covered by California 10/150k warranty?
    2017 and 2020 prime both with around 145k miles
    thanks
    52,286
    i suspect they are not, but it's always worth asking.
  3. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Are you sure it's the charging cable not the household socket or car socket?
    When you draw high current, 12A off a cheap 15A household socket, The pinch tabs held in place by plastic tends to loosen up over the years. The one cable that partially works, run your hand over the entire length of the cable, check for hot spots - including the outlet your plugged into. They do make tension checkers for your household outlets, but it may be cheaper to just replace it - if your handy.
    Good Luck..
    PS I've noticed in another one of your post that you've tried charging two cars on one circuit. Even if you backed both cars down to 8A you'll still need a 20A circuit with nothing else on it to keep from popping the circuit breaker.
    Danno5060 and Scarface2005 like this.
  4. Scarface2005
    Scarface2005 Member
    93
    47
    Hey yes I’ve verified outlet is fine, gfci is fine, breaker is good. I did have to replace a breaker after charging two primes on it repeatedly several years ago. Both primes are on separate, dedicated 20a circuits now.
    As far as I can tell the charger is covered by Toyota warranty 10y/150k, just like the traction battery. At least here in California.
    I tried to upload photos with no luck. But, I dug deeper and the charger that just failed this week is from my 2012 Prius plug in. The one that failed about a year ago is from 2017 prime. The one that still works, thankfully for now, is from 2020 prime.
    When gas was $6 a gallon I was schlepping my 2017 charging cable with me everywhere. Somehow the grounding plug was broken off. But, it still worked for several years, until it began having a flashing light and only offering a trickle charge. Last time I plugged it in it there was no flashing light, and no light of any kind :-(. Totally dead.
    I’m looking at buying a charger replacement on Amazon. I’m still gonna take the 2017 charger to a dealership and attempt to get it replaced under warranty. But, I wanna replace the ground pin first, lest they use that as an excuse to not warranty it. Question about third party chargers…
    They all advertise that they charge at 16a. Is that UP TO 16a? Ie, prime will still charge at 8a or 12a? Depending on where you have it set?
    I’ve noticed when I charge at 8a of course it takes longer but seems to add a couple extra miles. When I troll leaf forums it seems the consensus is that quick charging leads to faster battery capacity degradation. Is the 8a v 12a difference too minuscule to apply here in the plug in hybrid electrical vehicle segment?
  5. Danno5060
    Danno5060 Active Member
    393
    201
    Wyoming
    I can't seem to find it, but I think there's a preprogrammed limit to the number of times you can use the charger. I think they built that into the charger to prevent problems with the contacts in the plug from wearing out. If that's the case, Toyota may not repair your charger under warranty.
    The charge rate in the Prime is limited by the car's onboard charge module - 12 Amps normal, or 8 Amps. That's the car's "charge acceptance rate". I've verified this as my charger can be set up to charge at various rates, setting it to more than 12 Amps does not increase the charge rate more than the car will accept. Going to level 2 does make it so the car charges in 1/2 the time, so it "effectively" charges at 16 or 24 Amps, but not really. It's just charging at 12 Amps from both the line voltage circuits at the same time. (I'm sure there's a better way to say this.)
    Using the level 1 charger on my 2019 Prime, it takes 8 hours to charge at 8 Amps, and 6 hours to charge at 12 Amps. For my level 2 charger, it takes 4 hours to charge at 8 Amps, and 3 hours to charge at 12 Amps.
    I got a charger that can be set to various charge rate limits. I set it to 16 Amps, but it could be set to up to 32 Amps. It's got a meter on it, and I verified that when I set the car to a 12 Amp charge rate, the charger read 12 Amps. When I set the car to 8 Amps, the charger said 8 Amps too. I didn't try setting the charger to 10 Amps and seeing what the car said.
    The fully charged range includes an estimate of how you use the power. I wouldn't put too much stock in a couple extra miles of range, because that's just the car's estimate based on how you've been using your car fro the last few trips. My wife is a teacher at a rural school 50 miles outside of town, and most of that trip is highway miles. The car has been getting closer to 20 miles of EV range. Now that it's summer, and we're just running around town, the car is saying it has a lot more EV range after a charge. Yesterday it was 29.3 miles. Changing the use of your heater/AC settings also changes the estimated EV range too.
    I think the quick charge leading to faster battery degradation on your Leaf's EVs is because of the effects of excess heat on the battery cells. To charge at the rate that causes some concern would be more like what you would get if you charged the car by connecting directly to the car's DC battery voltage. I don't know what the Leaf is capable of, and this gets into the technical details of fast DC chargers.
    I'm not sure excess heat buildup in the battery is much of an issue with the Prime's 12 Amp charge acceptance rate. The direct-to-battery DC connections aren't provided on the Prime's J1772 port.
    #5 Danno5060, Jul 2, 2024
    Scarface2005 likes this.
  6. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Yes, a slower charge is always better on an air-cooled battery pack. I know an early adopter of a Tesla that has already replaced his pack, for $15K. He has free lifetime charging at any Tesla charging station, but I suspect those quick charges didn't do that old pack any favors. Since he had free lifetime charging, he saw no reason to install a L2 charger in his garage - even though he could afford it.
    Regarding replacing that plug, I've heard that there may be a thermal resistor in that plug. Please report back if that is the case. There should be some extra signal wires, once you cut that plug head off. If there is a resistor, you should see 3 thick power wires and 2 thin signal wires. I don't believe Toyota will cover the charger with that busted ground pin, but it doesn't hurt to ask.
    Good Luck....
  7. Scarface2005
    Scarface2005 Member
    93
    47
    I’ve ordered a third party charger off of Amazon, Asani brand. $115. NO APP thank god just plug and play. There were definitely cheaper ones, but all were app dependent.
    I kept both of my now defunct chargers plugged in 24/7, through rain, heat, snow, etc..I’m thinking that’s how Toyota intended them to be used? Or at least Toyota prepared for all of us mass market consumers to keep the charger plugged in 24/7. But, I’d reckon they’d last much much longer if only electrified when they’re ready to charge, via an on/off switch, smart plug, etc.. the charger seems just like a fancy low voltage transformer to me, and I’m looking forward to taking it apart and getting it working again. But..
    I still have t gotten around to repairing the original Toyota chargers… been too busy.
    Danno5060 and bisco like this.
  8. Scarface2005
    Scarface2005 Member
    93
    47
    FYI not gonna cut the head off. There are screws, at least a screw, to disassemble the plug itself. I’ve tried uploading photos but it’s not working.
    just an aside… I barely have cell and internet at my carport where I work on my cars. That’s why I love priuschat bc everything is spelled out for me…literally. People upload photos, graphics, and written descriptions, not all just videos a la YouTube. I hear there’s a way to save YouTube videos to watch w out connection? But, I’m an old school old fart ;-)
  9. bisco
    52,286
    my 12 year old evse was plugged in all the time and worked until i sold it last year. i can't think of a reason you have had two go bad, unless they are outside 24/7. maybe some moisture crept in?
  10. Mr.Vanvandenburg
    1,357
    578
    2020 Prius Prime
    I saw something about the charging supply unit has a definite life, it must have been in the owners manual.
    On level 2 the charging rate is 27.5 amps, 13.75 on each 120 volt line. 3300 watts/120 volts. On both my previous Volt and my current Prime I was seeing 3500+ watts on a chargepoint station screen. I thought the cars had 3500 watt chargers. No, the station has about a 130 volt power supply, or 260 on level 2. Not sure if that voltage is harmful or not.
  11. Scarface2005
    Scarface2005 Member
    93
    47
    “When you draw high current, 12A off a cheap 15A household socket, The pinch tabs held in place by plastic tends to loosen up over the years. The one cable that partially works, run your hand over the entire length of the cable, check for hot spots - including the outlet your plugged into. They do make tension checkers for your household outlets, but it may be cheaper to just replace it - if your handy.”
    ^ Homie was right :). 20 year old 15A GFCI was bad, AND the cheap 14A rated extension cord was bad, or rather the female socket / recep at the end was bad.
    The extension cord’s outlet’s metal had literally melted back to a point where it wouldn’t make contact. So that’s why it still tested good with a non contact voltage tester. To make things even more complicated, the outlet I charge off of is not the GFCi, but ‘daisy chained’ via the auxiliary line connections of the GFCI. Both the GFCi and its’ aux outlet are in very high moisture areas, and the inside of the j box and old gfci itself were rusty af.
    But…I’m now back in business :). I replaced the ancient, broken 15AGFCI with a 20A weather resistant GFCi. And I replaced the cheap extension cord with a real 20A rated, fire Marshall approved 25ft cord. I’m still using the aftermarket charging cable just because it looks so much cooler and sleeker than the original.
    BiomedO1 likes this.
  12. BiomedO1
    4,019
    2,109
    SacTown, Ca
    Get one of those harbor freight, non-contact infrared thermometer when they go on sale. Less than $20. You can hit those outlets and cords once in a while when the cars are charging. Increased ambient temperature is a sign of loose connections, as you've seen for yourself.
    Great Job troubleshooting.......
